1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Date: 02/28/2024 02:07 pm
Date: 03/07/2017 07:03 pm
Date: 10/02/2017 02:16 pm
Date: 11/05/2016 09:03 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
1979 pinto
Date: 04/19/2018 02:02 am
  • Online today: 535
  • Guests: 328
  • Total: 328
1973 C4 rebuild and upgrade
Started by dave1987, May 03, 2011, 10:01:17 PM
I got a little bit of reassembly done tonight after work. Wife and kids went to friends house to study and decided to spend the night there since it would be late before she got back anyway, so I ventured off to my parent's to play in the garage. It helped to wear me down from work and to actually sleep while she isn't home (hard to do).
I purchased two cans of Walmart stuff carb/intake cleaner, which wasn't enough. I just continued reassembling until I ran out of cleaner, since I am cleaning everything off with it before putting things together again, I spent about three hours on it today.
Here is what I accomplished:
Cleaned pump and replaced torque converter bushing
Assembled both clutch packs/drums and air checked them
Removed manual shift lever from old transmission and installed in new one
Removed valve body from old transmission and set aside for cleaning
Installed parking prawl and gear
Installed shift lever and parking prawl linkage
Installed both reverse and intermediate servos and covers
Cleaned and reassembled governor
Cleaned and installed governor distributor
Not a whole lot, but a lot of the measuring work is finished. Most of my time was spent cleaning parts with the carb cleaner and lubricating them with lucas. I am taking my time with this project but somewhat trying to get it done fairly quickly, since I still have to swap out the rear axle, reinstall the transmission, replace the choke and figure out some electrical issues with the right headlight and radio. I am pushing to get this all finished by the middle of July to take it to Emmett for the big car show here. I don't want my wife to worry while driving it out there.
Tuesday (technically tomorrow), I will try to get more done, if not all of it. I still need to pick up the selective thrust washers for behind the stator/pump assembly, so I can't finish the rebuild until that is done.
And now pictures!
1 - Converter bushings. Old on bottom, new on top
2 - Converter bushing installed
3 - Bottom of pump/stator assembly
4 - Top of pump/stator assembly
And the tail shaft as well...
First picture is the left side, second picture right side.
Third picture is the inside, fourth picture is the wiped out bushing at the rear of the case that the drive shaft yoke rides on. Yes, the rebuild kit came with a new one! :)
First picture is of the inside front, second of the inside back.
Third picture of the outside back, second of the outside front (there is still some dirt on the case, but none on the pump mating surface).
Good to know I didn't do something out of the "norm" there. Thanks Dave!
Well I picked up the transmission from Aamco on our way to the park. I got to Aamco right as they left the building. The gentleman who helped me earlier let us in to get the parts and he didn't even want payment for it! He said it was easy to just toss in there and have it cleaned, no worry about payment. Score! Free hot tank cleaning and it's shiny again! :D They did miss the bottom of the front of the transmission, but nothing major. It looks a world better than it did before!
First two pictures of the transmission before I started work on it, second two are of the left and right sides of it.
flash041
I too left the outer race in.The bolts are in really tight and the bolts have areally small head. Keep it up!!
This morning I finished disassembling the transmission, cleaning every part as they were removed, with gasoline. Before installing each part, however, I will be re-cleaning every part with carb cleaner and drying them with compressed air to eliminate foreign contaminants and/or substances.
I made a mistake earlier saying I had disassembled the forward clutch pack, it was actually the forward/reverse clutch pack. The actual forward clutch pack (second one removed) has no waffle pattern left on the clutch discs, and the steel plates are badly burned. As Dave stated earlier about his sealing rings, mine were dry and brittle as well. They were, luckily, no so hardened that I could not remove them though. I used a jewelers flat blade screwdriver to cut through the ring and then separated the ring from the hub and the hydraulic piston.
I was able to remove everything from the transmission casing minus the outer race for the sprag assembly at the rear of the case. The bolts from the outside of the casing were zoop in position and I ended up rounding out the head of one of them. So I gave up and put the two bolts I WAS able to remove, back.
Before heading home for the day I stopped by Transtar Industries and picked up the new thrust washer kit I had on hold, as well as a new shift shaft seal. Then I dropped off the transmission casing and tail housing at Aamco to have them hot tanked and all cleaned up.
Next week when I reassemble this beast, it will be nice and clean without any trace of metal flakes, shavings, dirt or grease! :D
EDIT: After some extensive calling around, I found the selective sized pump thrust washers at Idaho Transmission Warehouse (same place I got the torque converter from). I will be picking up one of each size on Friday as well as picking up the transmission casing from Aamco. Good day indeed! :)
Here are two pictures of Brownie and the transmission work so far (not to far into the tear down yet, haven't had the time). The mattress boxes on top of the roof rack were in the way in the garage, so on top of the car was the best place to put them! :P
So the torque converter came in yesterday (monday) but I worked and had a very important formal meeting with everyone of idaho jack in the box's, so didn't have time to get it.
I picked up the torque converter today, and $67.19 later I got myself a nice rebuilt torque converter, repainted to! They also replaced the pump shaft on the converter, so it's as good as new now!
There is some wear on the TC pump shaft which may cause some issues later, so I will be pulling out the new pump and gears that I purchased last year, from Transtar Industries, to avoid problems down the road (literally). That pump and gear set was probably one of the best $20 I've ever spent on this project, unknowingly.
Here are some pictures, very pretty! :)
I pulled apart a good deal of the transmission tonight after work. I got the tail shaft and governer off, as well as the servos, valve body, pump, and front clutch pack removed. I pulled apart the front clutch pack and didn't find anything really surprising, just a lot of glazing on the steels, I can't really tell about the clutches but I am sure they are glazed as well if the steels are. The thick friction plate/flywheel type spacer is in great shape, no glazing there. The drum itself isn't glazed, and the band is brown with a good deal of material left on it, I'm sure it is glazed and unusable though.
Dave, no split seals so far! The only damaged seal I see so far is the low/reverse servo cover seal, which is smashed so much it's more triangular now than round, lol.
I'm guessing that it's just the age of the transmission that made it die, since the clutches still look great, they still have the criss-cross pattern to them, it's just the steels that appear bad so far.
Wife called and said she was home from studying so I called it quits for the day and headed home.
It's fun so far, finding out whats inside and how it all works first hand! :D
flash041
Since my transmission was clean , sludge and filing free I  drained and reused my original torque converter . I would not of done this if I saw any filings.Mabe I should have replaced it , but a few trans guys I know thought it would be fine considering the condition of my trans.My main problem was a split seal in the forward clutch pack.
flash041, Your transmission rebuild was a major motivator for me doing mine!
I've been researching a lot about the C4 since about august of last year, a couple months before I dropped the original transmission and put this rebuilt one in. Apparently I didn't do enough research as I didn't realize that the metal flakes would deposit themselves in the torque converter or the oil cooler and then be recirculated through the rebuilt transmission upon the first start. :(
I've been doing research since then preparing myself for when I had the funds available to rebuild the original transmission and do everything again, but this time I will be doing things right with completely clean parts including the transmission, cooler and lines, and even upgrading the cooler to something slightly larger and easier to remove when it's time to flush the transmission in the future.
I hope I get it right! But then again, that's why I bought the tech book! :)
Jody, I will be taking pictures as I go. The original transmission, which I am rebuilding, had issues grabbing third gear since I obtained the car. I would just live with it and wait until it warmed up to get a 3rd gear. Then the intermediate servo sprung a leak spraying ATF onto the exhaust pipe and leaving a huge cloud of smoke while driving. I tightened down the servo cover and replaced a missing bolt and that settled down, but still leaked a little bit. Eventually I lost all of my forward gears and it took 30-45 minutes to get the car to grab a forward gear when started cold.
So, pulling apart the original transmission which has officially been deemed DEAD, should be interesting. I'm curious about what I will find as far as worn parts go. Perhaps the metal flakes I found didn't even come from the transmission, but I know they are in it. I'm wondering how much of the friction material is actually left on the intermediate band and clutches, if they are not worn down to the metal. The car always had reverse, so I'm thinking the reverse band should be good and reusable still.
flash041
tinkerman73
By the way, one thing I will say, when I get ready for any kind of rebuild on my car, I will be doing a step by step photo shoot as I tear down. That way I will have reference every step of the way putting back together! LOL.
Jody Michielsen
flash041
I did my c4 this January.Its working perfectly! I had no metal fillings of any kind.The biggest problem was the outer seal on the forward clutch pack was split. It was really easy to do.Just study a lot before taking it apart, take your time, and it will be a piece of cake.
tinkerman73
I will be watching this diligently! Thanks.
Jody Michielsen
My 73 station wagon (Brownie) is having it's transmission rebuilt by yours truly! :)
This is the third time Brownie has had it's transmission dropped, second time having it replaced/rebuilt. The C4 I just removed from the car was one that I got from a local PCCA member, as a donation. It was supposedly rebuilt less than 3k miles ago and ran great, but it has been acting up ever since I put it in. Flaring from 2nd to 3rd, which was better with the TransGo kit I installed, and then I lost reverse last week (which came back after driving it to my parents house), and now it doesn't like to grab 3rd gear at all!
I dropped the transmission today and pulled the torque converter. I have taken the torque converter over to the local hot rod transmission place (Idaho Transmission Warehouse), and they are sending it out to be cut open, cleaned out and bad parts replaced. I should have it back early next week, if not by Friday. They quoted me $48.00 for this which is better than the $125 for a new or reman unit.
I was considering just dumping a can of acetone into the converter and sloshing it around to get all of the metal flakes and crud out of it, but I figured that if I am spending $100 on the rebuild kit, $23 on the new cooler and then going to have the other cooler line reformed, I might as well do it all correctly this time! I think the crud filled converter killed the donated C4. :(
The Pioneer Super Master Rebuild Kit (Pioneer part # 753007) arrived today as well, which has a new intermediate band, clutches and steels, gaskets (including valve body), o-rings and front and rear seals.
Yesterday the Haynes C3, C4, C5 Techbook Shop Manual arrived, so I have a great reference with me at all times for clearances, torque specs and endplay specs to ensure this is done right and will last another 90k miles!
I pulled a transmission cooler from an 88 Bronco. It is an aluminum unit with a tube that runs through it with an 180 degree bend in the tube at one end and the two ports for it on the other. It's about three inches wide, 12 inches long and 1.5 inches thick with a lot of fins. I think it will cool the transmission better than the built in radiator one did, and it will be a lot easier to pull and clean later! It was $13.00 from the junk yard and another $10.00 to clean and 125 PSI pressure test it. For connecting it to the transmission, I will be using rubber lines from the steel transmission lines to the cooler, which is 400 PSI rated transmission cooling line. Six feet of this hose was $27.00, but well worth it. Eventually I will be replacing the hose with steel line all the way, but this is more than adaquet for now. I will have pictures of the mounting and installation of this cooler when that time comes.
This will take a few weeks to complete. I only have two days off a week and work all day when it do work. I don't have a lot of money to do this, so I have to wait two and a half more weeks before I can reinstall the transmission and test it, as I will not be using Walmart type F fluid, I will be using Valvoline MaxLife type F fluid which is $5.99 a quart vs. the $2.59 a quart Walmart stuff. I don't want this to be a crappy rebuild process, since I am dumping nearly $250 into this, and I want this to be the last time for a long time thing.
