99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
Date: 08/01/2018 01:17 pm
Bell housing
Date: 08/23/2017 05:41 am
Date: 03/06/2017 01:19 am
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 06/18/2018 03:47 pm
Date: 03/06/2019 06:40 pm
Date: 01/28/2021 03:49 pm
74 pinto
Date: 09/11/2016 06:32 pm
  • Online today: 126
  • Guests: 144
  • Total: 144
SUBFRAME CONNECTORS
Started by vonkysmeed, October 11, 2010, 02:37:20 PM
vonkysmeed
got a message back saying that he no longer made the kit for the pinto, but did make a generic kit that may fit.
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
I'm going to attempt to do the ones that I sketched in a previous link after the snow falls down.
Bad news. I got a reply from them. They don't sell that any more. The person said they had a universal kit, and suggested calling them to discuss plans for the car.
I don't like universal kits.
Oh,well. Back to plan a.
vonkysmeed
Quote from: russosborne on October 18, 2010, 06:18:53 PM
Thanks for that link.
However, if you look closely, you will see that it isn't for the subrame connectors, but to actually add a rear subframe to the Pinto that connects to the front subframe. And in the options there is a part number for 71-80 Pinto's. Yay!
But that is something I would like to do to mine to add a lot of strength to the rear end. Would make it a full frame. Might not be much harder than adding the home made subframes I was planning on. Then again, anything I do turns into a fiasco. :-(
I sent a question through their website asking about specific instructions for installing these. I will let you guys know what they respond with.
I did see that, Also sent several questions with no answers yet.  Also looking at my car, the rear subframe is almost non existant because it is a 73.  Was planning on beefing it up and may take their system and modify from there.
73 Pinto Runabout
6 point cage
RSM
Those look like they might be connectors for the subframe kits they have. I bought a pair for a Mustang II hoping they would fit but they don't. If I remember correctly they would attach ok in the front 1/2 but the rear 1/2 wouldnt. I think was just a matter of cutting some of the material away and welding it in. I have the car in storage right now but if I get a chance I'll check and see exactly what had to be done to use the Mustang II connectors.
vonkysmeed
https://www.secureway1.com/alston/index.php?productID=183
found someone who actually makes one for the Pinto, but looks to be from the frame all the way back.  Not sure where it goes, but not a bad idea to keep in mind.
73 Pinto Runabout
6 point cage
vonkysmeed
Thanks,
When I do mine, I will also document for everyone to see.
Right now it looks like I will be using 2" square tubing with 1/8" wall unless I can find channel made up cheaply similar to the other one.
73 Pinto Runabout
6 point cage
vonkysmeed
after posting, I continued to dig about the connectors and found a few useful links
http://www.fordpinto.com/index.php/topic,879.msg4990.html#msg4990
http://www.fordpinto.com/index.php/topic,15258.msg99215.html#msg99215
http://www.fordpinto.com/index.php/topic,11751.0.html
after a few quick looks, did not see too much on size of tubing to use, but I will keep looking.
73 Pinto Runabout
6 point cage
vonkysmeed
Getting ready for a busy winter and need to know a recommended size of tubing to use for subframe connectors.  I will most likely try to also incorporate my 6 point roll bar since I think it is providing most of the rigidity for the car right now.  I believe it is 2 inches wide, but want to know if it is overkill to go with 2 Inch tall as well.
Any pictures would also be appreciated.  I have seen a few, but do not remember where.
73 Pinto Runabout
6 point cage
