  • Online today: 624
  • Guests: 602
  • Total: 602
2.8 timing cover oil seal
Started by flash041, April 02, 2011, 04:34:10 PM
flash041
LEAK STOPPED! I got another timing cover from a local Pinto friend. I test fit it , it centered i n the hole. For extra measure I put the balancer through the seal before I installed the cover I then installed them together. One word of caution.As I went to install the fan I noticed the waterpump was bindingI took it off and found the center of the impeller was rubbibg on the raised protion of the cover. I took a diegrinder and burr and "softened" the edge, and it worked fine after that.I figure I must have a later model pump and eariler cover.The pump that came off the cover I just got had a thinner impeller.
flash041
it did have a small grove and pits. I put on a repair sleeve.
how does the sealing surface of the balancer look?
lencost
Hi Flash!
I once changed my PCV valve with an aftermarket brand, and my front seal leaked ever since.
1975 Wagon 8" C4 2.8 V6
flash041
thank you! I took it apart again. The seal is getting tore on the drivers side. The timing case is closer the the crank on the side, not centered in the timing cover seal hole.I dont see much if any room for adjustment ,as theire are two pins on the top and the bolts fit pretty tight.  I was thinking about loosing the bolts on the cover and try to tap on it to get it centered better.
I would give the machine shop that did some of your work a call and pick their brain.  Maybe they have a suggestion?
flash041
yea its really furstrating.All three seals have been from  three different places, so I doubt thats the problem.Yesterday I got an extra one, just in case this one leaked.Ill ask around the next few days . I was thinkng mabe the high volume pump is putting to much oil in the system, but it should not.Oh well I got a little less that 8 weeks to figure it out before the Stampede.
Well that is weird.  I had a leak on my 67 mustang coupe years ago.  I replaced the seal first and it still leaked.  I then noticed the groove in the balancer.  I got one of those sleeves and another new seal and my leak went away.
I can't imagine there is an alignment issue with your timing cover as the bolts should align it properly.  My next question is are you getting the right seals probably a dumb question I know....  Do the seals have the little spring in them?  Did you buy the seal from the same place both times?  Maybe they had a batch that were out of tolerance? Just thinking out loud......  Maybe call the machine shop that did your work and pick their brain?
flash041
yes its on the correct way. I just put in a Third seal. I was very careful, lubed it up really well. put the balancer on really slow still leaks!
One thing that comes to mind, is the seal on the correct way?  Sometimes the direction makes a difference on how it seals.
flash041
I am haveing problems with the timing cover oil seal. I rebuilt the engine and it leaked. I just finished taking off the front cover,and putting in new gaskets and seal and repair sleeve on the harmonic balancer, it leaks worse that it did before. Any ideas?
