Pinto Watch
Date: 06/22/2019 07:12 pm
postal pinto
Date: 06/03/2020 09:31 am
Date: 12/24/2016 04:13 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Date: 04/24/2018 11:45 am
SVO SWAP
Date: 03/15/2018 03:12 am
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 06/05/2018 09:13 pm
  • Online today: 152
  • Guests: 128
  • Total: 128
Fuel Guage
Started by Fair 73, October 22, 2010, 08:57:10 PM
Fair 73
 Yes the guage reads empty.
Thank you
72pair
What does the gauge read? If below empty, I'd suspect a bad float. The sending unit is fairly easy to remove just make sure the fuel level is low so you don't get drenched with gas. Sometimes varnish will coat the rheostat and it will not function also. A solvent cleaning will help that. I can't remember the wiring exactly for the 73, but i think one terminal is power and the other is ground. Connect an ohmmeter and see if the values change as you move the float arm. JT
Fair 73
 Hello
  My fuel guage is not working can anyone tell me how to check it. Is it either the guage or sending unit or is there something else it could be?
Thanks
