1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 11/11/2019 04:49 pm
Date: 09/15/2019 08:30 pm
Date: 06/25/2021 12:59 am
Date: 12/26/2016 04:29 pm
Built 2.0
Date: 10/07/2018 05:27 pm
  • Online today: 1,044
  • Guests: 52
  • Total: 52
Trim Clips
Started by Stuwil, January 05, 2011, 08:00:30 AM
Stuwil
Bruce
no hurry here, i've got lots to do. just found a rust spot behind the rear seat that needs work.
Please call and I'll give all my info. I don't expect this free.  Your offer is ver generous
Thanks
Stu
Not saying that that nothing should be posted again, and didn't mean to get under your skin. Perhaps I could be mistaken or perhaps I have some odd ball trim. Please don't take it the wrong way.
lol, good point. I suppose 7/16 inch is quite large huh? should be 3/16th.
289Wagon
 Dave1987-
I'm sorry, I guess all the info I got from the FORD parts book were not correct.  And I will never post anything on here again.
BTW can you show me any emblem with a 7/16 inch PIN.
Rich
baflinn
Quote from: Stuwil on August 16, 2011, 10:33:38 AM
Bruce
the wagon requires 76 total. I want them all if you're willing to let'em go. I need, also, the one small piece of trim that bolts to the front fender. Would you have that too? Please call me
760
9470650
thanks Stu
Stu - I'll call you after Noon EST today to get your address. I can throw these into a mail pack and send them to you no charge. If you can wait I'll pull the rest off my 78 wagon this week and have more for you by next Monday. Something to think about. Talk later. - BruceF
Liquidating all Pinto related parts.
Current list can be found here: http://www.flickr.com/photos/bruceflinn/8007178278/in/photostream
The "Pinto" emblems use 1/8" side clips, I think the other size is 7/16"
Rich, which ones are you speaking of for the lower corners of the windshield? All the Pintos I have stripped parts from (including windshield bright work) have the lower corner "clips" molded to the trim, and screw into the A pillars using a sheet metal screw.
Then, on the 71-mid of 78 Pintos, there are the hold down tabs which go along the base of the windshield gasket from the outside, about 1.5" in length and .5 inches in width. There are five along the base of the windshield and screw into the cowl with small .5" sheet metal screws. I have not had any luck finding these tabs, but they are reusable and don't wear, bend or break. Just don't loose them! :)
The clips that hold the brightwork AROUND the windshield are metal and square. They clip onto the studs around the windshield frame and capture the outside edge of the underside of the windshield bright work. There are available from just about EVERY automotive fastener and clip supplier as they were used on dozens of Fords through the 80s.
289Wagon
 These are the numbers I have for the barrel nut/clip/cup etc. A lot of terms used for them.
Small = 378362-S
Medium = 375890-S
Large = 375480-S
I believe you will only need the sm.& the lg. I needed the med. for the 289V-8 emblem I'll be using. You may want to measure your pin dia.(s)
Scott Drake & Mac's has ( or did have) all the sizes. Also a lot of the Mustang sites have some of them, since they are pretty much universal.
I have #s for the other clips also. If you want them PM or E me. The ones for the windshield lower corners are hard to find.
Rich
wesales has discontinued the 2110 clip and has no crossover part. :( The search continues....
UPDATE: The autobody shop that I purchased the barrell clips from tracked down a box of 100 for me! It's coming from California, $10.71 for the box and then the cost of freight. We'll see!
Stuwil
Bruce
760
9470650
thanks Stu
I think I may have found a source!
I purchased some barrel clips (this company calls them tubular clips) from a local auto body shop a couple months ago. I found the packaging and it is called a "wee pak", basically a small quantity of an item they sell to consumers. Well I looked up "wee pak" online and found their website:
http://www.wesales.com/
Page 14, Part Number 2110 on the right side of the page.
I will be stopping by the same body shop to see if they have any in stock, if so, we're in luck! :D
carbomb
took all the moldings off my squire wagon and i think i only broke one or 2 clips on the whole thing. not putting any moldings back on so if you cant find any new ones mine are still pretty good shape i took them off with a dolly so they arnt brittle by any means
baflinn
Quote from: Stuwil on August 15, 2011, 09:19:56 AM
very interested
I found that mine were so brittle they would crumble with just the slightest touch
Price?
thanks Stu
Stu, you can have them for my cost to ship - how many do you need?
- BruceF
Those would be the ones we are looking for. I had three dozen of them from cars I pulled apart at the junk yard the past couple years, but even they are sun baked enough that they crack and split when installed. I wish I could find a supplier of new repro clips.
Stuwil
very interested
Price?
thanks Stu
Stuwil
thank you very much
I'm still in need
baflinn
I have all the clips I pulled from 2 wagons a 78 & 79 - will take some pics tonight and post a link for your referrence. - BruceF
Just an update on this, I found this thread via  :search: .
I ordered a packet of the AV11288 clips and they are not correct for wagon window molding along the side. They are actually more narrow than the original clips. I pulled off my trim hoping to use them today and it turned out negative! There were enough clips still intact on the car to reuse and hold the trim on with, just not completely!
Stuwil
up date
You guys are great and soooo helpful. I did contact Cliphouse, by phone, the lady I talked with was extremely nice, considerate. She tried to help but with out PN#'s there is little she could do. I'll be sending her samples. I need clips for all pieces of trim, windshield, side trim, door window riviets.   Everything. Today I get to paint. The car is nearly stripped----dash, motor, windshield, doors--yikes, this has turned into a major learning experience.
thanks for the suggestions
Lost Coz
Fred,
You are a Pinto part's Guru if there ever was one. Here is a link to the clip's I think he needs.
http://cliphouse.com/av11288.aspx
That site sure would have come in handy when I did the paint on the 73 wagon, as I removed all the dull molding and replaced it with some nice polished pieces I bought. I ended up fabricating clips from metal that worked with the molding, but the pieces in the link above would have made things a lot easier.
Beer's to you Fred!
"Pinto's are Cool!"
"Pintos are cool!"
1973 Pinto Wagon
1974 Pinto Wagon
1975 Pinto Wagon
74 Pinto Wagon for parts
Go to cliphouse.com front page go down left side until you see molding hardware there will be 5 pages with picture's and sizes.  Fred   :)
sedandelivery
I got the "push nuts" to put the emblems back on my car as they were broken when the previous owner put lettering on it to advertise his business. Anyway, I got them from EBAY. They have a lot of generic trim fasteners just measure the size you need and you might find it.
flash041
Post some pics and measurements of the clips you need.Ill look in some older body hardware books that I have.
Stuwil
Thanks for your time and effort and suggestion. The trim clips were so crystalized and
rusted they just crumbled. I'll keep looking
Hi Stu!
I just spent some time going through that online parts manual to see what I could find that would help you.  Unfortunately, I didn't see any part numbers for the trim clips, themselves.  All the mouldings are listed with the notation: All Mouldings Include Attaching Parts, which was probably designed to make it unneccessary to ever buy the clips separately.  At any rate, this is probably not an insurmountable problem.  The body shop who did the paint work on my '79 Lincoln Continental ran into a similar problem.  They ultimately got it all back together using Chrysler clips.  I would consult a reputable body shop - they should be able to match up something that will work on your wagon.  If they can't, then try a restoration specialist (White Post Restorations in White Post, VA is the only one I'm familiar with).  They won't be cheap, but they'll come up with something.  Best of luck!
Stuwil
Maybe this was a huge mistake but now I'm in it and need help. I've pulled all the trim off the 73 wagon for painting. Most of the trim clips were broken or I finished 'em off during the removal process. Regardless, I can't find the part numbers, or the parts. For some reason I can't make the on-line parts manual open. Scott says it works but not for me. Can someone provide the #'s----please
Thanks
Stu
