Date: 07/17/2018 09:22 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
hood for a 79-80
Date: 11/30/2018 10:55 pm
Date: 09/12/2018 12:33 pm
Date: 02/18/2017 04:41 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 10/24/2018 07:41 am
Date: 02/21/2022 11:11 pm
Date: 10/24/2019 01:45 pm
  • Online today: 2,773
  • Guests: 114
  • Total: 114
Battery tray removal-the bolt at the bottom
Started by russosborne, June 30, 2010, 10:46:12 PM
Quote from: dave1987 on July 01, 2010, 12:31:13 PM
I've removed it once. I had to have my brother hold the bolt still with an open end wrench from the engine side while I removed the bolt from the wheel side then jam the bolt out by pushing it around until it fell out. I don't think I put it back in because it was so hard to get out.
same here  but i did put it back in  just never tighened it up
Thanks. Guess I will just wait until I pull the engine this weekend.
Going to be getting frustrated enough, no use adding to it by doing something that will be easier later.
i had the exhaust out of my 78 bobcat when i pulled the battery box
79 with 2.3l. The exhaust pipe is hitting this bolt. Do I have to remove the exhaust first? Engine is coming out, so that will be happening anyway, but just curious. I did try prying on the exhaust a bit, but didn't have much success.
Thanks,
