Date: 09/20/2018 11:01 pm
Date: 01/30/2017 01:48 pm
Date: 08/01/2018 01:27 pm
78 hatchback
Date: 03/12/2023 06:50 pm
Date: 09/15/2019 08:30 pm
Date: 02/21/2022 11:11 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 09/03/2018 08:58 am
75 wagon need parts
Date: 05/28/2020 05:19 pm
  • Online today: 125
  • Guests: 131
  • Total: 131
Strange Noises/Vibrations
Started by blupinto, March 09, 2011, 08:17:58 PM
Looks like Saturday is Pinto Day! lol Thank you again Dave. I definitely need it on jackstands... I just wasn't sure I needed the rear wheels suspended. I can't wait to see what's going on! ;D
No question is a dumb one!
No, it doesn't have to be on jack stands to test/check these things. It does help though, to get under the car with some moving room.
Pinto's don't sit very high above the ground you know! lol :P I have smacked my head and elbows against the bottom of the car and the ground a few times myself while crawling around under the car without any stands to hold it up!
When you check for excessive drive-shaft movement, pull the e-brake so it is engaged, keeping the wheels from moving.
It has been awhile since I was last under the car, but you will see the transmission cross member somewhere in the middle of the floor. When you find the tailshaft (back end) of the transmission, push up on it. It shouldn't move much, if any at all. If you can lift the transmission up and away from the cross member, you need a new transmission mount.
Transmission mounts are cheap and easy to install to! Maybe a total of 4-6 bolts to remove.
Dave, this is a dumb question... but... does the rear need to be on jackstands to perform these tests? Also... thank you for this info. It doesn't sound too major...whew!
What comes to mind from my experience with vibrations both from the C4 automatic and the 4spd manual transmissions, are as follows...
Bad pinion preload (unlikely to happen out of nowhere like this)
Bad u-joint (I would think it would happen all the time if this were the case)
Slipping clutch (probably not your case since you notice this in neutral)
Bad transmission mount (happened on brownie, vibrated like a beast regardless of what gear was selected)
Easiest check would be your transmission mount. For Brownie, the original mount literally tore in half and the transmission was just sitting on the cross member. Without anything to hold the transmission in place or cushion any movement against the car, it was a LOUD ride, even just sitting in park!
If it's the U-joint, twist/turn the drive-shaft. It should be SOME, but not much. I would say anything around 90 degrees of free movement is a DEAD giveaway.
If it is your axle causing the vibration, the first thing I would check is the pinion flange. Easy enough to do with the drive-shaft still on the car. Try moving/sliding the driveshaft towards the back and front of the car. It shouldn't move at all, but on my 78's original 6.75" axle, the pinion parts were so out of alignment that it could move back and forth a good 1/4" (not a good thing!).
OK I got a doozy...
For the last couple of days while driving Ruby to and from work I've noticed a couple things. One- she does some weird vibrations... sometimes when I accelerate, but mostly when I'm not. For instance when I put her in neutral from 4th gear (as in coasting to a stop or slower traffic) she'll vibrate loudly like I'm driving on a road that has recently been scraped before a new blanket of asphalt is laid. She does this in the 35-45 mph range. If I downshift from 4th to 3rd I don't get the vibrations. Also, if I'm in gear (especially 2nd or 3rd) and I don't have my foot pressed on the accelerator she vibrates.
The second issue (and I won't be shocked if they're related) is when I'm in gear she makes a loudish "clump" noise every time I press the accelerator pedal- even lightly, just to maintain speed. This noise definitely sounds like it's coming from around the transmission area. The vibrating is harder to pinpoint.
Despite these noises and feelings she runs well, shifts well (though now and then I hear a different "clunk" noise. The "clump" noise sounds like muffled backfires... and it definitely doesn't sound like when my late '72 had a bad U-joint.  Is Ruby in trouble? I have about 2 months and very little funds to get her roadworthy enough to make this trip to Carlisle. It looked like I was definitely going to the Stampede and show, but I'm waiting for the other shoe to drop. Did it? Please help! Thank you.
