Date: 08/13/2021 10:39 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
Squire trim
Date: 03/28/2018 10:11 am
pinto parts for sale
Date: 07/25/2018 04:51 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
  • Online today: 135
  • Guests: 64
  • Total: 64
Reverse lockout
Started by kneescraper, May 20, 2010, 11:07:41 AM
Perhaps the "tab" on the shifter's base has ground down? Unlikely though. The tab on the base of the shifter is part of one of the legs that wrap around the shifting rail, it hits the body of the transmission to keep it out of reverse. When you push the shifter down, it clears the body of the transmission enough to allow shifting into reverse.
kneescraper
The rubber is good, the c-clip is still there.  The shifter is held up nicely.  The reverse lockout just isn't working.  There has to be something else other than just the rubber boot that prevents reverse.
Right above where the rubber sits, there should be an indentation in the shaft. a C-clip is supposed to go there which holds the rubber down, making it a "spring". Ace Hardware is where I bought replacements.
kneescraper
The inner rubber is still in fairly good shape on our 4 speed.  It holds the shifter up nice and firm.  The problem is that it will still fall into reverse without pushing down on the shifter.  Any ideas?  Even if the inner rubber was bad, lifting up on the shifter should prevent it from going into reverse, but not on ours.  Am I missing something?
Thanks,
Sam
