Date: 11/05/2016 09:03 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Rear Bumper
Date: 07/26/2021 01:08 pm
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
postal pinto
Date: 06/03/2020 09:31 am
Bumper Guards
Date: 03/28/2017 09:27 pm
Date: 09/15/2019 12:38 pm
Date: 05/18/2020 10:22 pm
Date: 04/06/2017 12:13 am
  • Online today: 2,773
  • Users: 1
  • Guests: 107
  • Total: 108
2.3 cyl head # 2
Started by RapidRichy, December 06, 2010, 07:45:30 AM
The 91 mustang I pulled my roller cam and followers from was a dual plug head.
I'm not entirely sure of the valve stem diameter as my cousin assembled the head and purchased parts for me, however the roller rockers/followers DO fit well on them without excessive movement.
RapidRichy
Thanks gents for the info. Sorry for not replying sooner. I'v been runing around latly like chickrn with his head cut off. Thanks agine
I have not tried it, but from what I have read, it is a popular swap for improved reliability.  It seems like the dual plug heads have the roller cams.  Since there are always exceptions, you would need to pull the valve cover to make sure.  Some where in the mid-90's, Ford went to a smaller 7mm diameter valve stem.  I do not believe the roller rockers for the 7mm valves will fit over the larger valve stems of the earlier engines.
RapidRichy
Can the cam & roller follwers be used on 70-80 2.3 cyl. heads thanks Richy
I have a 93 Mustang and a 94 Ranger that have. Had a 89 Ranger that did not have.  Fred
They did. Not sure exactly what years but I've heard that early 90's rangers have roller setups, and I know I pulled my setup from a 91 mustang.
RapidRichy
 Did Ford ever make roller fallowers for the 2.3 thanks Richy
