Date: 02/08/2018 02:26 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Date: 06/07/2018 01:45 am
1972 Pinto for sale
Date: 05/19/2021 12:41 am
Date: 10/28/2018 08:45 am
Date: 03/25/2019 09:02 pm
Date: 04/12/2017 08:15 am
Crane Cam
Date: 02/26/2018 07:50 am
Date: 12/31/2017 11:14 pm
  • Online today: 1,090
  • Guests: 104
  • Total: 104
door windows
Started by tonij1960, July 24, 2010, 03:23:32 PM
ToniJ1960
 I think theres nothing behind the regulator that would interfere its just a matter of can I get my hand in there or a wrench to hold it :)
78txpony
1/4" bolts with lockwashers and nuts will be best and easiest.  Easy to find at the hardware store, too.  Tractor supply sells them by the scoop, too!  (Okay, by the pound...  ::))
Just make sure that the bolts will not interfere withanything inside the door (I forgot what is there.)
I do have relatively long arms and can reach across a Pinto with ease.  Now my Oldsmobiles are a different story, especially the right rear ones!   This is where PW are helpful.
-Rob Young
1997 H-D Sportster
Rob you must have longer arms than me! lol. It tsakes some calisthetics for me to begin to reach ther passenger window crank! lol! :lol:
ToniJ1960
 I was thinking the quality might be a let down on those kits too.
So what kind of screws or bolts will I need to reinstall the regulator with? Self tapping or with nuts and lockwashers, or can I use poprivets my poprivet gun can only use certain size rivets. Maybe  some washers and rivets?
78txpony
After putting power windows into my Olds convertible with atermarket "direct fit" parts, I will not do it again.
Fit was not direct, and there were mods galore.  Quality of the parts were less than crappy.  Gears stripped after 25 cycles, rivets broke off the mechanism, windows move at the speed of light (almost).
Not worth the 800 bucks at all.
If you stick with good original parts, you will have fewer problems.
Pintos do not really have the need for PW, either - 2 doors within easy arm reach.
If there were back windows that opened, or it was a ragtop, PW would be very convenient.
Just my thoughts.
I will pull out my spare reg this evening (or next) and see how it looks outside the door.
Glad your disassembly went well!
PS - I never got the picture you sent - musta went into the bit-bucket in the sky...
Bugs?  We got plenty here.  Luckily the spare doors are in my air conditioned workshop.
-Rob Young
1997 H-D Sportster
ToniJ1960
 We got the window regulator out tonight even though my boyfriend was whining about the insects outside. I had to sort of drill around the pins of the rivets because the drill bits I have wouldnt touch the metal that the pins are made of.Once I drilled around enough the pins came out and then I used a bigger bit to drill the rest out once the pins left a nice hole. So the regulator is out. And the wire I tried to use to raise and lower the window snapped it seemed pretty strong but it does take a lot to raise it. The pipe clamp around the vertical column did hold the window up enough that it didnt fall all the way out though :) so I clamped a small screwdriver to the column part that holds the window all the way shut for now,until I get a regulator to put in.
On a side note does anyone know if the universal power window kits are worth trying?
ToniJ1960
 ok the picture I have is basically the one you sent me but I drew a yellow arrow pointing to the part that wobbles, and a black arrow pointing to where I think putting a clamp will keep the window from dropping too far down,instead of using blocks underneath. I sent you that modified picture in my last email I think. Maybe I can get my laptop out there and hook my webcam to it tommorrow and take some actual ones of mine.
78txpony
Just email me the picture and i can post it for ya.
I want to see the bigger one anyway.
Triangle teeth, slippage - time for a new reg.
If they are greased and not abused, they last a long time.
The gear teeth are so worn that the window is sticking up.
Once you replace it, a release wire or whatever will not be needed.
1/2" long bolts & nuts will reinstall the new reg.
It is pretty easy - just wear long sleeves and or long rubber gloves to keep from getting "cheese-gratered-arm"...
-Rob Young
1997 H-D Sportster
Yep, you got it. The replacement can just be bolted back in, no need to rivet it in  unless you wanted to.
ToniJ1960
 And does that come out in one piece if you drill out the rivets? And the replacement will go in with bolts or need to be riveted?
Sounds like you need a new window regulator. The regulator is the thing that the crank mounts to & rolls the window up & down.
ToniJ1960
 Well I got the door panel off because when I came home today my door window wouldnt go up or down at all. What I saw the teeth on the long arm in the door looked ok except maybe the very top 3 teeth.But the rest all looked ok still rusty and symmetrical. So it doesnt really explain why it would go up easier than going down as it does now since I sprayed a bunch of wd everywhere in there lol. But even though it does go up better it strill slips a turn then grabs again.Going down it wont budge from the top unless I pull down on the long arm that is connected to the window frame to get it started.Then it goes so far and you can se it actually move back up an inch almost like its a spring.It does bind when I turn it.And the round part the cranck goes onto is loose itself and wobbles.
I can post up a picture since someone was so nice to send me some and highlight the areas to look at.I added a yellow arrow to the part that wobbles. So if someone will help me and tell me how to add an image to my post or where to upload them too I will appreciate that :)
For the time being Im leaving my door panel off because I need to get my windows up and down. It came off pretty well I think 2 clips werent nice and pulled out of the panel it couldve been worse. Does anyone know a way to put the clips back into the panel like a repair or should I just use silicone cement on those two spots to hold the panel down when it goes back in?
Im thinking of drillig a hole and dropping a metal cable into the door and wrapping it around the part that slides up and down and make an emergency window crank,maybe later replace it with a motor and have a power window. Instead of a block of wood to keep the window from dropping Im thinking of a piece of crate strap bolted around the metal channel to keep it from dropping too far ( I know a picture would be helpful (
78txpony
The wagon and sedan should use the same regs.
PM me your email address and I will send you some pictures and how to check if the regulator is stripped out.
You will need to have the door panel off of yours to check.
I want to be sure this is what you need.
Mine looks pretty good - should last a while just needs some cleaning and a good lubing before use.
-Rob Young
1997 H-D Sportster
ToniJ1960
 1978 wagon drivers door
78txpony
Quote from: tonij1960 on July 26, 2010, 01:38:40 PM
I can pretty much tell by the feel its not the crank handle itself slipping plus it does it in the same places all the time,near the top mostly,and does go up and down well in certain areas. Would you like to sell that gear you have :)
Let me look at the one I have to make sure it is okay - i think it is.
This is for the driver door right?
What year is yours again?
-Rob Young
1997 H-D Sportster
ToniJ1960
78txpony
Quote from: tonij1960 on July 25, 2010, 05:15:37 PM
And the slipping is mostly when rolling the window up for some reason and its the worst right near the very top.I haver to actually wrap my fingers around the glass and pull it up as I turn the handle,or else it just turns and turns and doesnt move. It does feel like a gear slipping,if I need that gear I hope you still have it who knows where I would ever  find another one
The most strain and wear in the mechanism is in the top inch of travel due to higher effort required for sealing of the window.
You need to find out what is slipping on what.  If the crank handle hole is full of metal shavings, then it is stripped.  Try the handle from the other door.  This is the only easy fix.
If that does not work, then it would be the regulator gear(s).  This will be more difficult, but not too bad.
-Rob Young
1997 H-D Sportster
78txpony
Quote from: blupinto on July 25, 2010, 10:12:00 PM
That's actually not a bad price! Thank you! Now it begs the question: How hard is it to install? The channels/fuzzy squeegies/sweepers?
The channel inserts will require the bottom stops be lowered and the adjustment screw in the jamb be loosened a lot to get the jamb side channel in and out.  Try to keep the cussing in a low tone of voice.   ::)
Pry out the old and scape out the adhesive with a screwdriver or a similar plastic or wood object to avoid damaging paint.
while window is loosey goosey and low, replace the sweepers (I thing they snap in and out - did not do those on my car).
Install new channel and use small amounts of weatherstrip adhesive to secure it.  Insert jamb side first and roll to the the corner.  Don't forget to put the metal window guide back on!
That 90* corner will take some creative accurate cutting with a razor blade.
Insert the rest and cut the end.
readjust the stops and adj screw in the jamb for smooth operation.
-Rob Young
1997 H-D Sportster
The channel should be easy, just pop out the old, cut the new one to size & put it in the track. Squeegees & fuzzies need some holes drilled for the screws that hold em on I think. I read the instructions briefly before sticking them in the rafters till Im ready.
Quote from: Pinto5.0 on July 25, 2010, 11:20:40 AM
The window channel itself is cheap from them, 20 bucks for enough for both sides. Squeegees/fuzzies were 95 I think & door seals were another 95.
ToniJ1960
 ok thank you everybody :) I will check into buying the window felt for $20. And the slipping is mostly when rolling the window up for some reason and its the worst right near the very top.I haver to actually wrap my fingers around the glass and pull it up as I turn the handle,or else it just turns and turns and doesnt move. It does feel like a gear slipping,if I need that gear I hope you still have it who knows where I would ever  find another one
78txpony
Quote from: Pinto5.0 on July 24, 2010, 07:39:12 PM
The slipping sounds like a bad gearbox. Popping off the track is usually a bad roller or rusted out track.
As for the sweeps & fuzzies, I found a place in Florida, Convertible Top Specialists on Ebay & for around 210 bucks I got new door seals, inner & outer squeegees/fuzzies & new window channel for both sides. Not cheap, but worth it to seal em up tight.
Yep, that would be topsdown.com.  I bought the window channel directly from them and that sealed my windows snuggly.  I wish i got the sweeper felts, too.
Where is the slipping occuring?  If it is NOT the crank on the shaft, then it is most likely the big regulator gear in the door.  These can be bought used (I have one if you need).
The guide block can still be had in the HELP! section at the auto parts store.  Once you get the door panel off, the causes will be more evident.
Removing the door panel wll require the special tool that looks like a putty knife with a deep slot cut into it.  Use a rag to protect surrounding paint.
-Rob Young
1997 H-D Sportster
One thing that helpped on my 78 sedan was to adjust the nut on the outside of the front of the door next to the upper hinge. That nut adjust the depth of the track the fronnt of the glass rides on. Once I adjusted that it stopped slipping off the track and was as noisy as far as rattling goes. It still rattles some but not to the frustration point.
I would like to play around with the door windows more to tighten the up some and change out the rollersbut just don't have the time.
ToniJ1960
 I used to be abler to find good spots where the windows quit rattling bad but not anymore I suppose its too far gone.Maybe once I get the roller to quit slipping (I have to help the drivers window at the top) I can figure out something to put in the sides of the window frame maybe that will  help.
I think one- if not THE- biggest reasons the windows rattle is those velvet-sided sweeper things that keeps moisture from going into the door itself. If that's brittle and dry-rotted out the window will rattle. Sadly all three of my Pinto steeds have rattly windows and I too am afraid one day they'll rattle themselves broken. In the meantime, play with rolling the window down to find a sweet spot where the window is supported a little better. As for the window slippage... I've had a window go off the track (PITA) and it ended up being because the white plastic (the brittle stuff) wheels and etc. had shattered. Like Matt said, you'll just have to remove the panel off the door and see what's going on.
It depends what is bad on the window itself. For the door panel there is a tool call a door clip tool, sold at any auto parts store. It's really cheap & can pop the clips from the door without damaging the panel. The window crank is held on with a philips screw & the door handle is held on by 3/8" head bolts. Just use a 3/8" socket to remove those bolts.
ToniJ1960
 Is there a particular tool or type of tool that makes removing the panels better? And will the roller make the glass so loose? I saw some rollers on ebay,they were square items with what looked like a screw in them. Is that the right thing to be looking for either inside the door or to be buying to replace them?
The door is easy to get in to after you remove the door panel, but be careful when you remove the panel. They can be easily torn & are hard to find replacements. The best thing that can be done once the panel is off is to check the rollers & guides to see if there are any problems.
