1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
KYB shocks
Date: 02/08/2017 07:09 pm
Date: 06/12/2018 08:18 pm
Date: 09/17/2024 12:35 pm
Date: 11/14/2019 04:02 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 08/06/2021 02:23 pm
Date: 03/25/2019 09:02 pm
Date: 10/24/2018 07:41 am
  • Online today: 1,044
  • Guests: 56
  • Total: 56
Radiator for V-8?
Started by randyg, September 05, 2010, 09:36:17 PM
dheil78
I'm running a Jegs Aluminum Ford Radiator.  I think i measures 19x22 and is a 1" wide two core.  I have a 347 Stroker that makes 478 that it sits in front of.  I put a 12" fan on it.  Its drag only though.
Here are a couple shots of what Im planning to use in mine.
The outlets are on the correct side for Ford & Ill make the shroud a little larger to hit the top & bottom of the radiator.
I picked up a Griffen aluminum 2 core street rod radiator for mine. Ebay had it for $119 bucks new & its supposed to cool a 450 HP SBF in an enclosed engine bay. It measures 22"x19"x3" thick & I am going to use a factory GM Cavalier/Ecotec shrouded fan to cool it. Ill go bigger if I need to but I think Ill be fine with a 350 HP 302.
randyg
My small block 71 runs really hot in a short time. When I first built it I used a new 65 Mustang radiator with an electric fan in front. I need to know what other V-8 Pintos are running.
Thanks
Randy
Just a 289......
