looking for parts
Date: 06/19/2020 02:32 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 08/03/2018 09:19 am
Date: 03/06/2019 06:40 pm
Date: 04/20/2017 10:10 am
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
Date: 09/06/2020 01:57 am
Date: 07/30/2018 04:32 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
  • Online today: 116
  • Guests: 111
  • Total: 111
Official 1980 Turbo Pinto Project Thread.
Started by don33, June 11, 2011, 04:35:42 PM
If you didn't already mention plans for a bigger turbo, I'd be suggesting it now....things are usually getting pretty serious when an HX-35 won't do.  8) For the power level, something with a T4 flange might be necessary.
Dibs on being the fly on the wall to see some very unhappy V-8 guys and Hondas cry after you dish out some cold karma 😺
don33
getting all the pieces of the puzzle together.
don33
don33
hello all you turbo pinto peeps...., well the pinto project is back on track. reborn as a 1971 trunk model.  a lot of the parts that were in the 80 are going into the 71. so here we go.
don33
haven't got to work on the car for a while, plus I have relocated from Alaska to the Phoenix, AZ. area. in doing so I have suffered a setback of sorts. I had to leave the pinto behind. I brought all the drivetrain and go fast parts with me so the car will be reborn here in Arizona. so, with that being said, I am in the market for another pinto. I would like a 72-73 or a 79-80.  I will consider any year but prefer the years listed. so if anyone knows of one let me know. thanks...
don33
its a street / strip car, maybe leaning towards the strip but definitely streetable...
Pintocrazed
IS THIS A STREET STRIP CAR OR JUST STRIP?
don33
well the day has arrived, here it is. just got my short block back from the machine shop. 2542 cc's of pure bliss. 3/4 filled block, studs and straps on the mains, and piston squirters fitted into the main oil galley. 2.5 crank, bored .030 over,  5.5 Crower sportsman rods and JE turbo pistons with the Esslinger dish.  love those pistons with the Esslinger dish.
don33
I installed new front shocks today.  I used the Competition Engineering adjustable shocks meant for a Vega.  the reason for this is that the Vega shocks have more travel than the pinto shocks. under hard drag strip launches this allows the pinto suspension to fully extend, 1.5" more than the pinto shocks will allow. better weight transfer, better traction. I had to mod the lower shock mount, and drill new mounting holes in the lower control arm. its a pretty easy mod and well worth the effort...
don33
Making more progress, Y block, Summit 10 micron fuel filter,  fuel system done all the way up to the firewall, intake manifold and fuel rail drilled and mocked up.
Even if you do not use the extra flow, having a installed back up could be useful.  I have been stranded twice with a dead fuel pump.  Each time they died without warning.  Just wire it so the second pump does not run until needed/wanted.  Nice project.
JohnW
Definitely looks a bit overkill, wouldn't one be more than enough? I really like how you're laying everything out. I just came up with a similar idea for my fuel system the other day when I stumbled on a piece of aluminum angle I had kicking around.
don33
Well, maybe not quite that fast, but fast.... ;D
A 900-1,000hp-capable fuel system suggests you might be planning to go pretty fast.  :o
don33
getting started on the fuel system ... two Walbro 255's and -8 tubing and fittings all the way.
JohnW
Good to see yours coming along. I'm in a similar spot. I need to make a trans crossmember (did something different with the trans) and then once I finish welding the subframe connectors (like 80% done) I need to do fuel lines and brake lines.
don33
did a half fill with hard block today, maybe closer to 2/3 fill.  anyway, got it done. letting it set up before taking it back down to the machine shop...
don33
more progress, got the brake system all plumbed up.... slow but sure its coming along.   next, fuel system plumbing...
don33
a small bit of progress..... modified the trans crossmember to accept a poly trans mount intended for a mustang II. stock mount on the left.
don33
Yep, its the Esslinger SVO aluminum head with the Esslinger  carb intake manifold modified for EFI. the current Turbo is a Holset HX35 mounted on a twin scroll header. I will probably end up using a 84 + - rear facing turbo GT hood scoop. but that is still up in the air as I will be getting a bigger Turbo.
JohnW
Damn that intake sits up high. What's the lower? My 85 Merkur one sits lower from memory, I need to double check. From when I measured before putting the motor in, I thought my rotated one was going to be an inch or two tall
JohnW
don33
after installing a new mustang II poly transmission mount and getting everything settled as it is going to be, I got everything mocked back up. cut the hood, measured and it looks like I can use a early rear facing Mustang turbo GT hood scoop.  things are looking up. here's the pic.
don33
I got the low profile upper intake yesterday and did a quick fitment check, much better, yes, but I'm still going to need a hood scoop.
Try a 1983 Mustang GT. hood scoop , that's what I'm going with. Remember it goes on backwards...Grill toward the driver...Not towards the front. I just hope the guy you buy one from packs it better...Can you say crack.....Oh well it's going to be repaired...
don33
now that all the work under the car is done, I wanted to get everything mocked up today. mainly wanted to see everything fit. well it all went well until I tried to put the hood on. it wasn't  happening. it looks like my Pinto will be sporting a cowl induction hood scoop. so much for the sleeper look...
I'll be selling the upper intake and replacing it with a low profile model... I think I can get away with a 2.5 or 3 inch cowl induction hood scoop.
don33
Ok one more pic on subframes, looking forward, this pic is of where the subframe connector enters the existing front subframe. I placed a piece of 1/16 plate at the intersection of where all the frames and braces come together and welded everything together. a couple more beads and done... she should be pretty solid now.
