74 pinto
Date: 09/11/2016 06:32 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Date: 03/18/2020 01:30 am
hood for a 79-80
Date: 11/30/2018 10:55 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
Date: 08/27/2018 11:11 am
Date: 02/27/2017 10:10 pm
Brake rotors
Date: 03/24/2017 09:02 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
  • Online today: 628
  • Guests: 487
  • Total: 487
No acceleratoin HELP
Started by Pup70, April 10, 2011, 04:48:18 PM
Then it could very well be time for a carb rebuild. Sounds like everything is where it should be. Where are the plugs gapped at?
Pup70
plugs are new fuel filter is new timing is 32 degrees at 3200 rpm
What is the timing set at? How do the plugs look? How is the cam timing? Have you changed the fuel filter?
All is good to look at.
Pup70
I have a 77 cruiser that i rebuilt and modded the motor a little ive hooked up with a shop out of Michigan who build 2.3 I got a cam a header and had the head decked 80 thousand and after timing it to the recommended degree it has no acceleration and tops out at 55 i have fooled with the timing again and again but with little change could this be a carb issue it is original.
thanx
