TWM Intake
Date: 08/15/2018 08:20 pm
72 pinto
Date: 06/23/2016 12:40 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
TWM Intake
Date: 09/10/2018 10:41 pm
  • Online today: 134
  • Guests: 124
  • Total: 124
C4 Rebuild - Tips please!
Started by dave1987, August 27, 2010, 12:58:33 AM
I have snap ring pliers, but not the hub spring compressor or bushing drivers, no tool rental places here have them either. :( Can it be done with other tools?
I hope to start this on Tuesday.
72pair
Luckily the c-4 is relatively simple. Clean the outside well before you disassemble. The internal parts will usually just wash clean with a solvent or spray cleaner. Keep that wire brush away from any seal surfaces. I like to soak the clutches in ATF. If you can find some transgel, it works great for lubing the lip seals and thrust washers. It also helps hold the washers in place. I hope you have the necessary snap ring pliers, bushing drivers, hub spring compresser, etc. Mainly be sure everything is clean and lubed well. Good luck. JT
Any advice or tips for rebuilding a 1973 C4? I've got the kit in at Schucks/O'Reilly's Autoparts and picking it up tomorrow, has everything in it, including the bands (Pioneer brand, 1 year warranty).
Looking for any info on things I should watch out for, ensure is really clean, test before reassembly or pay special attention to during reassembly. From the reading I have done about C4 rebuilding over the past few months, it seems pretty straight forward, even a few videos on youtube about using an air compressor to check valve operation, which I will be able to do at my parent's house.
One question I would love to know off the bat, how many cans of what type of areosol cleaner should I get for this project? Carb or brake cleaner, four or five cans? Should I use a fine wire brush or a toothbrush for cleaning parts?
