Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 03/30/2021 12:29 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
Date: 12/09/2018 06:59 am
77 pinto
Date: 08/22/2017 06:31 pm
Date: 07/04/2022 07:55 pm
Date: 09/20/2018 11:01 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
  • Online today: 957
  • Guests: 894
  • Total: 894
V-8, what to use for throttle?
Started by randyg, June 01, 2011, 09:15:40 PM
I spent 3 hours making mine. You will most likely have to do the same. Dont think you will find a stock Pinto piece that will work. V8 swap = fab work.  :lol:
randyg
Hey all,
I just lowered my carb because the filter stuck out the hood to far for the new scoop to fit. By removing the 1" spacer plate and the nitrous plate I now have a throttle bracket that will not work because it now sits to high. It was actually held by the back intake manifold bolts. The accelerator cable has a spring on the end and a square piece to bolt it up about a foot from the end. I assume it is the original Pinto part. Those of you with a V-8 in your Pinto-what are using for a throttle bracket?
Thanks
Randy
Just a 289......
