Pangra wanted
Date: 02/05/2017 01:58 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Date: 04/08/2018 05:47 pm
Date: 12/09/2018 06:59 am
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
72 Pinto
Date: 03/07/2019 12:07 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
convert to stick
Date: 05/19/2018 09:26 pm
  • Total Topics: 16,268
  • Online today: 354
  • Guests: 183
  • Total: 183
subframe connectors for a 72
Started by oldeguy, January 31, 2011, 09:01:17 PM
0 Members and 3 Guests are viewing this topic.
vonkysmeed
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
vonkysmeed
Quote from: oldeguy on March 18, 2011, 07:26:10 AM
I will be installing a 6 point also. I'm planning on a Competition Engineering 6 point kit. it will be bolted to the subframe like you. While you subframing it don't forget to re-enforce the spring perch area if your going to be running any HP and want it to hook up. Bill
no problem there, plan on welding it completely in place followed by a tab off the subframe to that location.  It helps that the main hoop sits directly above the perch to assist in the reinforcement.
Here is my plan on what to do.  about the only thing I do not show is where the seats mount and how they will tie in.
73 Pinto Runabout
6 point cage
oldeguy
at some point...2.3L EFI T3/4stageIII FMIC 55#inj eecla3 90mm MAF 65mm T/B 5 spd 8.8 w/ 3:73  11" rotors, GM Metric, explorer rear disc 205 55 14 fronts 225 50 15 rears subframe connectors w/ a 6 point roll bar
vonkysmeed
your idea got me thinking more and I will most likely use some scrap tube I have to weld onto my bolt plates for the roll bar while I do the subframe connector.  This should help keep things in line along with only supporting the car by the suspension.
73 Pinto Runabout
6 point cage
vonkysmeed
Cool, I will be doing the same here with  mine.  I will be using 1.5x2.5x1/8 (11 ga) and cutting the floor at the same time.  Good Luck
73 Pinto Runabout
6 point cage
oldeguy
plan to post pictures....will be starting this mod by next week. BTW...I'll be using 1.5" sq. tubing.
vonkysmeed
sorry, I missed this one when I did my searching.  I am cutting the floor, but like some of your ideas as well.  Can you post pictures of yours when you are done?
73 Pinto Runabout
6 point cage
oldeguy
No comments on this subframe connection idea?
oldeguy
did lots of searching for subframe connectors, didn't like any of the concepts because of cutting up the floor pan. so here is mine. using 1 1/2 x 1 (or 1 1/2) x 0.083 wall retangular tubing between the rear spring pearch and the crossmember around the seat location. it will be run flush to this rocker panel flange, and will be weld at many point to the flange. custom plate will be made to connected the tube to the spring pearch. up front, custom plates to fit to the crossmember and the tube. these will be welded in place. may add a tube at a 45 degree angle from the front crossmember tube to the front rail. the
design sketches on http://s1139.photobucket.com/albums/n547/donchez22/Turbo%20Pinto%20overhaul/?action=view&current=subframedesign.jpg a note on the sketch...the pictures show 1 1/2 sq. tubing and 1" sq tubing inside of the 1 1/2 tubing.
The car now has a roll bar that I'm going make it at lease a 4 point, but probably make it a 6 point.
So,what do you guys think?  :)
