Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Date: 07/01/2019 03:17 pm
Date: 04/12/2017 08:15 am
2.8 radiator
Date: 10/25/2019 04:10 pm
parts needed
Date: 02/20/2017 07:58 am
Date: 12/26/2016 04:29 pm
Date: 02/05/2020 11:06 am
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
  • Online today: 2,773
  • Guests: 97
  • Total: 97
79 battery tray area-how much of that is necessary?
Started by russosborne, July 03, 2010, 12:31:01 PM
Thanks. Since I have to fix it anyway,might as well make it better. :-)
i measured from the bottom of the bend where it flattens out and it was 3 1/4 inchs wide. hope that helps.
i like as much room as possible too i woulda cut more out but as it is its about 1/4-1/2 inch from the mounting area of the upper a arm. So any more and i would had issuses. lol
Thanks. I am not going the turbo route(at least not this time) but I like having as much room as possible to work. That is why I am not putting a V8 in.
i think its around 3-4 but when i get home ill go measure it for sure
Ok, didnt notice that the first time I looked. I was overcome by the blue interior. :-)
About how much of the "ledge" did you leave? Looks like maybe 4 inches, but hard to tell from a picture.
Thanks,
If you look at my project post on my 78 bobcat i cut pretty much the most that i would feel comfortable removing without hitting anything. Theres a few pics up.
If I don't put the battery there that is?
Is there enough room to just cut it out(mine is very bad) and put a flat piece there, or would that cause interference with the suspension?
Hope this makes sense. Maybe making it smooth instead of having the bump where the battery sits makes more sense as a question. It would be much easier, which makes me think it won't work.
Thanks,
