72 PINTO WAGON
Date: 09/23/2018 06:16 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
80 pinto original
Date: 08/04/2019 10:45 am
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Date: 10/24/2018 07:41 am
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
1980 hood needed
Date: 04/23/2020 10:41 pm
Center armrest for 1979 pinto . Possible anyone who makes them of has one for sale
Date: 08/13/2017 02:01 pm
Date: 10/14/2019 08:24 pm
  • Online today: 2,819
  • Guests: 2562
  • Total: 2562
Here is my '80 hatch I call Callisto
Started by Pinto5.0, May 30, 2010, 02:14:41 PM
Those look really nice!  Great find!
I bought a set of wheels for this car instead of blasting & painting the ones I had. I still needed 3 center caps & 2 trim rings anyhow for mine. I probably would have spent close to $300 getting mine ready to run with some used tires & for a few bucks more I got this set of 4,000 mile originals with new Kumho 185/70 tires.
All I need to do is change the silver paint to gold to match my originals & bolt them on.
have one ring on ebay! ck it out make offer! its yours!
Ok, thanks.
Might be something worth considering, I am just not thrilled about the plastic part, but maybe I am just old fashioned.
Plus I have heard in the past that they can't be repaired if it is the plastic. Maybe that has changed?
I went with that one because it's the biggest 2 core aluminum radiator that would fit. I'm planning an EFI turbo swap into this car down the road & I wanted plenty of cooling. That radiator has the correct size in/outlets on the correct sides. It took a bit of fabbing to mount but nothing crazy.
Well, maybe I'm just lucky but I put one with plastic in my dually and 5yrs later it was still like the day I bought it when I sold the truck, I also put one in the wife's Toy pickup about 3 1/2yrs ago and it's still like the day I put it in, I'll probably put one in my short bed too when I switch to the big block..
I'm curious about your choice of a radiator.
Why did you want one that has plastic?
I am looking for one and was thinking all aluminum, but I am open to being convinced otherwise.  ;D
thanks,
Thanks  8)  That was the longest I've searched for a single part. I now have everything I need to finish this sucker.
The 73 took priority over everything but when it's done I can swap the wagon engine then get this one on the road. It's still mostly assembled. I didn't want to turn it into a full blown rotisserie resto & was careful not to dig in too deep.
I also decided to put it back to 4-lug so I can run the stock wheels. I found a powdercoater that can do them in the stock black/gold theme so I'm going that route. I just need to find some near mint centers & some nice trim rings. I think 2 of my rings are a 8 out of 10 so just need 2 more.
It took 2 years of searching but I finally found an NOS hood for this car. I looked at a dozen used ones & not one was worth using. My original hood is clean but has a hole cut in it to clear the old turbo. I'll paint them both.
It's got some surface rust along the one edge but no pitting. It should come right off with some POR metal prep.
And the best part was the $100 price tag. It was going to cost that to chemically strip the so-so hood I had.
Now if I can just get some time to work on it.....
awesome man, i havent had time to work on the bobcat i have. Opened my own repair shop so ive had no time
One issue I had to address on this car is bass for the sound system. Having a hatch means there is no good way to hide a sub unless I eliminate the spare tire or raise the floor a few inches to get the required airspace. I finally found a solution that I like.
Bazooka disguised an 8 inch woofer as a nitrous bottle. Problem solved! I had tubes in my S-10 years ago & loved 'em.  I ain't hiding this sucker anywhere, it's gonna be right there in plain sight when you pop the hatch. NOS has replacement decals to replace the Bazooka label for added effect.
I liked the idea so much that I bought a pair of white ones to go in back of my wagon. Too cool!!  8)
I turned up this pic of one installed. I'm not crazy about the way it's mounted sideways but it sure looks good.
Finally had a little warm weather & jumped on the car. I got the area behind the battery replaced after an hour of fitting the new metal as close to perfectly as I could get it.
After that I decided to remove the bump for the eventual turbo install.
Again, an hour of fitting the new metal should give me a clean look once the paint is on her.
I still have some small holes to fill but at least the hard part is over.
I have to remember to send you pics of the header flanges on both sets I have.
Thinking the new (NOS) ones are for a 351w ? I have never worked on a 351w so not sure on shapes or measurements.
Grader going by.....gotta go !
Sadly that tire is too dryrotted to hold air. It has like new tread & was a quality BFG. It's a whopping 20 deg. down here. 5 months of winter soooo far...
Remember the guy I put you on to for the NOS header kit? Turns out he is the one I got the doors from. The Pinto world is indeed small.
How bout some smog free Canadian air for that RR tire ?
Cheap !
I'll send some -40c stuff down for ya !  ;D
Good show on getting NOS doors & springs !
I also got a pair of new Landrum 125# rear springs for this car since when I pulled my '77 parts cars 78K mile springs out they were both broken. I can only assume Callisto's 89K mile springs wont fare any better so when these popped up for $120 for the pair shipped I jumped on the deal. I have an insane amount of cash wrapped up in this car so a few deals really help at times.
Here is the last thing I needed for this car...... NOS doors  8)
They came partially assembled(latches, locks, windows & cranks) but have never seen paint. I have a set of AZ doors that Pintony brought me from Freds house but I think I need those for the '73 so now I'm not sweating the door situation.
Having OCD & working on cars is a bad combo. I started pulling engines just to clean, paint & detail  stuff when I was 17. I had rusty winter beaters with sparkling engine bays. I did manage to calm it down but it does flare up from time to time.
My MSD was (is) mounted in the glove box.
I want to pick a one wire alt up like you did. Nice, neat & tidy !
Lots of the holes in mine were not factory. I'll be cleaning up the whole mess.
Now seeing your (OCD) hole filling, now I'll have to do mine , or you'll look at mine & cringe !  ;D
The MSD will be under the dash, the coil is getting mounted on the engine & I have a 1-wire alternator for her. That eliminates everything on the inner fenders & I'm amazed at the number of holes that were drilled.
If I do this to my wagon I may cut the stockers out completely & metal brake a new set instead of all the welding.  I need to make room for the turbo on the passenger side anyhow.
Looking real good !
I stripped the engine compartment in mine. I too will be removing that battery tray part : rust leaking out from under it. Plus no need for it.
I also have a pile of holes all around in there !
I had quite a few days off & did absolutely nothing with them except one day for about 6 hours.  I'm gonna regret that at some point. At least I took the time to mock up the '79 turbo longblock with my ported head & re-check clearances. This time I showed plenty of piston to valve clearance. I thought I was off a tooth or two when I tried the 1st time.
The 9 to 1 pistons combined with the milled head should give me close to 11 to 1 compression. The big solid cam & porting as well as my dual Weber 40 IDF's should push me near 150 HP & be a blast to drive. It will eventually reside in my dunebuggy but for now I can run this combo in this car for a few years while I get the EFI engine ready to install.
I also did some welding on my inner fenders. The big hole on the drivers side is history as are all the smaller ones......ALL 30 OF THEM!! Wow, thats a lot of holes.
I decided to move the battery so I removed the reinforcement for the tray.
That left so many holes to fill plus the rivnuts so I decided to replace the whole section with new steel..
That's where I left off. I need to get my rear end moving on this thing.
It definitely wasn't cheap. I could have saved a hundred bucks by opting for the painted version but I'm going way over the top with details on this car. I'll build the rest of the exhaust myself out of 2 1/4" or 2 1/2" mandrel bent tubing & probably send that out to get coated as well.
I haven't settled on a muffler yet but was leaning toward a polished Magnaflow. I know I need a little backpressure so I'm saving the glasspack style mufflers I bought for use with my turbo wagon. I also have a Magnaflow 1 into 2 splitter(I wanted dual tips) that I'll save for the wagon. I found a really sharp oval exhaust tip that measures 1 1/2" x 8" that should really compliment the rear of the car.
Quote from: Pinto5.0 on September 09, 2012, 06:03:45 PM
The Pacesetter header arrived a few days ago. Wow, what a beauty. I almost hate to put this in an engine bay. The $250 price tag was a bit steep but this car is turning into a showcar in front of my eyes & I just couldnt put a crappy looking used Ranger header on her in good conscience.
Man how times have changed, and not necessarily for the better!!!
Back in the 70's I used to be a distributor for Doug Thorley, Hedman & Pacesetter and had great connections when it came to Hooker too.
That set back then would have been installed on the car with a complete 2 1/4" system out the back using a Walker turbo mufffler would have been no more than what you paid for the headers alone!!!
I realize it's all about supply vs demand and, really, I can't argue that point.  It's just that I know what went into those then and what it took to hand build a system then and to see what these parts/services are going for now; well, it's hard for me to comprehend.
If I ever win the Lotto I'm going to set up a shop to fab only Pinto exhaust products & damn near give them away.
If I could do that I would die a happy man! (not really!)
Wow, after almost 4 months of working on anything but Callisto I finally got back to her. She's in the garage for winter & I started welding up the holes in the inner fenders. I had it all painted & ready for the engine but my OCD made me go back & make it better.
I think I'm gonna weld up that hole under the brake booster unless there is a really good reason not to.
I already have a chrome timing cover & a black powdercoated 1-wire alternator as well as a polished aluminum scoop for the 350 Holley carb.
Problem is that now I want to get the stock valve cover, water pump pulley, alternator & power steering brackets & Offy intake all powdercoated chrome.
I also want to move the battery out back & fill all the holes & smooth out the engine compartment. How in gods name did I end up here??  ???
Bell that was on my 302w. I'll never use it...... T-5 was bolted to it. Meant for the small 157 tooth flywheel. BTW - I also have the flywheel & Center Force clutch I will not be using.
I still have to get the fork number for you.
JC Whitney sent my roll of weatherstrippi ng last week so I tried it out. The crappy cell pics don't do it justice. This is a great match & I'll only have about 10 bucks wrapped up in it. I should have enough left to do my wagon & 3 more hatches.....
The channel is dead on. The seal has an egg shape versus the D shape of the stock rubber but the next pic says it all.
Perfect match  8) The new one is on the left side.
3 of my bell housings came in yesterday, 2- D5's & 1- D9
To my surprise one of the D5's had a clutch fork & the other one had a dust cover.
Pinto1955 is sending me the other D5 fork so I've got the bells for Callisto & the wagon(when I swap out the auto. trans.) & one of the D9's is getting set aside incase I 2.3 Turbo my '73 instead of installing the 5.0  :-\
