1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 01/04/2017 04:07 am
Date: 10/28/2018 08:45 am
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Date: 12/09/2018 11:35 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 03/25/2019 09:02 pm
Date: 09/06/2020 01:57 am
  • Online today: 587
  • Guests: 176
  • Total: 176
??4.0 V6 IN A PINTO??
Started by billnall, February 08, 2005, 11:49:22 AM
73pinto
the 4.0 should weigh less than a 302 by at least 75 lb.  the 4.0 is based off of the cologne V6 (2.8).  The 2.8 v6 is actualy lighter than the 2.0 and 2.3's due to less block material.
I think it would be a cool swap, but I'd stay away from the a4ld unless it was recently rebuilt or you're gonna have it beefed up.  Those things have trouble holding up behind 4 cylinder mustangs and just HATE v6's.  I just swapped my a4ld out for a 5 speed in my Bronco II.
At any rate, there is a lot of performance potential for the 4.0. cams, chips, even supercharger kits!  Give a 2.3t a run for its money!
-Harry
Stock 73 2.0/4spd 3:40 maximum slip, cd player, pop-out quarter glass.  Soon to be slight performance 2.0/5spd and much more...
Runabout80
I remember seeing someone suggest this as a swap, and I'm not sure on the specifics but I think that the fully dressed 4.0 V6 is almost the same weight as a fully dressed 302.
However I'm not entirely certain, I think that discussion was on the old PCCA Yahoo! Group... But I can be sure... I'll see if I can dig it up for ya. [EDIT 5:04PM CST: Sorry dude, I couldn't find the post about that...]
I'm not saying it can't be done, but I'd bet it would interesting. Plus the 4.0 is a torquey motor, for a V6. I'm thinking that you could have fun with that one, and I'm guessing you probably have easy access to a Ranger speaking that you mentioned the swap. If you decide to try it, best of luck bud.
1980 Pinto 2.3, Not much now but looking at a 400+HP 302 V8 heart transplant. In 2006 probably, too hard to afford stuff like that in College.
billnall
I am thinking of installing a fuel injected 4.0 with an A4LD trans & rear end from a Ranger or Explorer in my 77 Pinto Wagon. Anybody ever done this? If so how did it turn out? Does anybody know if the rear end will fit?
Ford Parts Man
