Date: 10/11/2019 11:13 am
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
6.6.75 carrier
Date: 02/14/2018 06:47 am
1976 pinto for sale
Date: 01/12/2017 02:08 pm
Date: 05/28/2017 03:20 pm
Date: 02/18/2017 04:47 pm
Date: 05/13/2021 05:33 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Windshield
Date: 01/15/2022 09:31 pm
  • Online today: 344
  • Guests: 327
  • Total: 327
Body Drain Hole Fix?
Started by Jefferoni, August 23, 2010, 08:47:24 AM
nothingtodo
yup, remove fenders and you can clean that area out good then.
Might want to put some towels down on the floor next to the fresh air vents. If the water level gets high enough or you spray into the ducts it will flow into the interior and soak the floors.
Jefferoni
Thanks, Dave.  I'll try taking the fenders off this weekend and see how that goes.  Hopefully, with the fender off I can then use a powerwasher to blow down the drain and get to the gunk in there!  Thanks for the advice -- much appreciated!  Jeff
I remove the fenders to clean them out on my 73 and 78. It doesn't have to come off all the way either, they move out of the way quite a bit if you can undo the bolts under the hood along the engine compartment, and then the one behind the upper door hinge and the one under the lower door hinge in the rocker panel.
Jefferoni
Just Recently purchased 1979 Runabout with 12,000 original miles (pics posted in photo area of this site). The "body drain hole" is hopelessly plugged up from the car sitting for almost 12 years and having leaves and stuff sitting in there. So, when rain gets into the vent area just in front of the windshield, it is plugged up there and the water stays there, which can't be good. I found the other end of the drain hole on the chassis down below and it appears not plugged, so drain must be plugged up top in the grate area. Tried stiff wire, coat hanger, etc., but because it is nearly impossible to get wire in very far because of the angle (because of the grate over the drain area), I can't make any progress getting everything unplugged. Help! What have you guys done to unplug the drain hole? There must be a way! (BTW: the drain holes in the doors are clear).  Thanks for the help.  Jeff
