1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 05/13/2021 05:33 pm
Date: 10/03/2018 02:00 pm
Date: 12/13/2016 10:25 am
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Date: 12/26/2016 04:29 pm
Date: 11/08/2020 02:10 pm
  • Online today: 624
  • Guests: 608
  • Total: 608
How to Turbo a 2.3
Started by fomocolover, April 29, 2011, 12:17:18 AM
Skratch
You need to use the Pinto front sump pan, pump pickup and dipstick. Knock the little plug out of the front dipstick hole and move the dipstick to the front, then put the knocked out plug in the rear where the old dipstick was. You will need to use the Pinto engine mounts. There is a diference in the bolt holes in the Pinto and TC pans, but use the one piece oil pan gasket from the TC. It works just fine where as the Pinto gasket won't. Hope this helps. When you get ready for the wiring, there are several sites that are very helpful. One of the best is Blind Chicken Racing. It takes you through the steps necessary for only the wiring and sensors needed to run the engine. Hope this helps. Let me know if I can be of more help.
fomocolover
Hi skratch,Its me again fomocolover, i got the 1988 T/C as you suggested . I got a great deal at 600.00 for the entire car 111.000 miles on the engine and it runs like a champ and was very well maintained .I got the engine pulled from the T/C and the Pinto i noticed the oil pans are different which one should i use ?. will the T/C oilpan work its a rear sump and the pinto is a front sump ?.Im assuming i need to use the Pinto Motor mounts, Also Pulled all  the wiring thats needed ( thats looks like alot of fun to figure out...lol.. but thats later.Anyway i hate to keep bugging you is there a certain section on this website that will help me through this process i really dont like bothering people and im sure its probably annoying.Im sure theres a section were i can just go and search for info but cant seem to locate it.So far you have been a great wealth of info and i apreciate it.If you could send me in the right direction i would appreciate it that way i wouldnt have to bother you............Lyn Leishman  S.LC. UTAH Pinto
Skratch
I personally would go with the Turbo Coupe. That way you are starting out with the best parts except for the turbo and that's a cheap enough swap. All the turbo parts will physically bolt on the Pinto engine, but it won't live long and you would also have to fabricate some way for the oil to return from the turbo to the pan. Also, the Pinto engine has cast pistons which aren't going to last long with any kind of boost. The Turbo Coupe engine already has the oil return and good forged pistons. You will come out miles ahead using a donor car, but you have to make the decision as to which one you want to go with. Hope this helps.
fomocolover
ok cool, so which is the better way to go ?.i can get the complete 84 stang for about 400.00,the 88 tc for about 700.00 complete,and can i just bolt the turbo stuff to my engine in the pinto or should i use the whole engine and trans ?.thanks,kenny
Skratch
The Turbo Coupe has bigger injectors, an intercooler, better computer and if it's 5 speed it is the world class T5. It also has the short upper intake and dipped valve cover necessary for hood clearence on the Pinto.  If I already had the 84 GT donor car, I would definately ise it, but if not, I would find an 87/88 Turbo Coupe. Updating the turbo to a T3 is a bolt on swap on the TC manifold. Just my opinion.
fomocolover
Hi,i need a little help i  just bought a 1978 ford pinto cruising wagon 2.3 litre 4 speed in great shape all original panels ( 32nd pinto ive owned )i was wondering how rare this car is,its the tangerine color with the tangerine / black interior.way cool car my first cruising wagon,anyway i want to turbo charge it and not sure what direction to go in,i can get a complete setup out of a 1984 ford mustang gt turbo  or should i go with a 1988 thunderbird turbo coupe,i heard the turbo on the mustang is bigger but it doesnt have an intercooler.......confused in salt lake...thanks,kenny
