Date: 06/07/2021 08:14 pm
pinto for sale
Date: 09/11/2016 09:47 pm
Date: 01/06/2017 11:42 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
Date: 08/08/2018 12:26 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 07/20/2018 03:00 pm
  • Online today: 2,773
  • Guests: 129
  • Total: 129
I have some questions regarding comfort and updating.
Started by tinkerman73, March 25, 2011, 04:38:58 PM
lateniteauto
so for the main gauges (speedo + tach/multi gauge) you didn't have to cut the dash... awesome.  I have purchased the custom pillar gauge pod from MAP351, and planned on putting my fuel gauge in the lower dash.   Thanks for the info!!!
vonkysmeed
Have not cut the dash yet.  Right now I have 3 of the gauges where the heater controls go (no heater at this time) and teh fuel gauge where you see it in the picture.  I plan on putting a piece of stainless on the dash where the dash cover goes, but have not done so yet.  I also plan on putting the heater back on for the sole purpose of the defroster.  The controls will go in the console below the dash as I think it is more important to see the gauges.  I also have a used up triple gauge cluster from a later pinto that will go where my three are currently.  Tried to see how to retrofit them into it so I could keep from cutting the dash but it has not been my focus a this time.
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
lateniteauto
vonkysmeed
      "I will end up having to cut my dash to make it work, but I prefer to see the Large tach and separate gauges in"
Why and where do you have to cut the dash?   I had thought about going that route...
vonkysmeed
At one time I saw an insert you could put on the Pinto Speedo that made it white.  If you look at the picture, you will notice that I completely changed out my gauges in my cluster using modern electronics in the factory location.  If you have the $$$, you can get A speedo and a quad gauge (oil pressure, water temp, voltage and fuel level).  Have even seen Speedo's with a small tach integrated for the complete set of gauges in the stock locations.  I will end up having to cut my dash to make it work, but I prefer to see the Large tach and separate gauges in
73 Pinto Runabout
6 point cage
tinkerman73
Thank you. Very limited info there. But I did relpy. If he is still a user, hopefully he will reply and provided me more photos and details off site. Thank you very much for the idea of led lights. I did not think about those at all! DOH! LOL.
Jody Michielsen
Those close calls are definitely unnerving.  As for moving controls to the steering column, Wittsend installed the steering column from his donor turbocoupe car.  Suggest getting the EVTM's for both yours and the donor car to make wiring easier.  Here are a couple links to it.
http://www.fordpinto.com/index.php/topic,9958.msg61986.html#msg61986
http://www.fordpinto.com/index.php/topic,11742.msg75710.html#msg75710
For speed control, suggest using one of the electronic versions instead of the Ford mid-80's pneumatic actuated ones which are large and heavy.
You can get LED replacement bulbs in various colors and brightness.
tinkerman73
Also, has anyone put a speed control unit on a Pinto? Another one, has anyone put in newer gauge pods that were luminated more brightly? Like a very whitish blue light? Thanks.
Jody Michielsen
tinkerman73
While driving my car two mornings ago when we had a reall bad snow here, I was doing about 25 and needed to use my wipers. Well, I had to lean forward to turn them on. It caused me to spin out when I hit the slush. Needless to say, I had a tractor trailer behind me. I was all over the road. Luckily, I know how to bring a car back into control. I swung the wheel just a tad to get me finished turning around into reverse. I also slapped her into reverse and slowed down and pulled over to the side. The tractor trailer just missed me. Then I put it in forward and turned around and continued on my way. Needless to say, I had to take a crap the rest of the way to work. I was so freeking scared of wrecking my nice pinto wagon! So now I am in serious condition once the money rolls in to update the steering colum so I can have a column mounted wiper switch. With the snow and rain here, I wouldnt mind getting at least a three speed wiper set up either. Has anyone ever dont this in the past? Can anyone help me out with what colums would fit that I could fairly easily convert over to adapt the pintos wiring? Any suggestion on wiper motors too to allow the multi speed like three, or adjustable? Thank you.
Jody Michielsen
