1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Date: 07/17/2018 09:49 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
FREE PARTS!!
Date: 01/10/2017 02:38 pm
  • Online today: 548
  • Guests: 406
  • Total: 406
Removing steering column key tumblers?
Started by popbumper, October 09, 2010, 04:55:10 PM
youll have to punch the Ignition out if you dont have a key, IE break the lock cylinder with a Screwdriver, messy but works.
rctinker
Can you get the ignition out with out the key?
Thanks, Tink
1977 Crusin Wagon when I was 16
Thanks guys, done! This steering column is gonna be cherry!
The pin will be able to move in with the Key in the Ignition and turned to the ACC position
Been awhile but try going to acc position then push pin.  Fred   :)
Hey Fred:
  Thanks, thought so. With the tumblers in place, there's a pin in there. I tried to press it in but it won't depress. Does the key need to be in the tumbler to press the pin in? Hmmm...
Chris see pin hole lower side.  Fred   :)
Hi all:
  Sure this has been covered before, but I do not recall how this is done. I am in mid "column restoration", needing to restore/repaint the various parts of the column that are "dash color", and would very much like to pull the tumblers and replace them with a fresh set/new key. It is not obvious how this is accomplished - IIRC, there's supposed to be a hole / pin somewhere where you push in a paper clip or some such thing to release them?
  Thanks for the help.
