1972 Pinto for sale
Date: 05/19/2021 12:41 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 05/13/2021 05:29 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
ENGINE COMPLETE 1971 PINTO
Date: 12/28/2017 03:55 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
Date: 09/17/2024 12:35 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
  • Online today: 129
  • Guests: 105
  • Total: 105
door jam switch
Started by flash041, June 05, 2010, 10:45:05 PM
flash041
31 years ago when I bought the car I removed the buzzer. It drove me nuts!Thank you for the info.
According to the 1978 EVTM, the third wire goes to a reminder buzzer.  It will buzz if you open the door and have either the lights on or the key in the ignition switch.  It is not necessary but a nice feature especially for the head light warning (saved me from a dead battery a couple times).
flash041
I see CJ pony parts lists one for 83-93 Mustang that looks just like it.I know the driver side is Three wire and the passenger is two wire. On the drivers side I crossed two of the wires and the light works.What is the third wire for? Is it nessary?
bbobcat75
i have a set of used ones out of a 74 mustang ii
1975 mercury bobcat 2.8 auto
There are two types of these door jamb switches, the two pole and three pole types. What you are looking for is the three pole type.
O'Reilly's/Schucks has them:
Part # F6035 - $N/A
Autozone has them:
Part # SW110 - $16.99/ea
RockAuto has them:
1S1098 - $5.71/ea
Schucks/O'Reilly's around here (in Idaho) will price match with AutoZone and vise-verse. The Schucks/O'Reilly's website says they are not available online, so you will have to call or go in to see how much it is there, and if they have it in stock or can order it. These places shouldn't charge you for shipping if they have to special order them though!
The original ones have a metal shaft, less likely to break on you, and are not a full plastic unit like these replacements are.
When I need switches, I usually just go to the junk yard and check 70's era Ford cars for them. If they match, I grab them and they are usually dirt cheap and easy to clean up! Every one I've pulled was in working order, but you have to pull hard on them to get them off the socket on the wires, sometimes they will pull the wires off with them, or the socket will break. If that happens, just go to another one and try again.
flash041
Does any one know where you can get the door jamb switches for the dome light?
