Date: 03/05/2017 03:27 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Date: 01/24/2021 07:54 pm
Date: 07/24/2018 03:17 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
1976-1980 A/C condensor
Date: 09/21/2020 10:43 pm
Date: 10/01/2020 02:00 pm
Date: 05/24/2020 08:19 am
1977 Cruiser
Date: 06/29/2019 06:28 am
  • Online today: 367
  • Guests: 239
  • Total: 239
Blower Motor lead wire
Started by STLpintoWGNguy76, October 26, 2010, 09:48:34 AM
I just did the one in my '80 yesterday. The wires that come back through the hole connect to plugs in the wiring harness. At least 1 does. I think the other plugs to the resistor on the heater core. I just did it from memory, I never paid too much attention.
Quote from: STLpintoWGNguy76 on October 26, 2010, 09:48:34 AM
I had to replace the heater core and blower motor in my 1980 Pinto Wagon. The lead wire looped back through the firewall and was not connected to anything inside the vehicle. Is the wire supposed to loop back through the same hole that the blower motor sits in on the firewall, and what does it connect too?
I can answer half your question - I have a '76 wagon that is in mid restoration; part of the restoration was to completely dismantle, clean, and restore the heater box and components.
The answer about the wires is YES, they do loop back through the same hole; if you look at the motor mount plate, you will see a small indentation in the plate, and that is where the wires pass through. Now, on the rest of the question - not sure, because I need to reconnect mine as well and don't have a clear answer on where they go. If I figure this out soon (and I should, since the box will probably go back in within two weeks), I will let you know.
I believe it's the ground for the motor since the motor is isolated from the car by the insulation between the blower body and the firewall.
STLpintoWGNguy76
