79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 08/08/2017 01:44 pm
Date: 11/11/2019 03:38 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Wagon rear quarters
Date: 06/17/2020 03:32 pm
Date: 02/11/2020 12:09 am
Front grill for '72
Date: 03/02/2022 12:09 pm
Date: 11/08/2020 02:10 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
  • Online today: 169
  • Guests: 136
  • Total: 136
rear shock question
Started by oldeguy, May 18, 2011, 08:44:51 AM
Wagons are the same, stud mount.
You can pull the shock mounts from a mustang II (upper and lower), from what I have heard, and use them on a Pinto. I would imagine the upper mounts would require some modification though. I know the lower ones will bolt on without trouble.
I know the 78 I had was the stud kind, & my 77 is the stud kind.
PintoMan1
i personally don't know of any year pinto that used an eye end shock on the rear. they did on the front.
1973 pinto runabout
oldeguy
Got a 72 pinto runabout, it's presently has the stud on both end shocks. I would like to use the shock that have the eye end on the axle mount. I know later Pinto's and Mustang II used this style of shocks. Can I use them without any issues? Or does anyone have info on OAL and compression length of each style? Thk's
at some point...2.3L EFI T3/4stageIII FMIC 55#inj eecla3 90mm MAF 65mm T/B 5 spd 8.8 w/ 3:73  11" rotors, GM Metric, explorer rear disc 205 55 14 fronts 225 50 15 rears subframe connectors w/ a 6 point roll bar
