Front sump oil pan
Date: 01/02/2017 06:54 pm
Date: 10/24/2019 01:43 pm
Date: 03/05/2017 03:27 pm
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 01/23/2017 07:41 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 02/16/2019 10:46 am
Date: 04/06/2017 12:13 am
  • Online today: 1,292
  • Users: 1
  • Guests: 356
  • Total: 357
  • warhead2
manual transmission
Started by rjernee, September 09, 2010, 09:31:07 AM
Still in need of the kit? I can check with Transtar locally to see what their kit includes.
rjernee
hello , sorry ive been away for awhile. the bearing im looking for is a caged pocket bearing that goes inside the transmission.  it would be the rar input shaft bearing. i ordered a kit from napa but it isnt complete and im being told that a kull rebuild kit isnt available . thank you guys for responding!
I use a caged needle bearing on my 78's 2.3
Quote from: Srt on September 10, 2010, 12:40:02 AM
parts for those were hard to find even in'71/'72.  if you are going to carry on with the entire rebuild then don't overlook the needle bearings that the countershaft  rides in.  and new synchro rings too. (assuming you can find them)  check the teeth on all the gears that mesh with the synchros.  wear here will cause problems too.
Joe, IIRC wasn't the original pilot bearing a caged needle bearing setup?or was it a bushing?  you might want to try Dorman Products for the pilot bearing/bushing
Steve,
All good points, and yes on the 2.0l liter EAO motors, the Pilot bearing is a caged needle bearing. Not sure about the Lima 2.3l..
  Pintosopher , just a few needles short of a true Bearing!
Richard,
Are you trying to find the Pilot bearing (Crankshaft end) or the Input shaft bearing that goes behind the Bearing retainer and T/O bearing sleeve?
The pilot bearing is almost always separate from the Clutch kit, but the input shaft bearing should be included in the trans rebuild kit.
EP73Pinto
The pilot bearing is part of the clutch assy. Try rockauto.com.
 try oreilly auto parts that's where I get mine from.
rjernee
im currently attempting to rebuild a manual transmission for my pinto. parts however are hard to find. the bearing and seal kit that i got from napa only had 2 bearings and 2 seals . the part that i need the most is the pilot bearing . im wondering if anyone else out there has done a manual trans rebuild , and has any luck getting parts , or would have part numbers.. thank you! Richard , college place wa .
