78 pinto wagon
Date: 03/03/2020 01:07 pm
1974 Ford Pinto Runabout
Date: 07/10/2025 09:33 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
74 hood
Date: 07/03/2017 03:46 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Date: 04/12/2017 06:57 pm
convert to stick
Date: 05/19/2018 09:26 pm
TWM Intake
Date: 08/15/2018 08:20 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
  • Online today: 178
13" tires getting harder to find
Started by dave1987, April 02, 2011, 02:20:54 AM
RSM
I'm not sure how much material is in the stock 4 lug axle flange but it may be possible to redrill the axle and drum for a 5 lug. Stuff like that is done all the time to change bolt patterns for more choices on wheels. I had my 1970 Dodge Dart done. Changed from the factory 5X4 pattern to the 5X4.5 to use Ford wheels on the rear axle. Was cheaper than new axles.
how about 5 lug axle shafts from another 8" equiped car? Even if they are longer, having them shortened and resplined shouldn't be to much trouble.
Per 5 lug conversion - the fronts are easy, the rotors are readily avalable. I believe the challenge is the rear axles, as no aftermarket 5 lug sets to fit the Pinto setup are available anywhere.
I am still planning on a 5 lug conversion down the road. As I plan to convert the rear to disc brakes (easier now that I have an 8" axle), since a V8 swap is in my 78 Pinto's future.
I was looking at the ansen sprints that Jippah just got. I have had my eye on those for a long time, since I started driving the car really. I could just never remember who made them!
I have read that the ansen sprints are 15" wheels. What size tires should I use with 15" wheels so that they do not rub against the fender or the inner fender liner?
EDIT: Thinking about it, Wouldn't a 5 lug conversion be pretty easy? Arn't there 5 lug stock diameter rotors available for the 78 Pinto suspension? Also, 5 lug 8" axle shafts using a stock sized drum and backing plate should be pretty easy to locate, right?
The 80's Mustangs and T-Birds all had 14 and 15 inch wheels.  Just about any 4x4-1/4" wheel should work. The cost would be considerable to go 5 lug considering there are viable options.
Tom
Robert's right I have them all up through 16".  Fred   :)
RSM
I wouldn't change if I didn't have to. If you had to change, 4 lug wheels are available in 14" and 15" so you wouldn't have to do a 4 lug to 5 lug conversion.
Same here. Discount/America's Tire Co. has 13s in stock- even the 155/75R13s I have!  ;D
Dave, I have no problem finding 13". There is still a lot of cars out there that use 13's. I would not change too costly.  Fred   :)
Dave,
If it were me, I'd keep looking.
With 13" tires getting harder to find, I'm considering doing a 5 lug swap on my 78 Sedan and bumping up to some 14 or 15 inch slotted wheels with a similar appearance to the stock Pinto "mags".
My question is, do I upgrade the front discs to 5 lug and pull granada axles for my 8" axle (have them shortened a bit as well), or do I leave it all 4 lug and attempt to continue looking for 13" tires for the original steel style wheel?
