Crane Cam
Date: 02/26/2018 07:50 am
Custom Pinto Project
Date: 06/12/2016 07:37 pm
Date: 07/01/2019 12:23 pm
Date: 12/13/2016 10:25 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 11/08/2019 10:01 am
Date: 06/07/2018 01:45 am
Date: 10/24/2018 07:41 am
  • Total Topics: 16,268
  • Online today: 289
  • Guests: 230
  • Total: 230
door hinges
Started by tonij1960, July 29, 2010, 11:10:50 PM
flash041
yes they are easy to change.Look in my thread 78 Cruising wagon restore, I have instructions and pics.
Those are super easy to change. I did that on my 77 sedan & it locked them up good & tight
78txpony
I took a look at my spares and they are loosey-goosey as well.
The bright side is that the Pinto, like most other cars of the era, use pins and brass bushings.
The bushings usually take the most wear, being a soft metal.
The hinges I have have totally worn bushings - paper thin in places.
Look around for a pin and bushing set.
Installing them will be similar to how I restored those on my Oldsmobile:
http://www.flickr.com/photos/robsalbum/4438651018/#in/set-72157602930020786/
The door will need to come off the hinges for sure - drill out the top if the pin and tap it out through the bottom.  Bushings will pound out and new will press in with a vice.
Not too bad a job.
-Rob Young
1997 H-D Sportster
78txpony
I will take a look at the hinges on that spare door of mine and see how they look.  I think they are loose but not sure how much...
-Rob Young
1997 H-D Sportster
ToniJ1960
 There is a lot of egg shape so either oversized pins and bushings or replace the hinges Im sure
Quote from: tonij1960 on July 29, 2010, 11:10:50 PM
Everyone says the doors are noit the same for a wagon as they are for the hatchback pintos,but what about door hinges does anyone know for sure if theyre identical or not? And can I just replace the upper hinge to fix the sagging? And either way can they be done one at a time without removing the door altogether? I need this info to make the decision,replace my doors are not.
The early hinges are a little different than the later ones so if you end up replacing them make sure they have the same number of bolt holes as the ones that you already have.  Wagon or hatch hinges are the same.  As Matt said you can replace the pins if the hinge holes are not too badly worn.  Take a close look at the condition of the pin holes before you attempt to change the pins.  They may not be worth it.
ToniJ1960
 I have read that there are oversized bushings for the hinge pins but it seems like it would be beyond me to do the machining involved Im not set up for it nor do I have the knowledge. But I did help change a door once so I think changing a hinge shouldnt be any more difficult.
What you need to do is replace the hinge pins, not the whole hinge. If you got a replacement hinge it would probably be just as saggy. Do a search for hinge pin & you should be able to find the link on here to replace the sagging pins.
ToniJ1960
