Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 03/27/2017 10:07 pm
Date: 01/21/2023 04:19 pm
New cam
Date: 01/23/2017 05:11 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 09/15/2019 12:28 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
  • Online today: 1,722
  • Guests: 526
  • Total: 526
Well, just about to get started on my 79 hatchback-long
Started by russosborne, June 23, 2010, 04:44:42 PM
Not much done today. Didn't really feel like doing anything at all.
Only went out to the garage at all because my wife was watching one of her shows and it was more annoying than usual.
Got the dash and engine compartment wiring harness's completely removed.
Also got the heater box out. I didn't realise that it came off with the 4 nuts from the engine side of the firewall. I figured it out after I took the front cover off of it and still couldn't find any mounting screws. At least I didn't break anything this time.
Was going to take the rear part of the harness out, but I guess I just was too tired and I forgot about it.
Been a long week, and it starts all over again tomorrow. I just can't wait. :-(  honestly, about the only thing keeping me sane right now is the Pinto. If I had said that even 5 years ago I would have said it was too late, you have already lost it. :-)
I was googling last night, and found this site.
http://www.themustangshop.com/modswap.cfm
It is about doing a 4.6 swap into an early Mustang, but lots of useful info. They use a II front suspension, and even sell a Canton Racing front sump oil pan.
This is starting to look much more doable. :-)
Couple of notes to anyone thinking about taking the dash out. At least on a 79.
Mine had 5 bolts along the windshield, you either need a flex drive or remove the windshield.
Remember that there are vent controls on BOTH sides that need to come off first.
The steering column HAS to come out, or at least be dropped. There is a bolt in the center of the dash above the column that goes to a bracket, and that bolt has to come out.
Probably easier if you remove the heater control first.
Headlight switch and windshield wiper switch need to be removed, or at least remove the electrical connectors.
Most of this should be done before you take all the dash bolts off. I did it afterwards, with the dash hanging. Some of it may be easier to do that way, but if you want to make sure not to break anything I would disconnect it all first.
and a few more.
The last one shows more rust. I sort of knew this was there, I could see it when I sat in the driver's seat. I was just hoping that it wasn't rust, but it is.
It is hard to see in this picture, and the other picture I took is worth. It is the lower corner on the driver's side. The metal is separated there like a piece of plywood that has gotten too wet.
you asked for it, you got it. Well, no one asked, but here are some more pictures of the last two nights work.
One engine down, one to go.
Put the Ranger 2.3 engine/trans on craig's list last night. A kid came and got it today. For his dad's Ranger that has well over 300K miles. I didn't think a Ranger could last that long here in the rust belt. I really hope it works out for him, seemed like a good kid. Kid being probably 20ish. God I am feeling really old. 51 in a few weeks.
Someone here said they probably want the Pinto one as a spare, so hopefully he will take it.
Nothing new on the Pinto today, took all my energy to get the Ranger engine loaded up. Maybe tonight. Way too muggy out there right now.
the oil pan is going to be an issue. Might have to take a couple of them and make one. Will have to wait and see. Once I get the engine I am planning on just putting it in the engine compartment to see just what I will need to do.
The person giving me all this also found a spare set of frame mounts that he had taken off the k member that he is keeping, so he will be giving them to me. so if I can find a spot to put them on the Pinto I will be able to just use the Mustang mounts for the engine. Unlike the V8 mounts for the II/Pinto, these are all over the place. :-)
there is a post from 2005 or 2006 on here that has a link to a Mustang II that had the 32 valve 4.6 installed, and the car didn't look all hacked up, so I know it is possible. If this was an early Pinto, I don't know if I would even try, since putting a regular 5.0 in those isn't easy. I am imagining that putting the 4.6 in mine will be about the same difficulty as doing that. My goal is to not have it look like someone drunk with a torch did it. :-)
I actaully bought a 69 Fairlane with a 429(not the boss one) that did look like that once I got underneath it. I was stupid to buy it, but I had just gotten out of the Navy and really wanted a car and wasn't thinking. Didn't have it for very long.
Quote from: Bigtimmay on July 14, 2010, 04:42:25 PM
I havent seen a 4.6 in a pinto yet would be pretty cool been trying to talk my bro into puttin a LS1 or 4.6 into his AE86 corrolla.  If you do the 4.6 swap you should so go with the 6 speed trans talk about a fast pinto.
The 4.6 is really really wide, I see some potential issues there, then there is the rear sump oil pan....never seen a 4.6 w/ a front sump. But yea, that would be a sweet swap!
Saw a Mustang on tv that had a stock 32 valve Navigator engine swap, ran in the 10's.... :fastcar:
Oh, while I am thinking about it. On this car there were 5 or 6 hex headed screws under the windshield holding the dash. And I think the only way to remove them without taking the windshield out would be to use a flex shaft on a socket. These were 1/4 inch heads also. I tried using a standard nut driver, and at least with my hands I was putting way too much pressure on the windshield. A socket with u-joints might work, but there really isn't much room for anything with the windshield in place.
And I ended up making the most progress with the windshield by using a one sided razor blade, having it between the sealant and the windshield, and pushing it along to cut. I used a screwdriver and a gasket scraper as pushing tools. But I also had removed a whole lot of the sealant around the windshield beforehand, so there wasn't as much for the razor blade to have to move through. And you need enough of a hole to get the razor blade started.
How to get a little carried away.
go out to the garage wanting to do one little thing.
Not be able to do the one little thing. (quarter window philip screws on trim won't come off, going to have to grind the heads off).
Decide to work a little more on the windshield removal.
Taking windshield off, and not knowing where to put it.
Take dash bolts out. Some where something is holding the dash in, maybe a missed bolt. Need to go back and review some posts on that.
Did I mention somewhere back in time that I tend to be impatient?  :-) But at least I got something needed done. Need to get underneath and pull the gas tank and lines, but still not feeling up to that physically.
I really wasn't planning on taking the windshield all the way off, just wanted to get another side free. Oh, well.
Pictures later this weekend.
Oh, may not be getting engine stuff until the 31. I didn't know he still had to pull it all from the donor car, so I told him I could do it a week later if it was better for him. He is going to let me know.
Put the Ranger engine/trans on Akron Craig's List. For Free. Need all the good karma I can get. :-)
Not yet, a week from this Saturday. But I would like to make room now. I don't have room for 2 engines, much less 3.
But I did confirm that the guy is serious. :-)
lol i just read you motor classified im guessing you got that 4.6 to your house?
The one I may be getting is a 2V engine. Which is ok. Found lots of info on these things, going to take a while to digest. Probably shouldn't get too excited until the parts are in my garage.
Russ' Law-Every silver lining has a cloud.
But boy am I excited just thinking about it!
Well, this one would be coming with the automatic from the car also.
Along with computers, complete wiring harness, fuel tank, dash, steering column, driveshaft, etc. No rear end, but I would like the 8 inch I already have anyway. I probably won't use all it is coming with, but it would be nice to have it all just in case.
Let's just say he is making an offer I can't refuse. If he wasn't drunk or something when he made it.
I did a search, and found a post and a few replies about this from about 4-5 years ago. There is a link to a Mustang II that has one in it and it looks killer. Although that one is a 32valve engine from a Cobra. The one I am maybe getting is from a 96 Mustang GT. So I don't know for sure any details on the engine, but Google here I come. :-)
I just got an offer from someone on the vintage-mustang forum I am on.
It is so unbelieveable that I won't say what it is until I am sure about it. But let's just say it would be a major course correction on what I am doing with the Pinto. Something I really wanted to do but didn't have the money.
BTW, has anyone put a 4.6 from a 96 Mustang in one of these?   :-)
Quote from: popbumper on July 14, 2010, 03:29:02 PM
Quote from: russosborne on July 14, 2010, 02:43:51 AM
Oh, wait. I did find more rust. Is there something special about the passenger side on these things, or am I just lucky?
Naw, Russ, you are not lucky. Think about the standard relationship of a car to the environment and you will understand why the passenger side rust is always worse. Given that a car travels with the drivers' side to the INSIDE of a roadway (at the crown), all the water/slush/salt/mud/puddles run to the right side of the car - the PASSENGER side - which is exposed to a far greater volume of nasty elements, therby developing rust both more quickly and in greater amounts.
Even my Texas car rust was worse on the passenger side.
That makes sense. Especially here in the midwest, lots of slush and snow on the sides of the roads. Heck, there is lots of it in the middle of the roads in Akron.
Quote from: phils toys on July 14, 2010, 12:01:33 PM
if i wern't so lazy i would have looked up the part #'s my self  and yes they are all the same do you need the compleet set or just peices?
phi
l
The only one I need is the upright one on the driver's side. I managed to get the others off ok. Been too long, forgot how to do it. Been saying that to myself a lot lately.
phi
l
Quote from: russosborne on July 14, 2010, 02:31:33 AM
Well, according to all who answered on the site they will work. So if you still want to I will take them, but I will pay you back someday.
And now on to the good (HA!) stuff. Been a couple of days since I did anything, so I went out tonight to just clean out some stuff I had in the Pinto. Silly me.
Got 90% of the carpet out without removing the front seats. And guess what I found. 40cents. Bet you thought I was going to say more rust. Oh, wait. I did find more rust. Is there something special about the passenger side on these things, or am I just lucky? At least one more 3-4 inch diameter spot on the floor behind the passenger seat, not a hole yet, but I think I could push a finger through if I tried. And there is rust all along the rear part of the passenger side of the crossmember(?) that runs from side to side inside the car. The piece that the lower piece of the bottom rear seat bolts on to. Not sure how bad it is, need more light. And more courage. :-)
The driver's side still looks pretty good, although it does look like there is some rust around the drain plug behind the driver's seat. I have never yet seen one of those that isn't rusted. There is also a small spot in front of the seat. Again, I couldn't see how bad. Can't wait to see under the seats.
Will try to get some pictures later this week. Working extra at work, so I haven't really had the energy to do much when I get home.
Does anybody know the size of the nuts that hold the seats on? I really haven't had any luck yet. I think the ones on the passenger seat are rusted. But I can't get anything to fit.
Quote from: russosborne on July 11, 2010, 10:23:57 PM
Thanks. I don't know if those years would work. I'd rather wait on it for now until a) I know for sure, and b) I could afford to pay for it.
if it fits it is yours  all you have to do is show  up at the ohio meet
Quote from: phils toys on July 10, 2010, 03:24:18 PM
:look:
umm  now you dont have to worry about storing the  glass
:surprised:
i have trim for a windsheild for a 78 and a 76 it it will help  but i think they are different  let me know and i can bring it to the ohio gathering
at least for a while.  :evil:
Thought it might be that, but the passenger side is noticiably worse than the drivers side. And there is no crack on the drivers pillar.
Was working on the Blazer. Backflushing the radiator. had to let it run to get up to temp several times, since I flushed it several times. Lots and lots of rusty water. Finally got it clean, but the radiator probably needs boiled out.
Kept looking at the Pinto, and before I knew it there were no taillights, rear side markers, or hatch on it anymore.
Anyone know how to remove the vinyl piece that covers the gap at the rear bumper?I pulled it up, but couldn't see any attachment points. And how do you remove the quarter windows?
The ripple you see on the a-pillar and the c-pillar is that way from the factory. That is where the roof is put on. If you look closely you will see the same thing on the other side.  :o
I am wondering if this car was hit at some point. The picture of the crack in the passenger side windshield post along with the ripple that is on the passenger side rear quarter between the quarter window and the hatch really make me think it has.
The third pictue is of even more rust I just found. Again on the passenger side, this is behind the front seat. Getting scared about what I will find once I get the carpet up. Oh, well. It is still much better than my poor II was.
Took a bunch more. Then I started working on the windshield removal. I wish I could remember what weed eater string I had used when I took the 69 Mustang's windshield out, cause the stuff I have now bites.
Anyway, here are the pictures.
Quote from: dholvrsn on July 10, 2010, 12:33:04 PM
Have any trouble getting those Mustang Hurricane wheels on there without having them rub?
Well, I haven't driven it more than 10 feet with them on. But just from feeling around the tire I think at least with the tires currently on there will be a rubbing problem. But that is why I bought these. $40 for the set of 4.
There is room on the outside, so maybe a thin spacer would be all I need. I was planning on rolling the fender well lips anyway at some point before painting. I won't be worrying about that until I get the 8inch rear installed, which won't be for a long time most likely.
I haven't even tried putting them on the front, I am sure they would rub there.
