Many Parts Listed Below
Date: 04/20/2018 11:15 am
Date: 01/28/2017 12:30 pm
front end parts
Date: 03/30/2018 12:48 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Date: 03/05/2017 03:27 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 11/11/2019 03:38 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
  • Online today: 583
  • Guests: 406
  • Total: 406
rotors for '72 pinto
Started by 1qkwagon, June 29, 2010, 07:36:26 PM
You are correct, 71-73 suspension and front brake parts are not that easy to come by.  I am in process of rebuilding the brakes and front end in my 73.  I have found all but the rotors.  The front calipers took 3 weeks to get.  The lower control arm bushings were second hardest to find.
The 74 and up lower and upper control arms will not bolt onto your car without some modifications to the cross member.  The upper control arm bolts are spaced differently and the lower control arm bushing is longer.  I am not sure about the spindles but the ball joints look like they can be swapped from early to later.
1qkwagon
OK ,so I'm putting a 331 in my '72 pinto and had noticed the front rotors are pretty worn out, I checked with the local parts stores and they say either they can't get them or they are $132.00 each. Anyone know what you have to do to put '74-'80 rotors on? Is it just replace the upper and lower control arms for the newer ones along w/spindles? OR can you put the newer balljoints on and spindles? Thanks for any help. '71-'73 parts are not that easy to come by around here, '74-'80 not too bad tho.
