1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 12/15/2018 02:21 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Date: 11/02/2019 10:25 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
  • Online today: 3,091
  • Online ever: 3,214 (Yesterday at 10:48:59 AM)
  • Guests: 1521
  • Total: 1521
Turbo Swap fuel lines. HOPEFULLY WILL RUN THIS WEEKEND!
Started by yogetthephone, February 26, 2011, 02:41:00 PM
Congratulation s on the progress.  Ideally, the computer will control the relay for the fuel pump.  You should also employ at least one safety device to stop the pump in case of an accident: inertia (impact) switch, a oil pressure switch, etc.  Keep a fire extinguisher handy just in case.
http://turbotbird.com/techinfo/Fuel_Pump/Fuel_Pump_Diagnostics.htm
http://www.fordpinto.com/general-pinto-talk/electric-fuel-pump-safety!/msg43239/#msg43239
I'm guessing your just wanting run hose to the original metal lines?
Well if this is right then you can get hose to do it with but instead of heater hose you need fuel injection fuel hose.
http://www.oreillyauto.com/site/c/detail/GAT0/27094.oap?keyword=fuel injection hose&pt=N0926&ppt=C0222
Its good to 180 psi i used this on a corolla i built its best to put 2 good quality hose clamps on each end just to make sure it stays.
yogetthephone
Finally am on my final checklist to start the pinto wagon. Only one big job remains which I have been having much trouble with. The fuel system! Converting from the carbureted 8 psi system to the new fuel injected one is using 4 times the pressure. And after being told by the Auto-zone people that I could use heater hose with hose clams (first engine swap I didn't know any better) The whole thing begins spraying fuel when is gets up to around 30psi. I went down to a performance shop and they said that heater hose is a terrible idea. What should I do? keep in mind I'm on a budget. Is it possible to use hose safely?
Thanks,
Dylan
"There is no kill like overkill"
