free transmissions
Date: 11/28/2019 10:21 am
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Date: 01/06/2017 11:42 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 02/18/2017 04:44 pm
Date: 10/24/2019 01:45 pm
Date: 07/17/2019 05:23 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
  • Online today: 135
  • Guests: 76
  • Total: 76
What 2.0 stuff fits the 2.3 ?
Started by pintomadness, May 23, 2010, 06:18:06 PM
pintomadness
I gess I'll rebuild the 2.0 . Thanks for the help , you guys rule !
frame mounts, engine mounts, bell housing, ignition system, throttle cable.......thats just what I can think of right now.......
pintomadness
Hi, what would I have to change , mounts ? Thanks.
Hey just to let you know that the 2.3l is not going to be a bolt in thing on your 73.  It will require a some fabrication that will have to be undone when you put back in your 2.0L.
pintomadness
Hey thanks for the help guys ! I gess I'll pull the 2.0 ,give it a rebuild and put in the stock 2.3 for now . I found a 2.3 flywheel so I should be O.K. Long live the pinto !
Pintopower
Sadly, for reasons unknown, when Ford built a "smog" version of the 2.0, they neglected to use anything on the already in production 2.0. Nothing can be changed. Even the stuff that looks the same is slightly off an will not work at all.
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
Basicly nothing will interchange directly. None of the items you mentioned will fit the 2.3.
pintomadness
Hi what 2.0 stuff can you use on a 2.3 ? I have a 1973  2.0 with a fair bit of h.p. stuff on it but the block is bad .I have a mint ,stock 1979 2.3 out of a pinto to use . Looking to use the intake ,header, fuel pump other things like that . Thanks!
