hood for a 79-80
Date: 11/30/2018 10:55 pm
Date: 02/25/2017 08:45 pm
Date: 10/24/2018 07:41 am
Date: 09/15/2019 08:30 pm
Date: 02/18/2017 04:44 pm
Date: 12/31/2017 11:14 pm
77 pinto
Date: 08/22/2017 06:31 pm
1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
Date: 06/22/2017 07:19 am
  • Online today: 178
  • Guests: 115
  • Total: 115
Sway bar comparison
Started by 1975PintoMPG, May 26, 2010, 12:41:11 AM
Stiffness of a sway bar goes up in rate as the fourth power of the diameter. 1/16" makes a big difference. Polly bushings will also make a difference equal to 1/16" larger. Moveing the bar back, and cutting the arms off an inch or two makes a big difference too.
78txpony
Quote from: dave1987 on May 26, 2010, 01:06:35 AM
I installed a sway bar from a 77 Bobcat Wagon onto my 78 Pinto Sedan. It made a noticeable difference in handling, not as much roll when making turns, keeps the car a little more stable.
I installed a sway bar on my 78 MANY years ago - helped a lot when cornering fast.
I cannot remember the size, but it is something like 3/4" or so.
Best EASY bolt on part from the boneyard...  ;D
-Rob Young
1997 H-D Sportster
The bar I have is approximately 15/16" in diameter.  I just got some urathane bushings in that size which fit my bar perfectly.
1975PintoMPG
I didn't know the wagon sway bars were any larger than 3/4 inch. Maybe you can put an open end wrench on it and post what size it is that you have. Did you mean the wagons were equipped with bars up to 1 inch?
I am going to install a wagon front sway bar on my 73 in the next couple weeks.  The wagon bars are a tad larger ~ 1".  I think a front sway bar will make a difference in handling.
1975PintoMPG
I was wondering if anyone upgraded their non sway bar equipped Pinto with a stock sway bar from another Pinto or Mustang II. I want too know how big a difference in handling it made.
I was also wondering if anyone had upgraded their stock 3/4 inch sway bar equipped Pinto with an Addco 1 inch sway bar and if it made a noticeable difference?
