Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
looking for parts
Date: 06/19/2020 02:32 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Windshield
Date: 01/15/2022 09:31 pm
Date: 03/06/2017 01:19 am
Rare parts for sale
Date: 09/10/2018 08:38 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
  • Online today: 367
  • Users: 1
  • Guests: 171
  • Total: 172
  • rob289c
Blower Motor lead wire
Started by STLpintoWGNguy76, October 26, 2010, 09:48:34 AM
I just did the one in my '80 yesterday. The wires that come back through the hole connect to plugs in the wiring harness. At least 1 does. I think the other plugs to the resistor on the heater core. I just did it from memory, I never paid too much attention.
Quote from: STLpintoWGNguy76 on October 26, 2010, 09:48:34 AM
I had to replace the heater core and blower motor in my 1980 Pinto Wagon. The lead wire looped back through the firewall and was not connected to anything inside the vehicle. Is the wire supposed to loop back through the same hole that the blower motor sits in on the firewall, and what does it connect too?
I can answer half your question - I have a '76 wagon that is in mid restoration; part of the restoration was to completely dismantle, clean, and restore the heater box and components.
The answer about the wires is YES, they do loop back through the same hole; if you look at the motor mount plate, you will see a small indentation in the plate, and that is where the wires pass through. Now, on the rest of the question - not sure, because I need to reconnect mine as well and don't have a clear answer on where they go. If I figure this out soon (and I should, since the box will probably go back in within two weeks), I will let you know.
I believe it's the ground for the motor since the motor is isolated from the car by the insulation between the blower body and the firewall.
STLpintoWGNguy76
