Date: 02/18/2017 05:55 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 07/17/2018 09:22 pm
Windshield
Date: 01/15/2022 09:31 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Pinto Runabout wanted
Date: 06/05/2018 04:42 pm
Date: 05/03/2024 05:37 am
Pinto drive train
Date: 06/29/2018 08:32 am
Date: 07/11/2023 11:39 pm
  • Online today: 1,293
  • Guests: 1227
  • Total: 1227
2.3L cooling system problems
Started by stinsonj, January 27, 2011, 08:30:05 AM
stinsonj
Thanks for the tips guys!  Now it seems to be fluctuating between 230 and 190 degrees. It will rise to 230, then fall to 190, then rise to 230, and continue to do so until shut off.  When its rising to 230, there is no heat coming from the radiator, therefore no coolant is circulating.  The last time this happened, there was an air bubble in the cooling system, but i ran through the same process that remedied the problem last time and everything seemed to be fine, so maybe my thermostat is the culprit. I should also add that i have completely removed the thermostat before to make sure that everything else was working correctly (water pump, radiator, etc.) and the engine never warmed up which also makes me think its the thermostat (or a pesky air bubble that i cant seem to get out).  Ill try that water trick to clean out the carbon too, never heard of that before.
78txpony
I have had MANY brand new t-stats bad right out of the package.
-Rob Young
1997 H-D Sportster
Try running higher octane fuel that will help. Could be timing and also carbon buildup. Too rich or too lean on the carb could do it too I think. My 76 does it in the summer no matter what the timing is. I even did the water spray in the carb thing and tried ATF in the carb too which is supposed to clean the engine up real good on the inside as well. Nothing helped.
So I switched to premium fuel. Another issue  which is most likely in my opinion is probably all that ethanol in our gas these days.  The only fix for that is well, nothing. I dont know about other states but here in Missouri all gasoline under 91 octane has to have 10% ethanol in it. Some stations have ethanol in ALL their grades. Just have to ask the clerk at the gas station to know if they have any grades of gas that dont have any ethanol in them.
Too much timing or carbon build-up 0n the pistons. Spray water from a spray bottle down the carb while the engine is running should get the carbon gone. DON'T USE A WATER HOSE!!!! Spray bottle only.
The thermostat is the most likely culprit.  Should also check that the heater/intake water is circulating.  During warm up before the thermostat opens, the engine relies on this heater/carb water circulation system to even out the engine temperatures.  If a water line or valve is plugged, the thermostat may not heat up as quickly.  Probably the easiest way to check this is to feel the carb choke housing (or the small house coming off the thermostat housing) getting hot before the thermostat opens and heats up the large top radiator hose.
I would change thermostat.  Fred   :)
stinsonj
I have a 1975 2.3L that will get to about 230 degrees before the thermostat opens.  Once it opens, it will run at a constant 190-195.  I dont feel it is a problem with the thermostat itself, but im stumped. Im also having a slight "run on" issue.  The engine will run for about 1 to 2 seconds after the key is turned off.  Im guessing it might have something to do with the timing, but its running smooth so i havnt really messed with it too much.  Any ideas???
