1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Date: 03/07/2017 07:03 pm
74 hood
Date: 07/03/2017 03:46 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 08/16/2018 08:54 am
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Date: 08/20/2017 01:34 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
  • Online today: 1,044
  • Guests: 925
  • Total: 925
Thinking of having my 78 Sedan Repainted....
Started by dave1987, August 01, 2010, 03:33:23 AM
Not only is good prep key...so is a good environment free-from-dust to paint your car at. Once you get air flowing in the area, it will not ever piece of loose dust in the vicinity right on top of you tacky paint and will cause a ruined finish.
Also consider that changing the color of a car requires you to cut in the door jambs, engine compartment, trunk, and other areas to make it look right...which is usually very labor intensive. Also, as your car is a repaint, be sure to sand the car thoroughly enough so the new paint will be able to stick as old paint that is too thick will not mix well with the new and cause runs and orange peel.
Once these additional things are considered plus the forementioned...its a lot cheaper to attempt to paint yourself but there are so many things to go wrong that you have to make sure you can afford putting your labor and money into a paint job that might not turn out as well as you have hoped.
Good luck with whichever route you go with!
Dave, I'm so glad things are getting better! See, good JuJu works! lol.
I agree with Dwayne and Chris...good preparation is key- you want no rust, no oils, no moisture under your paint or you'll understand the word undermine real quick. With Wildfire I have to sand her paint down to bare metal before I have her repainted due to her paint crackling.
Dwayne could not be more correct. To wit: ever seen a car that had poor prep and was painted BLACK? Or ANY dark color? You get the idea. The quality of the final coat is only as good as the prep. In fact, I thought my prep was outstanding in my engine compartment - until I put the color coat down. Yup, color reveals ALL the flaws. Glad it was just an engine compartment.
Like SO many other things where labor is involved - the cost of LABOR is the killer - not the materials. And being that car refinishing requires excellent labor - you pay for it.
PS - red paint is expensive ONLY because of its popularity. Supply and demand.
The quality, or lack of quality, in any paint job lies more in the preparation of the surface and the skill of the painter than in the paint itself.  Even the least expensive of automotive finishes should give you a decent shine and good durability if applied correctly over a properly prepared surface.  My Ford F-150 was painted six years ago at a material cost of about $300 and looks just fine today.  My Mark V cost approximately the same three years later.  One important note if you decide to go red: red paint is more expensive for whatever reason.
Oh yes.  I'm more playing with the idea right now. The wagon has been up for sale for more than a month now but we are making things work right now. Tax season will come around again and we should be settled.
Dave, your family is fed before you even consider painting the blue car, right? I thought that was why you were selling Brownie- to feed you and your family.
That's what I was thinking, you get what you pay for!
One reason why I wanted to use the same materials and paint my brother used. The paint is of high quality, I would have to pay to have pearl added to it like my brother did though, to get the same results.
I think the biggest reason the clear coat is delaminating, is that the car was repainted four months before it sat for three years, fully exposed to the elements and never maintained. Shortly after I took ownership (legally) I started to wash and wax it on a regular basis, even had to polish the entire car to get it's true shine back. I'm thinking the paint took shock from all of it and just started to deteriorate after being exposed to new chemicals it had never seen.
If I do the job myself, I was considering doing something not so fancy as the metallic canyon blue w/pearl that is on the car now. Perhaps cherry red or something close to ferrari red. Maybe even the bright yellow it was before. Something I wouldn't be as afraid to play with and get a hand for painting. I'm not afraid to do the body work myself, I would be happy to cut out and weld in a new section on the quarter panels, bondo/fiberglass it flat and then do a paint job.
Other touching up that would need to be done to the car before paint is fixing the cowl vent (hood came up on my dad while on the freeway, back in the 80s), and reforming the body lines on the doors where door dings have taken their toll.
Whichever coarse I decide to go, I need to get the wagon up and going, nice and strong, before I take the 78 out of commission for an extended period of time.
Just a word of warning. The guys who do this "on the side" or "will do it in between other jobs for less money" tend to have your car for months, or worse.
Maaco isn't horrible if you do all the prep work. I don't think I would want them doing the repair you mentioned though.
Unfortunately, to a large extent paint jobs are one of those where you really do get what you pay for. Cheap just usually doesn't work out.
Well the Ultra7000 is what my brother repainted the car with back in HighSchool. For nostagia reasons, I wanted to keep that kind of paint on the car. But anything that is the same color and will last a long time will be good enough for me if the paint turns out to expensive.
turbo74pinto
600 is WAY too much for paint in my eyes.  i use nason paint which is duponts lower brand.  works fine for me.  my average pint is around $20 and a gallon of reducer is around $50 i think...its been a while since ive bought reducer.  a gallon of nason clear with the activator is $120 ish.
bob
Dave,
You won't need anywhere close to a gallon of paint!  I'll guarantee you could buy a half-gallon and still end up with paint left over.  Unless you're doing a color change, a quart should be enough to paint a Pinto, but I really don't like running myself that short.  You might want to explore other paint brands also, unless there is some particular reason you're sold on Sherwin Williams.  The color you specify will be custom-mixed in whatever brand you select and my experience has been that there's little difference in brands.  I bought a half-gallon of paint when I painted my 1979 Continental Mark V and did not use quite all of it.  I sprayed three coats.
Personally, I'm not a big fan of Maaco, but their shops vary a lot and some of them are quite good.  Ask around.  If you can find a small, local shop, they might be more willing to work with you on price than a chain.  Don't count out talented DIY's either... some of them can turn out a mean paint job for far less than a shop.  Often the guys who work in the shops will do side work at home... doesn't hurt to ask!
Good luck!
How much do yall think it will cost? I know that a gallon of the Sherwin Williams Ultra 7000 that is on the car right now is around $600, but should it take more than one can to paint the car? Then there is clear coat and hardener, probably another $600. Materials probably $1200 alone! I'm afraid to attempt to paint the car myself and experiment a first time with such expensive products!
What's the alternatives I have here that are cheaper and more affordable? I want it to look nice and be durable. I was thinking possibly taking it to Macco after stripping the chrome trim off and removing the bumpers and rock reflectors, maybe have them cut out and fix the lower quarter panels while they are at it.
I want the exterior of my beloved 78 to reflect the beauty and luxary of it's interior!
Right now the roof and fenders are having clear coat delamination and it looks HORRIBLE.
