Date: 09/01/2017 07:52 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
71-73 sway bar
Date: 06/12/2021 10:12 am
1978 pinto grill
Date: 07/24/2018 02:18 pm
  • Online today: 116
  • Guests: 59
  • Total: 59
Official 1980 Turbo Pinto Project Thread.
Started by don33, June 11, 2011, 04:35:42 PM
That's good to know for future reference. I never noticed Turbo Coupes crossed sides.
don33
I'm sure he is. however, I am not using stock Pinto hoses. I am using a stock thunderbird turbo coupe hoses.  the lower rad hose crosses from the drivers side (right behind the lower rad support) to the passenger side. the upper is the same story, it goes where it needs to. trim as needed. It's what hot rodding is all about, have a vision of what you want to do and then make it work...!
Eric's right. 2.3 Lima & German 2.0 engines have drivers side top & passenger side lower hose locations. It doesn't mean you cant run it however stock Pinto hoses won't fit.
don33
don't remember exactly, think it's in the 94 - 97 range.
bbobcat75
What year explorer radiator r u using!?!! Thanks!
1975 mercury bobcat 2.8 auto
don33
actually no, it works just great on the 2.3...! in fact I just pulled it out of a 2.3 setup, and I had another set up the same way in a thunderbird so, not to sure what your 2 cents is all about, others have done it the same way.  but stay tuned and you will see...
another of the  explorer rad fitment...
bbobcat75
just a quick question, I see you are using a explorer radiator and installing a 2.3t correct??? if so the inlet and outlets for the radiator are on the wrong sides no???  if you where running a 2.8 that radiator would be great!!
just my 2 cents!
don33
don33
as far as the NPR intercooler goes, there is a large and a small. the small is just shorter top to bottom. less cooling effect, I want as much cooling as I can get. what makes the NPR desirable is the configuration of the inlet and outlet, this combined with a 90* rotated upper intake makes for a very clean minimal plumbing setup. funny you should mention the turbo mustang hood scoop, I have one off a 2.3 turbo mustang. just waiting to go on my hood...!  I be fitting that up soon.
Alpine615
I actually believe I found the part #...Google Image search along with eBay helped!
8972183941 & 8972183942 seem to look identical to the large NPR intercooler you have installed.
As for the sheet metal cutting, I would like to keep the hood latch, since ultimately I see my turbo Pinto looking as stock as possible, but I may end up making a concession here or there...I'm also considering a turbo Mustang hood scoop (carbureted), so who knows.
1980 Runabout
don33
I don't have a part number, bought it used off Ebay.  as far as the surgery goes, I had to make a decision, big NPR as far forward as possible = no hood latch, hood pin car. I'm sure it is possible to keep the latch and use the NPR, people on here have done it, with enough time and patience. I don't mind it being a hood pin car, my car is not a restoration, its a hot rod. by the way, a Isuzu NPR is a small cab over diesel box truck. so, if you have any local truck wrecking yards around you might find one there.
Alpine615
Do you have a part # for this "large NPR"? Also, can you post a pic of the rad support without the IC installed? I'd like to see the "surgery" you performed. Thanks!
1980 Runabout
don33
Test fitting the large Isuzu NPR intercooler, yes, it did require some sheet metal surgery, but I think it now fits like factory.
don33
Well folks, life kind of got in the way and I was forced to put the project on the back burner for a while, but I am now happy to report that we are back in action. pics to follow...!
Quote from: don33 on December 01, 2011, 09:59:12 PM
yep, was aware of that one, just wondering what else was out there. its a pretty good deal, chromoly would be nice due the the thinner material (weight) but probably more expensive.
Chromoly is gonna cost ALOT more and also has to be Tig welded. Yeah the weights nice but unless your building an all out racer for the 8 second or less class I wouldn't worry about it.
don33
RSM
Competition Engineering has a really nice kit. You can start with a 8 point and work your way up from there. http://www.competitionengineering.com/default.asp
I depend are what time class you are going to run and what is required by the track you will run at...An 8 point should be a good choice....I do not think the price differs much...This is the one thing should not be done on the cheap.....
don33
Looking at 6/8 point roll bar kits, anybody have experience with what you think is the one to get ?
don33
don33
shot of the right side inner fender, where the battery used to reside.  modded for extra turbo clearence.  not quite done yet, got a few small holes to fill in. welding that thin stuff is a pain...
well I did get this done. got it all welded up tight. ground down all the welds to smooth it out. turned out pretty good. I'll get some rust resistant primer and give it a coat... I'll take a pic when I'm done.
don33
Thanks,   the weight before was 2377 according to the specs chart. Its the Pinto Pony model, lightest car for 1980. I didnt weigh it myself. wish I had.  but my goal when finished is 2250. I have taken a lot of weight out of the car and this weight has come from all over the car, front to rear.  I have also added weight to the car, this has been in the form of the fuel cell/battery mounting  structure and subframe connectors. the positive side of this is 90% of the added weight has been in the back half of the car. also, the battery has been relocated to the rear.  I like to think of that as traction enhancement.  anyway, I keep looking for little pieces here and there that can be cut out without affecting structural integrity.  when its all said and done 2250 lbs  is the target.  If I can get under that, that will be great.....
DreamBean
That is some sweet work you do. She will be nice. I would like to know the weight before and after you have finished the mods. I am looking at going InSaNe on the 76 in a couple of months.
Go Ford, Go Fast Or Go Home!
don33
a little more progress. completed the rear mount battery well this morning...
cut out some sheetmetal in the area where the turbo will go to provide more clearence, will shape a piece of metal and weld it into the hole.   even accomplished a little more weight reduction.
don33
well, I started on the subframe connectors today.  heres my progress on the drivers side. hope to get most of it done today.
finished up the drivers side, will get to the passenger side on wendsday...
ahhh, got it done. just a little clean up and tie the subframes into the front leaf spring perches and thats that.
don33
Dave, I love the feel of a steel u joint. if you move the wheel a little you get the same movement in the tires. there is no slop, no play.  you get a much better feel of the road and to me that = quicker response and better control.  some may not like that, some will like the soft mushy feel of a rag joint. but if you are performance oriented, it is the only way to go.
Timmay.... that is an 8 gallon fuel cell, and I purchased it from Speedway Motors. and it is a perfect fit.
http://www.speedwaymotors.com/Jaz-Bottom-Sump-Fuel-Cell-8-Gallon,443.html
How many gallon fuel cell is that? Also where did you buy it from?
I'm curious as to how nice the steering is with the steel U-Joint. I was thinking of putting one on my 78 Sedan, it still has the rag joint on it (replaced with a rubber HELP unit).
don33
heres another pic of the fuel cell taken from the inside of the car looking into the trunk.
here is looking from the rear of the car showing all that is seen of the fuel cell is the sump.
and here are two pics showing the front and rear bumpers after sucking them closer into the body.
and last but not least, threw the old rag joint away and replaced it with this forged steel u joint from speedway motors
Next on the agenda, subframe connectors...!
don33
well, havent done a lot for a while, but yesterday I got motivated and pulled out the new welder and this is what happened...
framed up the rear, fuel cell will mount in the center, with the battery going on the right and the the nos bottle on the left. havent decided how low to mount the fuel cell yet. the fuel cell is 8" tall and I would like to mount it with the top flush with the trunk floor. opinions/examples ?  forget those examples, got er done...
