1972 pinto grill
Date: 02/27/2018 12:13 am
Date: 06/24/2020 06:12 am
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 08/26/2018 06:23 pm
Date: 08/13/2017 02:01 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
  • Online today: 587
  • Guests: 242
  • Total: 242
How do you know if you have solid or hydraulic lifters & how do you adjust them?
Started by Pinto5.0, September 03, 2010, 12:42:59 AM
Quote from: Bigtimmay on September 05, 2010, 12:25:59 PM
Heres the part number for the felpro on and a picture its only 7.99 at my local part store.
http://www.oreillyauto.com/site/pi/detail.oap?line=FEL0&item=TCS45108
That will help a bunch. Im gonna get the gaskets next week & if the seal isnt included now I know the part number at least.
Quote from: dave1987 on September 04, 2010, 02:46:04 PM
That's the one. My cousin forgot to install it on my motor when he rebuilt it and we took it for the first drive ending with an engine compartment COVERED and I mean COVERED in oil! lol
Thats exactly what I want to avoid. I just cant find the seal listed in the Fel-Pro gasket set. I hope it's in there.
Quote from: Bigtimmay on September 03, 2010, 10:00:50 AM
You should be able to tell the difference in the 2 lifters just by looking at them one will be a solid sleeve with a screw in stud and the other will be 2 piece and have oil holes in the side and a groove to keep them pumped up.  As for adjustability of the lifters im pretty sure only solids can be adjusted other then shimming them.
So since the lifters on the race head have adjusters & locknuts they are solid lifters. I google imaged em & that helped.
Quote from: Bigtimmay on September 03, 2010, 10:00:50 AMAn as for cam seal it goes in the front  tower around the cam to keep oil from leaking out of the block.
Thats the seal behind the gear then? Thats what I thought but I didnt want to forget anything.
Anyone know the lash settings for Esslinger cams?
I have a shaved & ported head that I want to put on my 2300 when I pull the turbo off. It's got a big Esslinger cam & all the supporting parts including large valves to run on a mini-stock. I have never dug into a 2300 & have no clue how to tell if I have solid or hydraulic lifters in the '79 engine & no idea how to adjust them. I assume what is called a lifter is the adjuster that the follower rides on but I'm clueless. Also what is a cam seal?? I was told it's the only thing the head needs but again I have no clue what it is.
