2.8 radiator
Date: 10/25/2019 04:10 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
Pinto for sale
Date: 04/19/2017 10:15 am
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 10/31/2018 12:00 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
windshield
Date: 04/14/2018 08:53 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
  • Online today: 1,044
  • Guests: 83
  • Total: 83
2.3 Turbo standalone ECU
Started by yogetthephone, June 06, 2011, 04:14:09 PM
ive been running megasquirt for 4 years..... its a great unit for themoney and can grow with your needs....look at diyautotune dot com for the kits and assembled units...all the software is free and for 40 bucks you can get tunerstudio and it gives you auto tune features.... you get the basic settings right for start up and idle.... turn on the tuning software and start driving the car.... the auto tune feature tunes the car as you drive..... should take no more than a couple hours to have it tuned... you can also (like i did) get the new wiring harness they sell and have a NEW engine harness for 65 bucks... its labeled the entire length of each wire and plugs directly into the megasquirt.... you just cut to length and solder on the correct connectors.  i recommend it highly.....
yogetthephone
Quote from: dave1957 on June 06, 2011, 06:39:39 PM
i had a similiar problem.. Ended up running a switched power wire to the red/green wire going to the dist. Hope this might help..
I ran a relay setup to the white with blue spot wire but still no go. My wire colors are different.
"There is no kill like overkill"
Quote from: fast64ranchero on June 06, 2011, 07:45:56 PM
If your stock or close to stock the factory setup does well,
I went with a ElectroMotive setup, but it's far from cheap, I think I'm into mine about $2,500 or so with everything, there are cheaper units out there, Maga Squirt, is one of them, keep in mind most systems do not run the ign. side, so you end up running a sep. MSD box or something simular, the ElectroMotive setup has it all built in...
Mega squirt can be ran with LS1 coils and then it wont be a wasted spark setup. wilson racing is a good place to look into first or even stinger preformance for the P.I.M.P ecu setup but its gunna use the factory wiring so if your factory wiring isnt working already its not really gunna help to go to a standalone that uses the stock wiring.
fast64ranchero
72 old V-8 parts Pinto
73 pinto, the nice one...
dave1957
1979 bobcat
1974 red stinkbug
yogetthephone
So I have been in the process of swapping a 2.3 turbo engine and have been having problems trying to get power to the coil for months now and after pulling my hair out over it I am leaning towards purchasing a standalone ECU system. I have never used one and am unsure of which one I should go for. I would rather not spend too much money but have only found systems for over a grand. Is it worth it to purchase one and if so which one is best for me?
Thanks, Dylan
