Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 02/18/2017 04:47 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 01/24/2021 07:54 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 08/17/2022 06:27 pm
Date: 12/13/2016 10:25 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
  • Online today: 178
  • Guests: 136
  • Total: 136
Hazard flashers do not work
Started by r4pinto, April 02, 2011, 06:47:32 PM
Yep!! Now to get workin on the interior & exterior of the car, so she looks all nice for Carlisle.
YAY!!!!! :tgif:   Thank Goodness It's Fixed!
I guess I shoulda added that I managed to fix the problem on the car. Turns out it was a combination of a bad fuse & bad turn signal switch. All is well with the car (for now)
Quote from: blupinto on April 03, 2011, 10:41:41 AM
Did you check the fuse?  ;D
;D  Funny thing Becky, I thought I did but it turns out the fuse I checked was not the right one. You see, I replaced the fuse box in 2006 with a modern one & never relabeled it lol. oopsey
Quote from: oldkayaker on April 03, 2011, 07:49:45 AM
Just looking at a 77 EVTM and it shows a difference in the internal wiring of the flasher units between turn signal and emergency flasher.  Assuming they are different, maybe a new emergency flasher unit is needed.
Hmmmm... You know I never thought of that. The problem just happened a couple months back & it has the same flasher units as it did before, but I will try anything. Best to check anything I can to see what happens.
Well, I had found a turn signal switch when I went to a Ford swap meet yesterday & it does the same thing. Is it possible something else is wrong?
It's the switch. I replaced my 73 wagon's original switch (which had a broken cam) for a spare I had lying around (with a half working cam) because the hazards didn't work. The replacement I installed everything worked flawlessly. Now that I have another different switch installed with a good cam on it, the hazards sometimes work and sometimes don't, it's never consistent.
Lucky for you, later model signal switches are easier to find than the pre-74 ones!
I know for sure that 74 and up Pintos, Mustang IIs, and 70s Rancheros all use the same signal switch! I want to say that I pulled one from a Fairmont at one time as well, but couldn't say for sure.
RSM
Sounds like switch may be the problem.
Having an issue with my 77 Pinto sedan. The hazard flashers do not work. The brake lights work, flasher unit is good & switch seems alright.
I originally thought it was the switch, but if I hit the switch it will blink a couple times, then nothing. I know the flasher unit is good, as I took the one from the turn signals, which is good. No change. As far as I know the wiring is good, as it has continuity. Any ideas??
