1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 03/14/2020 01:52 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 11/05/2020 06:32 pm
Date: 04/15/2017 05:14 pm
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 07/10/2016 10:17 am
  • Total Topics: 16,268
  • Online today: 152
  • Guests: 160
  • Total: 160
2.8 V6 rebuild
Started by flash041, February 09, 2011, 10:13:49 PM
great progres  we will see you in a few weeks
flash041
I exchanged the power steering pump today...its QUIET!! One more thing done!
flash041
I replaced the front timing cover with another and the oil leak problem is solved! Also today the transmission started to shift the way it should! I figure it was a valve sticking. The power sterring pump is still noisey. Ill give it till this weekend.If it does not quiet down ill swap it out for another.
flash041
I will deal with the trans after the other issues are solved. I pulled the front timing cover off to reseal it. I took a magnifing glass to the harmonic balancer and found lots of pitting. I ordered a repair sleeve that will be in Saturday. Hopefully that will solve my oil leak problem.
Not sure about the P/S question or the oil leak, but...
For the transmission, try adjusting the downshift linkage. There is a long fine thread screw on the linkage by the carburetor used to adjust the downshift linkage. I did this on my station wagon and it downshifts like a dream. I just can't get the car into third gear until it drives a quarter mile in second gear, and the 1-2 shift is a bit hard.
flash041
I put on about 250 miles on the car today. I have three main issues to deal with.
1st
    I replaced the power steering pum with a reman after I broke the plastic nipple off on the return line.I replace all hoses, and now the pump is VERY noiey at times.Mainly when I rev it up and trun.I may just have to return the pump and try another one.
2nd
    The front engine oil seal is leaking.I tried putting in another, same result. The front cover appears to be shifted off center to the right side of the engine.The crank stub is not centered in the hole where the seal goes. I may have to remove it and try to get it centered more. Any Ideas or has any one else had thei problem?
3rd
      All gears work on the transmission, but. It will shift 1st to 2nd to 3 fine, but when I come to a stop it does not go back to first.It is still in 3rd or 2nd. If I manually  put it into 1st then back to drive , it shifts throught the gears fine till the next time I stop.
Awesome news! You have a brand new Pinto again now! Inside AND out! :D
Is it shifting without any issues now?
I'm planning to rebuild my 73's C4 transmission soon but want to be sure that rebuilding it will actually work for the 2-3 shift flare. I remember you having issues with yours before all of this work.
flash041
took it out for the first time at highway speed today. Running good! Have a few small issues to button up.Tomorrow I plan to drive it all day. Got to get it broken-in before the Stampede!
flash041
Thank you. After running for a few mins the short rubber fuel hose after the fuel pump sprang a leak. Also a little anti freeze leak at the upper hose where it connects to the intake . I replaced the fuel line and tighted the rad hose. Tomorrow I will let it run for a while, even take it for a short spin to make sure the transmission is shifting fine. Cant Wait!
vonkysmeed
great job.  always a good sound
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
flash041
ITS RUNNING!!!!!!!!!!!!!!!!!! its quiet and smooth, and the trans goes right into gear!
flash041
Getting back at it. i was going to paint the engine bay, but time is too short. So today I joined the transad engine and ...they are In ! It was realy easy and plenty of room.
flash041
Tonight I thought id take the starter apart to see if the brushes were ok.It worked when I pulled the engine. When i took to apart I found one brush holder was broken, and the brush was just laying inside disconnected from its wire! its amazing that it even worked.Time to order a new starter. I plan to have the engine and trans in by next weekend.
flash041
Just waiting on one o-ring for the oil filter adapter, then its ready to mate to the transmission and set back in! Thats after I clean up a little rust in the engine compartment.
flash041
Got the front cover, oil pump, oil pan, heads and rockers in!
flash041
Yea I do not know why it did not clean that , but its ok. Today I installed the rear main seal, flexplate ,and timing gears.One tip, dont forget the spacer washer at the end of the cam! I tightened the cam gear and the engine turned over very hard. I looked at the old cam and noticed the spacer.I took off gear and installed it on the new cam.
Odd that any residue would still be present after hot tanking. I don't recall seeing any of that after my 2.3 was done.
Build is coming along well, can't wait to see more pix! :D
Awesome. Love the "nth detail" of doing everything you can. I am not rebuilding my block but with only 65k original miles, no real need.
flash041
Thank you! The "white putty" around the cylinders is assembly lube. The water passages are a light yelloish, dye residue from the antifreeze I assume.
Looking good! What's the white putty looking stuff in your water passages though?
It needs paint! :D
flash041
I got the block back from the machine shop last Friday. They put it in the cleaning tank, honed the cylinnders, cleaned the pistions , reconditioned the rods , and put in new cam bearings. I got it home and started putting the crank in.I got the crank and cam from a friend with Pintos that lives close by.He bought them 15 years ago and never finished the project.I put the mains and crank in , no problem.I installed the first piston and bearing, and The Crank would not turn! I tried # 2 piston same thing.I looked at the box the crank came in . .010 .010 was written on the box. I checked the mains , the were .010 , but the Rods were .020! I ordered .010 rod bearings , and now all 6 pistons are in and it truns over fine1
skunky56
77 Starsky/Hutch 2.3 Turbo A4OD Sunroof
78 Wagon V6 C3
flash041
Still waiting for the machine chop to finish the block. Today I picked up a reman crank and performance cam shaft fron a locak "Pinto Guy" that was rebuilding a V6 years ago,but never finished it. So I am hoping this weekend to start putting it back together
flash041
thank you! Cant wait till I get it going again.
Quote from: flash041 on February 16, 2011, 09:59:10 PM
Dropped the block off at the machine shop to get it cleaned and measured.As it looks right now it should not have to be bored and I can use my original pistons. Ill know within a week.
Good luck man hope all goes well with her.
flash041
flash041
Got the engine out and apart! Looks really empty in the engine bay. Good news is there is no ridge in the cylinders, but there are a few vertical scratches and the cylinders and pistons.I am taking it to an engie shop I deal with to see what he thinks. I dont think it that bad.The cam bearings , were, as I suspected, wore into the copper.
flash041
My heads should be good, it has never leaked anti freeze. Although I did get it hot two years ago.I had just got off the interstate and noticed it pinging, looked down at the temp gauge and it was pegged! The new fan belt had failed! I shut it off and coasted into a McDonalds , walked to a parts store and got a new belt.It seems fine , so Hopefully my heads are good. Did you a performance cam, or leave it stock?
skunky56
No bore, mine had 70k on it, one cracked head (from overheating at one time).
Alberto and Mario helped me out by finding me a good head, it took 4 of them to make it happen, most were cracked. Remember that engine was also in the Ranger/Bronco/Capri etc. All engine parts are out there.  You will be pleased with the performance of the 2.8 it flat out rocks. Keep up the good work!
78 Wagon V6 C3
flash041
I have everything disconnected  except the fuel line. Now its to the rental store and get a hoist.I plan to do it tomorrow or Saturday. sunky did you have to bore the cylinders , or were they within specs? I already know that I have to have the crank ground, or get a kit already done with the bearings.
