Date: 01/28/2017 12:30 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
72 pinto
Date: 06/23/2016 12:40 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
72 Pinto
Date: 03/07/2019 12:07 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
Date: 02/28/2024 02:07 pm
  • Online today: 826
  • Guests: 698
  • Total: 698
Larger front disc brakes keeping the 4 lug bolt pattern?
Started by russosborne, July 23, 2010, 11:10:46 PM
slowride
The rotor assy is a Raybestos 6022R (others manufacturers are available). Googled it and found it for $98ea at JC Whitney, and $118 at Rockauto.
Pricey, but Google is your friend.
1qkwagon
Does anyone know where I can get rotors for '72 pinto?  HELLLPP!
slowride
Quote from: Pinto5.0 on July 28, 2010, 08:07:42 PM
Semi-mets are great but its easy to glaze the rotors after a couple hot panic stops. Ceramics produce a REDICULOUS amount of brake dust.
That's why I have both coming in. I'm looking for the best compromise between performance and maintenance. All I know is that organics just aren't cutting it.....
Quote from: slowride on July 27, 2010, 02:35:13 PM
I have been running organic pads and am as underwhelmed as everyone else with them. I have both semi-metallics and ceramics coming this week and will be testing them to see if I can get an acceptable brake from them without resorting to brake/hub/wheel swaps.
Bigger brakes also mean going to bigger wheels in many cases.
80 an up granadas are fox platform cars which is why they are 4 lug and they prolly arent a direct fit options like the older rotors are.
slowride
That matches what I have found out. I hadn't even realised that the Granada was still being built in the 80's.
But for the slight change in size, it won't be worth the effort to me. I will just have to go with the 5 lug setup. Good thing I haven't bought any expensive wheels yet. I don't mind eating the $40 I paid for the 15inch Mustang 4 lug wheels, but much more and i would be crying.
slowride
Granada up to '79 are 11.03" but 5 lug. '80 and up are 4 lug but 10.08" (Pinto are 9.3")
Don't know if the later spindles interchange......
From what I understand Granada rotors use Pinto bearings & fit Pinto spindles 74-up. They are 11" & there are adapters to bolt on GM Metric calipers. Ive seen complete kits on Ebay for street rod use but they are 5 lug.
Ive never made the swap but I was looking into it before I found 9" 5-lug rotors cheap.
I have read about those rotors here, but not many people seem to think they are for real. But I will see what I can come up with searching car parts sites. :-)
If they do exist, would I need to do the same things that are needed for the 5 lug Granada swap?
Thanks,
I would think 4 lug Granada rotors with GM metric calipers are what you are after.
I've daydreamed about chuckinging those bigger five lug rotors on my rotary table and redrilling them for four holes.
I have been searching for this also and have found nothing available yet.  I like some of the Fox Mustang wheel styles (plus I already have them).
I have been looking at the Turbocoupe rotors (similar to 87-93 Mustang GT), again because I have them.  They use the same bearings as the late Pinto but the distance between the bearings is shorter on the Fox rotors.  I was wondering if adding a spacer behind inner bear cup could be used to fit the Pinto spindle.  This is a planned future R&D project dream.
I did search, and I think the answer is no, but thought I would give it another shot.
I had decided to keep the 4 lugs instead of converting over to 5 lugs. Then I get offered this 4.6L mod motor for free. I think the stock brakes are not going to be able to handle things now.
Would like to go to around 11 inch rotors, since I will be using 15 inch wheels.
Or should I just break :lol:  down and convert to 5 lugs? Even if there are Granada 4 lug disc brakes, if I am going to have to convert anything I might as well just do it right and go 5 lugs. But am hoping that there is something that will work with the 4 lug.  :lost:
Seeing as I have already gotten rid of the 67 Mustang 8 inch rear I had I am pretty sure of the answer.  :(
Thanks,
