Windshield
Date: 01/15/2022 09:31 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
1978 hatch back
Date: 11/29/2019 03:18 pm
Date: 12/09/2016 08:34 am
Wheel cap
Date: 04/25/2022 11:21 pm
Date: 02/10/2017 09:30 am
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 02/27/2017 10:10 pm
  • Online today: 2,562
  • Guests: 2051
  • Total: 2051
2.3 turbo swap
Started by oldeguy, January 29, 2011, 11:32:30 AM
Yes that's an aftermarket FPR not sure what brand.  The line should be ran to a vaccum source it hooked to the metal line coming off the side of the upper intake from the factory. the FP will be based off both vaccum and boost at and idle the FP will be lower and when it sees boost it should raise the FP 1-1. So if your running 15 psi of boost it should raise the FP 15 lbs.
Got anymore pics of what your working on? i see its got a larger throttle body since the throttle cables got the adapter for one!
I'm doing a 2.3T into a 78 bobcat! It outta be fun the Turbocoupe was fun and weighs almost double what the bobcat weighs.
oldeguy
new to all efi stuff so, going to asking a bunch of (dumb) questions, old school carb guy you know...
this looks like an after-market adjustable fuel regulator? It has a billet alum. body and a tube that connects to downstream of the TB. Does this hange the fuel pressure based on vacuum or boost conditions? see the picture attached...
at some point...2.3L EFI T3/4stageIII FMIC 55#inj eecla3 90mm MAF 65mm T/B 5 spd 8.8 w/ 3:73  11" rotors, GM Metric, explorer rear disc 205 55 14 fronts 225 50 15 rears subframe connectors w/ a 6 point roll bar
