looking for parts
Date: 06/19/2020 02:32 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
Date: 01/21/2023 04:19 pm
Date: 09/03/2018 08:58 am
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Date: 07/08/2022 11:51 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
  • Online today: 116
  • Guests: 59
  • Total: 59
Official 1980 Turbo Pinto Project Thread.
Started by don33, June 11, 2011, 04:35:42 PM
don33
good info on the u-joint dave.  I assume that joint is to mate up with an 8" ? and Dave, didn't  I tell you to get the rear shaft out of a 4X4 model  8)...
Quote from: don33 on July 10, 2011, 10:02:18 PM
1997, but there are several years that are the same.  I think it is 96 and up. its the rear driveshaft on the 4X4 model...  after some quick research I have found that the 96/97 is the ones that have the C4/T5 compatable yoak.. although the newer years may be the same.  there may be more but those two for sure... it will be 45.5 center to center on the drive shaft u joints. and make sure the ends are welded on not crimped on. I believe it was only the early shafts that were crimped 95 and earlier.  and one last note, you may or may not need a different rear u-joint.
Me and my dad pulled a shaft from a 2wd Aerostar but it was to long, 57 1/4". I will be going back to have it swapped out though.
At O'Reilly AutoParts I found the necessary U-Joints to use with this axle. they are PRE 353. It is a crossover u-joint so it is longer one way than the other.
http://www.oreillyauto.com/site/c/detail/PRE0/353.oap?keyword=353
don33
fomocolover
Hey Don what year of aerostar did you get this drive shaft out of im thinking i need one....Thanks
Congrats on the "bolt on" drive shaft! I may go this route with Brownie (my 73 with C4 trans and 6.75" rear), instead of having the steel one rebalanced. That is, if it's cheaper. Heck, if not, I could get the aluminum one for my 78 like I have been planning, and the swap them out since I know the 78's is balanced perfectly!
don33
parts are starting to trickle in.  the speedway 5 lug rotor kit has arrived. and yesterday I picked up a 97 ford aerostar aluminum driveshaft.  the stock steel driveshaft is 46", the aerostar aluminum is 45.5"  the difference in weight is significant.  just for kicks I thought I would insert the aerostar shaft into the tailshaft of the C4 trans. it slid right in. how awesome is that !
you can see the yoak inserted into the C4 tailshaft in the pic. also I got he flange attached to the rear of the driveshaft. with any luck at all, it will bolt right to the 8.8 rear...  today the ups guy brought me the all steel universal joint from speedway motors to replace the rag joint on the steering shaft. I feel like its christmass...
don33
don33
Got the trunk floor removed...  ready to buy some steel and do some framing.
don33
yeah you can get some nice brakes if you are so inclined. but it really opens up the world of wheels......  I'll be using this kit from speedway motors on the front
http://www.speedwaymotors.com/Mustang-II-Complete-11-Inch-Brake-Kit-Ford-Bolt-Pattern,2008.html
and the stock explorer brakes on the rear, 11.25 rotors.  I think I'll be able to get her stopped.
289pinto
sounds like a fun project! Damn I really want to go to a 5 lug pattern now seeing how big of brakes I can get. Oh well I'll see what I can do for a bigger rotor with the 4 lug pattern.
1978 Pinto wagon, 289, 8" rear, 17" cobra R rims
don33
thanks for the picks Pinturbo75, yep, your treatment of the fuelcell install is very similar to what I have planned.
baflinn, I allready have my C4 built but thanks for the offer.... and I am holding out for a matched set on the mirrors. but you never know, so if I end up needing yours I will let you know, thanks.
baflinn
Hey don33, if you're interested I have a NOS (1971) TransGo C4 shift kit and a new WIX trans filter that would help you with your C4 build. New ones are going on ebay starting at around $48.
My kit is not just springs it has everything from the gasket to the shift module with complete instructions for the build included. Will add a pic this weekend of all the internal components.
I'll let both the kit and filter go for $50 plus shipping if interested.
pics: http://www.flickr.com/photos/bruceflinn/sets/72157626843265609/
- Bruce
PS. any ideas on whether or not you want the sport mirror from the '74?
Liquidating all Pinto related parts.
Current list can be found here: http://www.flickr.com/photos/bruceflinn/8007178278/in/photostream
don33
The trunk floor is gone. I'll be going to find some square steel tubing to frame up a well for the fuel cell, then tie it all into the pinto rear frame. when that's done it will be covered with thin sheet of sheet metal and all welded together with an access door/panel to access the cell. I'm going with a cell design that is 7.5 inches deep so it can be flush with the new trunk floor and not hang down much further than the stock tank. I think I will take pics since no one has answered the call and I cannot find pics of anybody else that has done this.
don33
I know there are a lot of you guys that have cut out the trunk floor to install a fuel cell.  Anybody have any pics of there install ?  Tips,  helpful hints , etc.
don33
well I pretty much have everything stripped out that's going to be.  old shocks are gone  will be replaced by performance shocks. I haven't decided yet weather I am going to cut out the trunk floor and refab it. that will depend on the rear shocks used and I will be repositioning the rear shock mounting points.  Also the battery and a fuel cell are going into the trunk.  and that's pretty much where I'm at as of now...
don33
Awesome,  the rotors on the explorer rear are 11 - 1/4.  pretty good match. I'll be ordering that kit soon.  Thanks.
don33
I think I would be better off with the larger brakes.   So,  are these the only parts I need to get ?  do I just buy the rotor or the hub and rotor ?
you can upgrade them from 9 inch discs to 11 inch disc buy using a Granada rotor, speedway adapter bracket/GM metric caliper which are larger and work better
Speedway makes a replacement rotor thats the same as stock but 5 lug thats the easiest. But if you want better brakes you can upgrade them from 9 inch discs to 11 inch disc buy using a Granada rotor, speedway adapter bracket/GM metric caliper which are larger and work better.
But thats all up to you and wether or not you think the stock size brakes are up to snuff for your project. On mine personally I want the largest brakes i can get front and rear Ive even thought about doing the cobra brake swap.
don33
I want to do a 5 lug conversion on the front of the car so it will match the 5 lug rear that will be going in.  I've seen different kits on E Bay and Speedway motors ranging from a simple 5lug rotor replacement to a full blown replace everything kit. The price ranges all the way from $60.00 or so for a 5lug rotor to $700.00 for some full blown kits. exactly what do I need ?  If I can just swap out rotors that would be great...    whats the deal ?
don33
Well, I fabed up front bumper mounts today, the old shock bumper mounts weight was 14 lbs.  the new mounts weigh 2.4 lbs that's a difference of 11.60 lbs   .    they also move the front bumper in to the body about 2+" .    I also drilled and collapsed the rear bumper mounts 2.5" .  I may at some point fab up some light aluminum mounts for the rear but not today. anyway, the pinto is now 4.5" shorter and almost 12 lbs lighter, that's not counting all the other weight reduction that has been accomplished.
don33
I was looking at the heavy steel bumper mount/shocks on the front and rear. I want to fab up some aluminum brackets to replace these heavy steel units. it doesn't  look to be to difficult.  doing this would accomplish two things, lighter weight, and to move the bumper in closer to the body.  has anybody else fabed there own mounts ?  have any pics ?
don33
Well, I figured I may as well start my own project thread.
I do this with the Idea that it may be of some help to someone who is considering traveling down a similar path, here we go. here she is as I brought her home.   has a 2.3 with a C4.     plans are, a built 2.3 Turbo and built C4.  am going to do a explorer 8.8 rear axle swap and aerostar aluminum drive shaft.
Since bringing her home I have pulled the engine and trans. pulled everything out of the interior.  now I am going through it to remove everything that isn't needed (weight reduction).  I have gutted the bumpers,  removed all sound deadening and every nut and bolt that isn't needed. the interior will go back in when everything else is done, subframe connectors etc.  will update as things happen or questions arise.
