1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 09/19/2019 04:43 pm
Date: 04/28/2018 04:12 pm
Date: 09/10/2018 10:41 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 01/18/2017 05:35 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
77-78 front grill
Date: 04/07/2017 12:35 am
  • Online today: 1,044
  • Guests: 83
  • Total: 83
Maverick tail light lens
Started by Bigtimmay, July 21, 2010, 05:31:55 PM
hummm....... good question ummm mavcat i guesss sence there is more maverick than bobcat, but i am looking at buying a 72 comet for scrap  price  as it has been sitting in a feild for 7-10 years. and changing more   then   who know what it will be.
So does that make it a Bobrick or a Mavcat??
HA! I should've known! That IS a dad thing! lol. :lol:
because i had them , it makes the car look different , so you could ask why.......  and why not
Now it begs the question... why swap Maverick lights for Bobcat lights on a Maverick?
no  .... alot longer  double  in lsize they have 2 lenses but one set is reflecters  only
that is where the modifying  has to be done, eather cut a stud off or drill a hole.
Ok I'm trippin'... I remember Maverick taillights looking similar to '71-'76 Pinto taillights but Bobcat taillights?!? They're a tad longer, no?
the housing would prolly be a direct bolt on if you want the pinto light look but as for the lens they are a little diffrent atleast if your putting a maverick lens into the bobcat housing.
ok. the housings will interchang with a bit of modifying  as i have bobcat tail lights on my maverick.
Well i just found out the hard way that a maverick tail light lens and a bobcat lens are different even though they have the same part number.
The specific difference of the 2 is the fact that the back up light clear area is larger and above and below the clear part the lens the outer plastic doesn't have the dimpled in areas to clear the screw holes.
So i took a grinder too the lens and made it fit because my original one had a crack and well till i can find a real bobcat lens its gotta look better.
Figured id just let yall know they arent the same. LOL
