Interior Parts
Date: 08/07/2017 03:59 pm
1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 01/20/2018 07:51 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 01/19/2021 03:56 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
Date: 09/21/2018 11:35 am
Rear Bumper
Date: 07/26/2021 01:08 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
  • Total Topics: 16,272
  • Online today: 186
  • Guests: 139
  • Total: 139
My 1977 Runabout
Started by Hobbesga, December 11, 2010, 06:49:24 PM
I agree with Phil. I had to replace my radiator after I tossed a hammer in the garage & it went straight through it (non repairable). But when I replaced it I got a used one from a 74 Pinto & have had no problems with overheating at all. I would say just have the old one fixed. It will be cheaper if it can be repaired & will cool your car just fine.
i have a 76 with ac and the stock radiator is just fine
Hobbesga
Okay, so I haven't been on here in a bit. I had some serious trouble with my computer and have had to break down and buy a new one. Now that I'm back online, I have a question. I need help with replacing some parts. I'm about to have to buy a new radiator to go in the car. The one that's in it now has some problems and is probably repairable, but I think I'd prefer to just replace it like I've done with everything else...
Some of my research has indicated that there's a problem with the cooling capacity of the stock radiators. Has anyone else found this to be true? Should I consider upgrading to a larger radiator, or in your experience has the stock radiator provided sufficient cooling on the little 4 cylinder engine?
I painted my 78's engine compartment semi-gloss black with engine paint. It's holding up well, but the dirt IS visible when I don't keep up on the power plant cleanliness.
skunky56
I agree with S&H paint it white I left mine white , it stays clean and hides the dirt well. Really no kidding it does.
77 Starsky/Hutch 2.3 Turbo A4OD Sunroof
78 Wagon V6 C3
If i was going to paint it .I`d use gloss black,,, flat will get glossy when oil gets on it ...and it will look patchy,, Id leave it the white myself .
Hobbesga
Just wanted to show that there's some progress going on...
Hobbesga
So...
Today I carried on with cleaning and painting suspension components. And then my carburetor rebuild kit arrived and I managed to complete that task before it got too late. I just wanted to throw this little tid bit out there for anyone struggling with a question I found myself perplexed by...
The original tag that was on the top of the carb identifying what model was in the car was long gone. So, when I went to order the kit for the carb I was torn between which kit to order. A kit was suggested elsewhere in the threads that would be usable to rebuild any carb on any Pinto. While that suggestion was certainly good information, I did find stamped into the base of the carb, just above where it bolts onto the gasket and riser. The stamp was on the face of the base in small numbers but showed that mine was model #R7950. I already knew that the base model of the carb was listed as a Model 5200 VV, but that small set of numbers helped me get more information and determine (with some doubt still) that the information shown in my Chilton's repair manual for the carbs was incorrect. The Haynes manual information appears to list the carb correctly.
Of course, I haven't cranked the engine yet to be able to check out how it runs. I'll definitely let you guys know if I find out that I'm wrong about which manual has the more accurate information. Then again, my engine has been bored over so the correct settings may be off from what's shown in the books.
I hope that little bit of info helps someone else out. Once, I get finished with the carb and some of the other parts I'll post some new engine picks to show how it's all coming together.
Then I have a question for you guys. I'm getting ready to prep for repairing the engine bay and do a little painting. The engine compartment was originally painted the same white color as the rest of the car's exterior. I'm going to lean toward not going back with the white, but instead painting the engine compartment a flat (or semi-gloss) black color to help hide some of the dirt. Plus, since I'm intending on using the black rubberized undercoating on the bottom of the car (once again, instead of the white) I think it'll make the transition a little easier on the eyes. The other option is to continue the undercoating into the engine area... Any ideas or suggestions on this?
Hobbesga
Well, I just wanted to throw a little update out there. I've got the car back up on the trailer and blocked up. I've dropped the front suspension and rack and pinion. I've also pulled the rear end out from under the car and started pressure washing it all off. I still haven't gotten any of my most recent orders in the mail yet, but I'm hoping to be ready to start painting the underside with some rubberized undercoating by the end of the weekend. Once everything starts going back together I'll try and get some good pictures of it. All of the pressure washing in the world still hasn't cleaned up the tunnel though, so I'll be on my back scrubbing until it comes clean.
I've got some more looking around to do, but I need to find some donor material for the passenger side inner fender. I've already got a plan on fabbing up a new battery mount, but I'm not sure whether I want to try and find a panel to cut and weld in place, or if I'll have better luck just finding some material to work with and banging out my own replacement.
If you've got any experience with the rubberized undercoatings, or with repairing that inner panel, I'd like to hear from you guys.
Oh, and I know I mentioned the remade water neck in a previous post. If you look close at the second engine pic I posted above you can see a really good shot of it.
Uh, I also feel obligated to mention that I painted my exhaust manifold with some of that high temperature black paint. Which has to be cured by baking it for and hour or two at either 400 or 600 degrees in an oven. Now I know that the can clearly indicates that this should be done in an outside oven, but who has an extra oven outside for baking parts? So, when I informed the other residents in the house that it was Manifold Manicotti that was in the oven I got some very strange looks. If you decide to follow my lead on this one, can I suggest doing it on a day when you're at home alone and can open up some doors and windows. The paint itself didn't seem to be too bad, but some of the deposits inside of the manifold started to smoke and kind of pissed some people off. Not to mention that they weren't too happy with the timing covers hanging from the fireplace mantle to finish drying. Oh well, you can't make everybody happy all the time. I do want to get a picture posted though after the carb is rebuilt with all of it mounted together. The old style ford blue looks great with the black parts.
that is, without a doubt, the coolest engine hoist i have ever seen!
Looks beautiful!
I can't wait until I get the chance to pull the motor out of my 78 and paint it. I should have done it after my dad and I rebuilt the motor but I just didn't care about the car at that time in my life.
Hobbesga
Well, engine reassembly has begun. The block has been brought back from the machine shop... One of the auxillary shaft bearings was set incorrectly and had to be taken back to have them replaced. I posted in another thread about the kit I purchased, but I'll repeat it here...
I purchased an engine rebuild master kit from RPM Machines online, they're based out of Colorado. The kit cost me about $390 after shipping and handling. It included a complete gasket kit, a new Melling oil pump, sealed power seals and pistons (30 over), Durabond bearings (10 under), hydraulic lash adjusters, new camshaft, and a complete set of new timing components.
The block was tanked and I had the crank turned while it was out of the car (The crank was right on the border of still being within tolerances, so I opted to have it turned because, as deep as I was into the engine, I was hoping that it would be enough to help me get 200k miles out of this thing.) Other than having the chambers bored over, which might have been a pointless decision, but the machine shop offered to do it for $12.50 a hole and I couldn't pass up the chance to squeeze a little more out of the engine.
So now I've questionably used Plastikote Primer and Enamel paint to coat the engine. The primer and paint is rated to handle up to 500F. We'll see how well it holds up. I've included some pictures of the work after two coats. I'm trying to decide whether to throw a third coat on before I call it done. I've also bought some black Hi-Temp paint to coat the exhaust in.
I'm going to be continuing on for the next couple of days so I'll keep you guys posted.
nice car great progress
dont be afraid  to ask for parts if you need them many of us have gathered spare parts  even if we may not need them
as i have a wagon but have alot of sedan parts  just in case some one can use them.
Hobbesga
Yeah, the brake lines are getting replaced. I just needed to get it working enough to figure out how much of the brake system was intact. It worked long enough for me to trouble shoot most of the system. I've already got the new master cylinder installed and I'm waiting to put the lines on until after I get the replacement shocks. I also got a delivery in the mail today of some of the POR-15 paint that I was wanting to test out, I'm hoping the Chasis Black is going to bring back some life to some of the suspension parts that I've been cleaning up lately.
The gas tank went back together today after a good scraping... My advice is that if anyone else decides to cut into their tank to clean it... don't. The thin metal was a pain to weld. It wouldn't have necessarily been too bad to do, but even after some serious cleaning and repeated hits with the wire wheel and a flapper wheel the metal was still contaminated. Let's just say it made for some interesting work.
The fill line going into the tank had also picked up some rust. Turns out that the 2-1/4" line was matched up well by some old exhaust tubing that was laying around. Removed the rusted section and replaced it with that.
Also managed to fix my old water neck, was too cheap to buy a new one and the ones in the junkyard were almost as bad as mine. I'll have to take a picture of it before I reinstall it. Cut off the neck and replaced it with a piece of stainless pipe. It's kind of cool looking and weighs more than twice what the old one did.
The big excitement today came when Fed-Ex showed up. I thought my parts had surely arrived. I got excited. The truck went into reverse and backed up... Despair and despondency washed over me. The truck pulled forward again and the drive called out my name. Oh boy, oh boy, oh boy, my parts! No. He handed me a small envelope and left me walking on my lower lip all the way into the house. Maybe Monday...
Welcome to the odd ball option club. Thats a keeper. My '80 has a black/gold theme that made it worth keeping.
After reading your posts I would definitely replace the front & rear rubber brake lines. 20 years of sitting has them swelled closed. That's why fluid won't go through them easily. They are not safe to drive on & the fronts are cheap. The rear is a bit pricey but you will never need to do it again.
skunky56
Nice find I think keeping it is the best option, I myself have a 77 S&H white/red
mine has the roll back sunroof however no A/C. Like the others said you do have a rare find.
Congrads.man on your find
Paul
78 Wagon V6 C3
Hobbesga
Well, it's been a minute since I posted so I figured an update was in order...
The engine has been completely torn down. I'm glad I did it. Overall it appears to be in good shape, but the hydraulic lifters had frozen up and weren't moving on their springs very well, not to mention that the water jacket was corroded up pretty badly. I'm expecting the rebuild kit that I ordered to arrive either tomorrow or the first of the week at the latest. If I'm happy with the kit once I've got it in my hands I'll post the link where I bought it, in case anyone else would even consider rebuilding the little 4 banger. I've made some attempts to track down various parts for the car that haven't met with much success. Come to find out, a nearby automotive garage runs a racing team, which turns pintos into drag cars. In other words, they have bought up every single Pinto within a 100 mile radius for parts cars and then scrapped all the pieces after stripping them down.
Also, I finally decided that since I was going to be doing all of this work I needed to deal with the gas tank. I dropped it out from under the car and cut off the top half with a small grinder with a cutting wheel on it. You wouldn't believe the amount of sludge I've removed from the tank. While I was cleaning it up today I also discovered some small holes in the top of the tank. They're all above the level of the filler neck, so chances are I wouldn't have noticed the tank leaking if I'd continued to use it, but the sludge in the bottom would have probably clogged my little inline filter I added rather quickly. I'll be trying to clean up the filler neck and weld a new end on that while I'm working on it this weekend as well. It also appears that the tank could use some rubber padding between it and the bottom of the rear floor. I found some areas under there that look like it rubs pretty good when the cars going down the road.
After the block comes back from the machine shop I'll probably post a couple of pics showing it in it's fresh and clean state.
Until then...
A fellow has to be careful using those old "hind diggers". Old worn hoses and weapy boom cylinders.
I've done it (lifting stuff) with all sized hoes & excacators. Always make sure the person near what is being lifted is clear that no body parts get near pinch points etc.
(track hoe operator with about 25 years on those alone)
Hobbesga
If you live in the country, like I do, then you would probably think it would be easy to find an engine hoist to borrow. Well, I didn't have any luck finding one, and I couldn't move the car over underneath my usual oak tree. So I asked my dad if he had a minute to give me a hand with it. Turns out he had an engine hoist all along, I just didn't recognize it for what it was.
And so after a few minutes here it is...
Now it starts for real...
Cheeseliner
75 Pinto Hatchback Runabout. 2.3 EFI Turbo Charged Pinto with C4 and 8 inch 4.11 locker, Front mount IC, NOS, Walbro/T-bars/ Drag Stars
Well, I'm glad to hear your insanity was due to a fever and that you're now feeling better! :lol:   Would have really hated seeing that car parted out!
Hobbesga
Well, after laying around in a puddle of my own juices for the last couple of days, I realized that my considering parting out the car was just the result of my fevered brain. So even though I still have a mild fever and my sinuses feel like they're packed full of wheel bearing grease I decided to spend a couple of hours working on the car today.
After a couple of minutes standing there in a daze I realized that I had absolutely nowhere to put any of the parts I was trying to pull off so I managed to build myself a small storage space out of old scrap lumber I had around...
If you're a carpenter, or just have any carpentry skills... then just keep any comments to yourself. I know it's ugly, but I did build it out of scrap while running a fever so it's good enough for me.
I've actually been taking quite a few pictures during the disassembly, but I don't think I'll be posting many of them unless someone needs to see how something is routed for their own project.
After getting the little shed built, I only had the energy left to remove the radiator...
I'd like to point out here that the shop manual lists the steps in removal as
1. Drain the cooling system
2. Remove the upper and lower radiator hoses
3. Detach the two ATF cooler lines from the bottom of the radiator
4. Undo and remove the bolts securing the radiator to the front panel
5. The radiator may now be lifted upwards and away from the engine
Ha! Yeah, that's basically it, but what should have taken less than 15 minutes if I had some help took me more like 45 minutes by myself. The fan shroud was a total pain in my a$$. If I had just had someone else there to help me get the drain cock and bottom radiator hose connection up past the bottom of the shroud it would have popped right out. Instead I spent a long time trying to finesse it out and finally ended up cracking the old plastic shroud. I don't know what was going on, but I've removed and replaced several radiators and never had this much trouble before.
I then broke the A/C compressor loose from the mounting bracket and laid it over to one side and started working on removing the power steering pump. Hopefully, I continue to feel better over the next few days and be able to get back out there.
I can't believe that I worked on the car in such bad weather for several days and got sick just as the weather got better. I've wasted a couple of perfect days to work on the thing laying on the couch. (There was a long sigh involved in typing that out.)
If it weren't a Starsky & Hutch car, parting it out would be a viable option (although it looks to be in too decent shape to even consider that).  I don't think you really want to part it out - your car is relatively rare.  Hang in there and you'll have a car you can be proud of when you're finished.  If not, at least offer it up "as is" here and you'll probably find some takers.
Hobbesga
Well, apparently the water pump is shot. I can't say I didn't expect it. Looks like I'll be replacing the belts (including the timing) and the pump. I'll probably end up replacing several of the hoses while I've got it snatched apart. I think I may also have a leaky heater core, but honestly, I can't tell for sure right now. So, anyone think of anything I should be looking at once I have the front side of the engine stripped down?
Well, here's an update as of about 8p tonight, the engine sounds like it just spun a bearing. I have a very long list of explectives that I've been using for the last few minutes. Some of which I may have even been the first to ever utter. So, I'm definitely snatching out the engine starting tomorrow. I've got my camera on charge tonight. Not that anyone's noticed yet, but I've just stolen all of the sandwich baggies out of the pantry. Since my shop manuals haven't arrived yet here's my gameplan for you guys to critique... hopefully if I've forgotten anything you'll be able to stop me before I snatch the engine out with the parts still attached.
So the way I see it is this...
1. Battery and cables unhooked
2. Fuel lines and drain tank
3. Drain radiator and unhook coolant lines
4. Radiator removal
5. Exhaust at headers
6. Wiring from the distributor
7. Gas Pedal linkage
8. Driveshaft from tranny
9. Shifter from the transmission tunnel
10. Speedometer cable
11. Motor mounts
and snatch???
Oh... maybe the power steering too...
Any opinions on the best order of removal for the radiator... Will it come out with the fan still attached or do I have to take off the belts and the fan before I pull it out?
Well, it looks like the engine compartment is going to get cleaned up and painted after all... I'm starting to wonder how much I can part the car out for...
Cheeseliner
Looking good. Like you found out, the C3 tranny as 13 bolts on the pan. The C4 has 11. Also on the C3 the modulator faces towards the passengers side door. I just went thru these issues on mine. Good luck with it.
Sounds like good progress! Glad to hear you didn't end up with transmission troubles like I did with my 73 wagon's C4!
For carpet, check out Stock Interiors at http://www.stockinteriors.com/ and order some carpet samples of their different shades of red plush cut pile to get a good idea of what color is closest to your factory carpet.
If you break any of the FORD letters, let me know, I have a few sets in storage.
Tiny eyeglass screwdrivers, The Flat head on and carefully pry them up. little by little at each end. thats how I got the Mercury ones off my bobcat. it worked well and didnt ruin the letters, or the little things that Hold them in place.
Hobbesga
Yes, you're right... it's Type-F and I returned the other when I also returned the wrong gasket. The right gasket, filter, and Type-F fluid all came home with me and went on and in the car... as well as all over everything else in the vicinity and my hair.
I've been on here tonight reading through as many old posts as I can just trying to absorb as much information as I can from the Project board. I'm hoping that reading everyone else's struggles will help me pinpoint some of my own problems before I suffer through the guess and test method on my own.
I want to get started on the body and the interior so bad that I can taste it, but I don't want to move anything else forward until I can make a good driver out of this car. I've already started making some mock-ups for the new radio installation. I'm trying to keep the original radio in the car and work up some ways to mount a newer radio and some decent speakers without actually cutting into anything in the interior. If I get the car going before the end of the month I'm going to order some new carpet so I'll have something to color match. I'm thinking about making some kicker boxes to mount in the floor, I'll try and match the carpet to wrap the boxes so it's not glaringly obvious that the boxes don't belong in the car. Seeing as how most shops wrap their speaker boxes in either black or gray, I think that the red color will make the boxes look truly custom without detracting from the origianl feel of the interior. I haven't decided where exactly I want to mount the stereo yet, but I'm hoping to score one with a remote so I can stick it out of the way.
At this point having a pipe dream removed from the actual day to day wrenching is what's keeping me moving forward. Especially when I'm doing everything I can to not pull the engine out of the car, while I know that even if I don't do it now, I'll want to before it's all said and done.
Does anyone have any tips for pulling off the F O R D on the front lip of the hood? I'm going to have to take them off to do some sanding and painting, but I'd hate to break one of the letters. I'm imagining it's just hold your breath and pry gently, but hey if anyone has it down to a science I'd like to hear about it.
Check the dip stick on the transmission, it should tell you what type of fluid it takes.  If your tranmission is a C3 then it should take type F fluid.  Not sure what the dextron will do to it.  Nice progress so far!
Hobbesga
Transmission pan went back on with the correct filter and gasket. I will say that the gasket I originally got from AutoZone was a cork style gasket (which I personally would have preferred, other people seem to shy away from those though), the gasket I finally got from Advance Auto Parts was a rubber gasket (I would have been alot happier about that if they hadn't wadded the gasket into a ball before cramming it into a small box).
I spent part of the day today cleaning and out the metal fuel lines and running new rubber sections. On this particular car the lines are 5/16" on the send and 1/4" on the return. I installed a large inline filter just outside of the fuel tank to catch any residual particles that I didn't get cleaned out.
I also replaced the battery cables with some new ones that I made out of an old set of heavy duty jumper cables. I've seen several people mention the deterioration of the passenger side fender well from what appears to be a battery acid leak. Does anyone have any helpful insight on the best way of dealing with this? The rust appears to be just starting to make a hole through the fender and hasn't yet done any substantial damage. I'm leaning towards hitting it with a sand blaster to clean off the rust and painting over it with some rust preventative paint. Any recommendations on paint type, or a better way of dealing with this?
I did eventually locate a set of tires for the car (Maxxis MA-1 P175/80R13), a set of 5 ended up costing me about $370 mounted and balanced. Considering I was originally quoted $442.24 for the same tires, I feel good about the deal.
Just as it was starting to rain today I fired the car up for the second time. It's still running rough, but I'm going to re-gap the spark plugs in the morning and start checking to make sure all of the cylinders are firing. After that I'll be running it down the road tomorrow for it's first test drive. I'll let you guys know tomorrow if it explodes in a fiery ball or just locks up tight and refuses to move. Otherwise I'll make a list of things to fix and start turning wrenches again.
As of right now I'm at a grand total of $969.22 into the car. So far the tires have cost more than the car so, if nothing else, I'll have a really nice set of tires to put on a trailer.
