2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 09/02/2021 08:21 am
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
hood for a 79-80
Date: 11/30/2018 10:55 pm
cam pulley
Date: 05/30/2018 04:56 pm
  • Online today: 2,399
  • Guests: 1391
  • Total: 1391
72 Pinto "Hot Rod" OverHaul
Started by oldeguy, January 29, 2011, 10:37:51 PM
This is the COMPUTER (PC) method. If you are using your phone you will have to wait for someone else. This is not a "one and done" process that some of the social media site have.
First the picture needs to be stored somewhere (and you need to know where that "somewhere" is) on the computer.
Note that there is a picture file maximum size and natively out of the camera/phone that picture size can often be too large. What I do is open the picture, then use the Snipping Tool to recapture the image and it will create a new picture file that is smaller in data size that you save. I recommend you use some indicator ( I use LR) in the file name to indicate it is a "lower resolution" image.
On the page where you create the post scroll down to "Attach." Select "Choose File." This will open your folder files. Navigate to the location (drive, folder, image) where the re-sized pictures are located. Click on the picture and the picture file name should fill the dialog box near the bottom of the open window. Click on "Open". That should complete the process.
In summary: Transfer pictures to the computer, resize picture to an accepted size, select "Choose File" and  navigate to the location the picture was stored, click on the picture to highlight it (and fill the dialog box) and select "Open."
oldeguy
call me crazy, just bought a 1980 Pinto 3 door. 937 mile round trip, 16 hours and an average mpg on my 03 dodge 3500 dually of 29.3 at 70+ MPH...sweet
at some point...2.3L EFI T3/4stageIII FMIC 55#inj eecla3 90mm MAF 65mm T/B 5 spd 8.8 w/ 3:73  11" rotors, GM Metric, explorer rear disc 205 55 14 fronts 225 50 15 rears subframe connectors w/ a 6 point roll bar
oldeguy
Hello all, sold my turbo foxbody car...sad to see her go but it was time. So project Pinto is back on. How do I add pictures to my posts?
PintoRoyL
I am relatively new here, but I think I can learn a lot from this project.
I intend to keep tabs on your progress. Sounds very interesting.
Quote from: oldeguy on July 29, 2021, 05:17:13 PM
got a year award today, how do I post this in my signature? thanks
I'm a little mystified by what you're calling a "year award"... can you elaborate on that, please?
Dwayne ???
oldeguy
Looking for subframe pictures anyone as done thanks!
oldeguy
Quote from: oldeguy on July 29, 2021, 10:40:59 AM
Hello All, it's that time again, kick-starting the Hot Rod project. My one Turbo Foxbody buddy is bugging me to get this project started and move'n to completion...s o now is the time.
Glad to hear you've renewed your interest in the project.  Keep us in the loop with your progress!
Dwayne :)
oldeguy
Hello All, it's that time again, kick-starting the Hot Rod project. My one Turbo Foxbody buddy is bugging me to get this project started and move'n to completion...so now is the time.
oldeguy
Car still for sale...cold in Ohio now!
oldeguy
OK...Aug 2018 It's been a tough decision, but I'm never going to finish this rebuild of my Pinto. I have decided to sell my turbo pinto project. So, got all kinds of stuff for the build. If your interested let me know...440 949 9528 $5k for everything!
[/size][size=78%]1972 Pinto "Turbo" EFI runabout Kit Car...no rust! Never been is salted roads, purchased in CO in 1975, owned it ever since, always stored in a garage![/size]
Finish building my dream! A kick butt 2.3l turbo coupe EFI engine with a Tremic T5 WC transmission thru a Quicktime bellhousting, with an 8.8 posi differential with 3.73 gear ratio, running 275/50-15 street slicks on Weld wheel, big disc brakes (11" rotors) up front, Explorer discs on rear, Mild steel roll bar 6 point kit,  Recaro Mustang pace car seats. The car has the BOSS Pinto wheel spats (like the old Trans Am Firebird, louver back window, with Cougar tail lights. Car is Imron metallic black, custom hood scoop (I built from scratch) All of the body work was completed on the original build back in 1976 This is my dream. And it is in kit form! Got almost all the parts...you need to finish the kit.
Engine...Got two: 2.3l turbo coupe donor engine, this is an EFI engine. it was built, bored +0.020, crower rods, roller followers, capped main caps, and 60 pound injectors. Aluminum flywheel, new Ron Francis wiring harness set up for MAF ECU has a tune chip. New big front Mount intercollerMany more details...#2 is the 2.3l carb'ed engine...installed in the first build back in 1976...approx 55,000 miles.
Brand new Quicktime bell housing, stock turbo coupe one and aaa...stock 2.3 manual bell
Transmission...got three, the standard T5 from the turbo coupe, or a T5WC from a 5.0 mustang, both have aftermarket shifters, the third is a 2.0 4 speed with Bellhousing.
Differential...the stock pinto is in the car now, but have a Explorer 31 spline that has been narrowed to 57" inches the same as pinto width. It has disc brakes, 3.73 gears, and it's posi traction.
Wheel 4.5 wide x 15 fronts, 8 x 15 rear, Weld aluminium...no tires
Body...runabout means it's got a hatch, once I got the car to Ohio used a penetrating rust seal to the body, as anyone who lived thru the one year rust thru of cars back then knows...you could hear them rust! It's 72 A/C car from factory...tinted glass, A/C and heater box removed...still have it. Body is straight, painted in Imron 48 years ago, has a BOSS Pinto body kit, custom hood scoop molded into steel hood. 67 Cougar tail lights, lovered back window, sun roof, Mustang pace car seats, 10 inch steering wheel, back seat is removed, got a 6 point roll bar kit, new stock fuel tank. Radiator flushed and tested, Got extra grills, fiberglass bumper...
Brakes...11 inch Granada rotor for front with brackets to mount GM Metric rotors. Rear are the Explorer diccs, new master cylinder with proportioning valve.
oldeguy
WOW...July 2016! still have a Pinto "OverHaulen" project to complete...
other things eating into my time...347 dart block w/ TF 11R 205cc heads, 75mm Turbo, TH400, 92 notch FOX body...my 5th wheel RV...Sailing...garden...Oh...forgot about the work thing! too many things to do and not enought time.
oldeguy
well, getting to be the end of Aug 2015...the "Hot Rod" Pinto is still awaiting for me to start putting parts back on her so she can get back on the road!  :o
Don't feel bad, I've had one collecting dust for over 3 yrs now, can't tell what color it is now, lol..
oldeguy
well she is still collecting dust.... :-\
oldeguy
still sitting in the garage....waiting for someone to do something!
oldeguy
Quote from: Henrius on January 20, 2014, 05:19:28 PM
Wow, that custom hood rocks. Wish you were around my neck of the woods to fabricate body panels!
Thanks for the complement! let me tell you...that that was my third try for the look I wanted. and many hours of fabrication! someone on this sight is making some FRP body parts (not my hood)....do a search if your looking for spoilers, wheel spats??
Henrius
1973 Pinto Runabout with upgraded 2.0 liter & 4 speed, and factory sunroof. My first car, now restored, and better than it was when it rolled off the assembly line!
If it's not one thing it's another, always something to deter a project, lol..
oldeguy
well...Pinto still on hold! my 92 turbo notch fox body broke the transmission...need to fix this >:(
oldeguy
8 sept 2013...my pinto still has not built itself yet! she's waiting for me to get off my a#* and help her to finish!
PintoMaverick
Its taking me forever as well. Started working on it shortly after my son was born (he's 3 1/2 now) and in just the last couple months I finally got the turbo motor running in the car. I have another baby due in Feb so its time to get on the ball. So don't feel bad it happens to all of us lol.
1974 Pinto trunk model, 2000, 4 speed. 1971 Maverick Grabber, 4.6 DOHC 98 Cobra engine, 5speed, Mustang II front suspension, 4 link rear.
Glad I'm not the only one that takes forever to get a project done, already hearing the wife whining about the wagon not being finished, but yet I get a list of crap to do every day, LOL.. ::) :D
oldeguy
OK...just want to post...I still have the pinto, still in the same...I'll get aroundtuit some day....can't rush into a good project! LOL
Glad to hear you're ready to dig in. My '80 was sitting almost 2 years before I found the time to work on it.
oldeguy
Well...got all my wood cut, split and stacked. New to me wood burner installed. Now ready for Winter here on the North coast. The boat is on the hard.
Now, It's time to dig out the Pinto and get the project mov'en again.
review my past posts....man, it's been over a year since I've worked on the Pinto! :'(
oldeguy
well...the Pinto is still on the back burner. got the 347 in the AC Cobra, got my 331 92 all polished and up for sale, and now working on a 92 302 turbo mustang...re-enforcing the battle boxes, subframe and all new delrin bushings on the control arms....oh, and just launched the boat!
oldeguy
it's about time to start working on the pinto again...the boat put away, got 6 cords of wood cut, split and stacked...the stumps ground out. cut a hole in the roof for my triple wall stove pipe...i think I'm about ready....
oldeguy
Quote from: don33 on August 25, 2011, 06:20:20 PM
hey there oldeguy, bout ready to start on mine too. you bought that high dollar bell I see... my fuel cell came in last week and I just brought home my Miller 140 autoset welder.  now I'm ready...
hey don33...you'll love the wire feed machine. I got a lincoln sp?180c about a year ago...it's amazing on thin (under 0.125) sheet metal stuff, about ready to sell the old 225 buzz box.
yep...plan on doing some drag racing with the Pinto when completed...really want to keep my feet.
