Date: 04/28/2018 04:12 pm
Date: 10/27/2018 03:30 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 03/06/2017 01:24 am
Date: 07/01/2019 03:17 pm
V8 rear end
Date: 04/12/2018 10:57 am
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 02/28/2018 09:33 am
Date: 10/05/2017 02:26 pm
  • Online today: 899
  • Guests: 551
  • Total: 551
Difference in early spindles vs. late spindles?
Started by ahawes, November 15, 2010, 07:22:06 PM
Lost Coz
The 2 inch drop spindles won't work on the early suspension. I bought a pair for my 74 and when I redid the suspension in the 73 found that they were totally different. The brake caliper mounts are different and the drop spindles were about 3/4 inch higher (from ball joint mount to ball joint mount). There was no way to use them on the 73 unless I wanted to do a bunch of modification to the entire front end. The easiest way to lower the early Pinto is to cut the springs. I ended up cutting a turn and a 1/4 to get the 2 inch drop in the 73. It rides a little stiffer but sure looks good.  I am still going to use the 2 inch drop spindles on the 74 when I get into it, as I plan on putting a 302 in it and don't want to cut the springs.
"Pintos are cool!"
1973 Pinto Wagon
1974 Pinto Wagon
1975 Pinto Wagon
74 Pinto Wagon for parts
ahawes
I've got a '71 that I'd love to get some 2" drop spindles onto but haven't got any later model spindles to compare mine with. I've noticed that some places say their spindles are good for 71-80 Pintos whereas other places say 74-80. Are they all the same or not?
Car has disc fronts if that matters in the slightest. Thanks in advance.
Adam
71 Runabout
