Pinto Watch
Date: 06/22/2019 07:16 pm
Mirror
Date: 04/15/2020 01:42 pm
1979 pinto
Date: 04/19/2018 02:02 am
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 11/11/2019 04:49 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
upholstery for bucket seats
Date: 10/30/2018 08:44 am
  • Online today: 2,909
  • Guests: 2622
  • Total: 2622
Here is my '80 hatch I call Callisto
Started by Pinto5.0, May 30, 2010, 02:14:41 PM
I thought these turned out great
I have a few more I copied from his sale ad as well. It's a beauty.
Very nice looking fabrication.  The custom Pinto linked below had the same idea of using 68 Firebird lights but ended up using GM truck turn signal lights for a similar look.  I have more photos of that red Pinto (from eBay I believe).  I saved them to a Word file and can not figure out how to convert them to jpg or gif format for posting here.  If would like them, PM me your email address and I will send the file to you.
http://www.fordpinto.com/your-project/my-v8-street-pinto-project/
Quote from: Pinto5.0 on September 11, 2010, 04:44:43 PM
Here is something I wanted to do 26 years ago to my first Pinto. '68 Firebird tail lights. I have been saving these just for that purpose & this is the car they will end up in. I have seen a sequential LED kit for these & down the road Ill probably upgrade.
It's amazing how well these fit in the back & I can't believe it's never been done before. This should be a very simple cut & weld & I'll probably spend 4X more time on bodywork versus installation.
It's not often you get to quote yourself or even see a one-off idea you came up with as a kid put to steel but here's my tail lights already done.
I wanted to do this back in '84 to my '74 Runabout but never did. I saw a blown Pro Street Pinto around  1990 at the Hot Rod Nats that pulled it off but it was Corvette Red. I wonder if this is that Pinto? Sure looks like it to me just repainted dark red.
I finally found time to mount my radiator. There were a dozen ways to halfass it in but I wanted it to make it look good. Boy can I make anything into a project.
I made a new bottom on the core support that doubles as the lower mounting point.
The little rubber shipping protectors made perfect mounts so I used them in the bottom.
I still have to weld the upper mounts(ran out of gas for my mig)but they turned out great.
I need to find the right shouldered bolts this week to finish it off.
Also fitted my shroud. I will weld a tunnel on it once the engine & fan are in place.
Quote from: Norman Bagi on July 17, 2012, 10:01:03 AMReally nice car, you may want to keep it as original as possible.  Just a thought.
Thank you. I backed off a lot of major changes I had planned for this car when I started to realize it was oddly optioned & I couldn't find another like it except the parts car another member sent me a pic of.
I'm stashing all the original parts like the 4-speed, front bumper(rear was garbage), stock wheels, etc., just in case it ever warrants a stock resto but it's still just a Pnto & I doubt it would even be worth 10K with a flawless restoration.
I'm changing a few things like painting the grille & headlight buckets satin black instead of argent, the bodyside molding & wheelwell trim is getting stored since I like it without & I have anouther set of brite window trim that's going to get anodized black to replace the originals & I'm putting '78 tail lights with black anodized trim to replace the stockers since I never liked the huge plastic '80 lights anyhow. All this is easily reversible down the road.
I was looking at a 77 with the same color scheme last year.  It was a Rallye, you may want to look into the Marti report on this car, I believe with that interior and since it originaly had the Rallye wheel that you actually have one. Nice work on the body and brakes, I had the same issue with the tie rods rotten almost through.  Good thing you got to it in time.  Really nice car, you may want to keep it as original as possible.  Just a thought.
Quote from: Reeves1 on July 16, 2012, 05:36:28 PM
The air dam below the bumper ?
Right now it is at Map351s place. He is making copies & will be selling them.
Cool, that's the last piece I need to complete my 73's frontend. I hope he posts pics. I was planning to run his other bumper until I decided to tub it.
What I really need to find now is that front valance that's on yours.
Would be nice to have that much shaved off mine with the heavy B2 engine.
Maybe I'll add more HP to off set this ?  ;D
Quote from: Reeves1 on July 16, 2012, 07:14:52 AM
Not fair you can find fiberglass parts ! LOL !
It was no easy task  :)  I swapped a chrome bumper with another member in Delaware for the glass one, drove to New York & got the hood from Pintoman1972 & found the fenders in Pittsburgh & the guy brought them to Canfield for me. And so ends the 2 year search for parts lol.
I figure the whole frontend is gonna weigh about 30 pounds.
I didn't have time to work on the Pinto this weekend. I hit the Canfield swap meet friday, did 5 hours of yard work then spent 6 hours organizing my garage saturday then spent today mowing & trimming trees before work. Man I'm beat!
I did score a pair of fiberglass fenders for my '73 on friday so it wasn't a total loss.
They join the glass hood & bumper that I already rounded up.
By the time I get started on my '73 I should have everything I need to assemble it.
Here's the post where I got the idea from.
http://www.fordpinto.com/general-help/wagon-sway-bar/msg25017/#msg25017
I'm gonna play around with it this weekend & see if it's close or won't work at all. A few zipties will hold it in place while I do the mental planning to make it fit.
bbobcat75
you got a smoking deal on that sway bar kit its over 200.00 on ebay and summit.
good find well now i know what to look for online and at pick and pull.
1975 mercury bobcat 2.8 auto
Quote from: bbobcat75 on July 11, 2012, 07:28:51 PM
plz post pics of install of sway bar!!!
thanks
eric
I definitely will. I hope to get to the back of the car over the winter. I never planned to go as crazy on this car as I have with all this detail work & it's added cubic hours as well as dollars to the build.
I just wanted to get her running again & do this later but I realized I'd never get to it. My son turns 16 in a little over 4 years & I only have about 16 hours a week to work on his car on some weeks but less on most others. Add to that the time spent to maintain my houses & work on my own cars & you begin to realize that 4 years is gonna fly by FAST!
I think the hardest & most labor intensive portion of this build is behind me now that the frontend is complete & I can install the drivetrain. There really was no way to half-butt the front of the car since I replaced everything in sight. I could have skipped all the cleaning & painting but why not do it while it was torn completely apart. I think it adds to the quality of the build to have it look this good underneath.
Once the engine is in & running I can toss the rearend in & drive it, enjoy it & work any bugs out. I'll get it in my garage this winter & pull the axle, springs & fuel tank & go detail crazy back there. I want to tie the subframes, install the rear swaybar, weld in the new rear footwells & finish up under the car by spring.
I want to drive her next year so I'll worry about body/paint next fall. I have a hundred different ideas for body mods so I don't want to jump the gun & paint her too soon. I still need to find a flawless hood anyhow. Mine has a big hole cut under that scoop to clear the air cleaner hose when the turbo was on it.
bbobcat75
thanks
eric
I found a Hellwig 7511 sway bar new in the clearance section at Summit for $30 so I nabbed it. It fits '83 & up Rangers.
I saw a post from '06 that showed eatmydust's installation of one from a Bronco II so I knew the width was correct. I'll get to it when I swap in the 8" rearend & detail the back of the car.
Take a look at this one for your V6.
http://www.summitracing.com/parts/SGT-CU871/
It has the correct sized outlet & inlet on the correct sides, the core is similar in size to the one I found for the 2.3L & it's designed to cool a V6 Jeep Cherokee so it's got the capacity. It even looks like it mounts at the sides which may make installation as simple as drilling a few holes.
bbobcat75
thanks for the info, been looking for something for my v6 bobcat that looks factory and have no luck, but might steal this idea for my 2.3 wagon.!!!
Quote from: bbobcat75 on July 09, 2012, 06:32:07 PM
what is the radiator for?
as far as car make and model??
thanks
eric
looks like a 2.3 setup rad. not v6, by the hose locations!
It's for an '87 to '96 Dodge Dakota. I spent 10 hours researching radiators to find one with the maximum core height & width that fit & had a 1 1/4" upper left & 1 1/2" lower right hose fittings plus a fill cap on top. That was a tall order & I can honestly say I think this may be the only radiator in existence(other than stock Pinto) that measured up. I looked at more than 400 before I stumbled on this one.
The part # is CU981 & unlike a replacement single core Pinto radiator, this one is usually in stock at most parts stores. This one has the pins on the bottom that drop into holes(I'll drill holes & use wiring grommets for those) & shouldered bolts that fasten it at the top. I may grab a pair at the junkyard if I can't match them up at the parts store. Some exhaust bolts look pretty close but I wont know till I measure them.
The core measures 17 5/8" tall by 21 5/8" wide & it's a 2 core downflow that's only 1 1/4" thick.
bbobcat75
thanks
eric
I swung by Summit between runs & picked up my radiator today. It was $107 but I had a $20 off coupon so with tax I spent about $94 for a brand new radiator with a warranty that fits perfectly, will cool a V6, is easily replacable & should take stock Pinto hoses.
All I have to do is make a mount & I already have it designed in my head. I can't wait to tackle this & get it outta the way.
The plan for this car will eventually include an EFI Turbo set up & since this is already a fresh turbo engine it will be a bolt-on deal plus the wiring. This radiator was chosen with that thought in mind......
It was waaaaaay too damn hot this weekend to work on Callisto but I did spend a few hours sweating to install the new master cylinder that replaces the new rebuilt one that was put on prior to the car being parked back in the 90's. I'm not big on rebuilt M/C's to begin with let alone a nearly 20 year old one.
Also recieved the correct passenger side rack boot & installed it along with the swaybar. I tightened everything up, installed the last cotter pins & pumped everything full of grease. All that's left is to bleed the brakes & take her in for an alignment once she's road ready.
I hope to have the radiator & make the mounts next weekend. I'm buying a radiator for a late 80's Dodge Dakota. It measures 18" x 22" & will cool the 3.9L V6 so my 2.3L should never get hot. I wanted a modern plastic & aluminum radiator & this one already has a 1 1/4" inlet on the top left & a 1 1/2" outlet on the bottom right. I'm pretty sure I'm gonna be able to run stock radiator hoses which is a plus.
Quote from: Reeves1 on July 02, 2012, 11:01:26 AM
Very nice work !
Thanks  8)  I've tried to get this project started for nearly 2 years. I pulled the engine in Oct. 2010 to change the leaky rear main seal & remove the turbo & it took until now to find time to work on her. I waited long enough lol....
Put in 5 more hours before work & got the wiring straight. I wont spiral wrap it until I add the MSD wiring.
I also cleaned & painted the left fender.
Then I painted the engine compartment in gloss. The satin wasn't doing anything for me....
I think it may be time to install the engine & transmission so I can finish the wiring & make mounts for the aluminum radiator. I may get to drive her before winter afterall...... :o
Today I decided to tackle the wiring. I removed the Duraspark wiring as well as the voltage regulator wires. I'm converting to an MSD ignition & a 130 amp 1 wire alternator so there was no use leaving it there.
The voltage regulator wiring was crumbling & the main wire from the fusible link was losing all its insulation. The rest of the harness looks great but I'm adding some weatherpak connectors in a few spots to make it easier to hide it under the inner fenders & run it through the holes.
Now that the frontends done I can get a look at the new lower stance. Once the engine & transmission is installed it should come down right where I want it to be.
Snapped a pic of the window sticker & build sheet.
Apparently this car has a special order 42 Gold Sports Package whatever that is.
Quote from: Srt on July 01, 2012, 02:40:25 AM
rear window louvers:
"......All parts were included but there is a series of holes running up them with no explanation of why. I cant figure out why the holes are present but I found the same thing on pics of other Interpart louvers so I guess its something they just did..."
concerning the holes in the slats; they may have been or are for a 'stiffener' to prevent the slats from flapping in the breeze and to eliminate vibration
It seemed like something was missing but I never thought about a vibration reducer. It's probably the same principal as twisting the straps when you secure a load on a flatbed truck. If you don't twist them they catch the wind.
Quote from: bbobcat75 on June 30, 2012, 01:49:05 PM
that  is going to be on detailed pinto!!! i want to do my that much to my 75 bobcat hatch, ill do it when i retire in 40 years, it will give me a project!!!
great work!! the end result will be awsome!!!!!
Thanks  ;D  I didn't earn the nickname "CAPTAIN OVERKILL" for nothing. It was going to be some simple parts swapping until my OCD took over & you see where that takes me LOL....
At least I wont have to do anything twice. All I know is my son better take care of this sucker or I'll take it back  :-\
Here's todays progress. Went to Kenny's Rod & Custom this morning & picked up new T-bolts & braided brake lines for the front. The stock Pinto lines were hitting the spindle & they were a little short so I got 20" lines.
I installed the Energy Suspension control arm bushings & the new Moog ball joint & started assembly.
This side went together easy compared to the passenger side.
In went the new KYB GR2 gas shocks.
Followed by the brake lines(zip tied hose over them for rub protection) then the strut rods(with poly bushings) & steering rack.
I didn't put the sway bar on yet because I didn't realize the right side steering rack bellows differs from the left so I ordered one & have to wait for it so I can button everything up.
